Laser pwm low power
28 Aug 2019 11:42 #143440 by brettw
Replied by brettw on topic Laser pwm low power
It will be Friday before I get home where I can look at it. But I will look and report back. Thanks for all your help.
31 Aug 2019 19:32 #143742 by brettw
Checked and it is +1. Maybe my laser is bad. Have tried another computer with a parallel port card added and same result.
02 Sep 2019 20:55 #143943 by andypugh
Replied by andypugh on topic Laser pwm low power
Is the voltage 5V without the laser connected and less with it connected?
If so that points to a low impedance input to the laser.
An Op-amp in voltage follower mode is a fairly simple solution in that case. You can dead-bug the circuit and wrap in tape / heat-shrink.
Here is one (and the data sheet) with a 1A output... (if you need more than that the laser definitely is broken)
uk.rs-online.com/web/p/op-amps/1844764/
For voltage follower no other components are needed:
www.learningaboutelectronics.com/Articles/Voltage-follower
www.instructables.com/id/Dead-Bug-Protot...reeform-Electronics/
Time to create page: 0.133 seconds
