Parallel Port failure?
- jensor
- Thank you received: 4
13 Aug 2019 18:24 - 14 Aug 2019 15:06 #142063
by jensor
Parallel Port failure? was created by jensor
My setup uses 3 parallel ports, one on the mother board, and the other two provided by a PCI card. The system has been performing flawlessly for a number of years. Recently it has failed and I have not been able to determine what the cause is.
Using Hal show to see what the parallel outputs are, I find they do not agree with what I see on the Axis presentation.
For example when Axis starts the Axis screen shows as it should that "Machine on" has not been actuated. Looking at Show Hal configuration under Pins/parport/2/pin 2 it shows red (no signal) which agrees with the axis display.
Yet when I look at my breakout strip for port2 pin 2 I have a signal present.
Checking my hal file I see the statement:
net machineon halui.machine.is-on parport.2.pin-02-out
Assuming the PCI parallel port card had failed, I replaced it with an identical one and still get the same results.
Can anyone give me a clue as to how to resolve this problem?
jensor
jensor
Last edit: 14 Aug 2019 15:06 by jensor. Reason: Add attachment
- Thank you received: 7468
13 Aug 2019 22:17 #142087
Replied by tommylight on topic Parallel Port failure?
Can you please attach txt files, not doc files. Hal and ini are OK.
- Grotius
- Thank you received: 2349
14 Aug 2019 01:12 #142099
by Grotius
Replied by Grotius on topic Parallel Port failure?
This is certainly a hard question.
If you can try another pc with the same hard drive and 2 external pci card's. I would give it a try first. Good luck !!
Jensor suggests nothing is changed at the software side.
- jensor
14 Aug 2019 13:46 #142113
by jensor
Replied by jensor on topic Parallel Port failure?
These files were created with Gedit. I added a .doc suffix assuming that would be okay. Gedit should open them for you.
14 Aug 2019 14:47 #142121
Thank you, that does not help on a mobile.
- jensor
14 Aug 2019 15:07 #142123
by jensor
Ok, I renamed the files by changing the suffix from .doc to .txt. See if that works for you.
jensor
jensor
14 Aug 2019 15:38 #142125
Check the header connector, it might be reversed.
Also try the other addresses, but one at a time, not both. With netmos parallel plus serial adapters it is usually the second or the third address that works.
- jensor
14 Aug 2019 20:35 #142157
by jensor
Thanks for the help. I am in the process of setting up another computer. Need to jump through a lot of hoops. Its been so long from the last install.
Time to create page: 0.099 seconds
