gedit
  • jensor
  • jensor's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Aug 2019 21:02 - 14 Aug 2019 21:04 #142163 by jensor
gedit was created by jensor
I am setting up a another pc with linuxcnc using axis 2.7.14 and I would like to install Gedit that I am used to using on my first PC.
Using Synaptic package Manager, I have not been able to find it.
How do I get it or do I need to find another another text editor and learn to use?
I am using the Debian interface.
jensor
Last edit: 14 Aug 2019 21:04 by jensor.
14 Aug 2019 22:22 #142167 by Leon82
Replied by Leon82 on topic gedit
Is pluma available? That's what I use on Deb 9
14 Aug 2019 23:44 #142172 by BigJohnT
Replied by BigJohnT on topic gedit
I've started using Geany instead of Gedit.
sudo apt install geany
JT
15 Aug 2019 01:15 #142178 by cheng
Replied by cheng on topic gedit
try running
sudo apt-get install gedit
or
sudo apt install gedit
  • jensor
  • Premium Member
  • Premium Member
15 Aug 2019 13:10 #142224 by jensor
Replied by jensor on topic gedit
I get this response:
jack@debian:~$ sudo apt install geany
sudo: apt: command not found
jack@debian:~$
  • jensor
  • Premium Member
  • Premium Member
15 Aug 2019 13:28 #142226 by jensor
After update I get:
jack@debian:~$ sudo apt-get install geany
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
jack@debian:~$
  • jensor
  • Premium Member
  • Premium Member
15 Aug 2019 13:32 #142227 by jensor
After closing other things running, I get:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package geany
  • Moderator
  • Moderator
15 Aug 2019 13:47 #142232 by tommylight
Replied by tommylight on topic gedit
You have to enable " extras" in the "software sources "
  • jensor
  • Premium Member
  • Premium Member
15 Aug 2019 15:38 #142242 by jensor
How do I do that?
  • Moderator
  • Moderator
15 Aug 2019 18:17 #142268 by tommylight
What falwor of Linux are you using ?
Time to create page: 0.263 seconds
