hal.parport_ko : Device or Resource busy error
11 Aug 2019 01:01 #141888 by kborsum
I'm also new to the inner workings of LinuxCNC (and Linux in general) and trying to get a system up and running on a new computer.
lspci -v gives my two parallel ports at 0xe010 and 0xd010, so the system seems to recognize them.
But regardless of the Hal_Parport settings, I still get the same error message when LinuxCNC tries to load:
the Hal file generated by stepconf (even tho I specified two parallel ports) contains:
loadrt hal _parport cfg "0xe010 out 0 out"
I've tried a number of variations such as:
loadrt hal _parport cfg "0xe010 out"
loadrt hal _parport cfg "0xe010 out 0xde010" etc
wit the the same results.
After playing a bit, I tried a new load of LinuxCNC with the hal file containing loadrt hal_parport cfg "0xe010" and got a different error:
HAL: ERROR: 'parport 1 read' not found
11 Aug 2019 07:06 #141896 by pl7i92
it seams that the parport card is not set to ECP
can you please post the output of
terminal command
dmesg | grep parpo*
11 Aug 2019 08:01 #141901 by tommylight
Replied by tommylight on topic hal.parport_ko : Device or Resource busy error
Device or resource busy usually means the wrong address and you must reboot the computer after editing the hal file to change the address.
12 Aug 2019 16:34 #141970 by kborsum
I tried your command on the terminal, but got no response.
lspci -v shows two parallel ports: e010 and d010.
After much playing around and reboots, I am able to talk to a BOB on the first port, and can turn the spindle on and off, and control other functions (and perhaps most importantly) it also responds to the EStop command.
I'll be trying the second port shortly.
Thanks for the quick response.
kelly
12 Aug 2019 16:35 #141972 by kborsum
Its taken several tries, but I think the computer is now talking to the BOB's.
12 Aug 2019 17:40 #141974 by tommylight
Nice, glad you got it working properly.
