Aluminum extrusion table base?
- Leon82
- Thank you received: 79
14 Aug 2019 23:00 #142169
by Leon82
Aluminum extrusion table base? was created by Leon82
I am having a brain fart I think.
I'm looking for the thinn extrusion found in laser engraver tables. This is with t slots. Maybe 20mm thick? Searching has received 20x20 and similar frame pieces. I want a generic table fixture to secure some straps to to hole a work piece.
- pl7i92
- Thank you received: 358
15 Aug 2019 15:44 #142245
by pl7i92
Replied by pl7i92 on topic Aluminum extrusion table base?
somthing like that one
www.ebay.de/itm/Aluminium-Extrusion-T-Sl...Printer/172691228708
The following user(s) said Thank You: Leon82
- Thank you received: 4652
15 Aug 2019 17:47 #142264
Replied by andypugh on topic Aluminum extrusion table base?
If you search eBay for "T-slot 15180" you will find some, though I had not much luck finding anything wider.
15 Aug 2019 17:52 - 15 Aug 2019 17:54 #142265
Via a Youtube video I found
us.misumi-ec.com/vona2/detail/110302261820/
And then the search term
www.google.com/search?q=HFSQN4-15250
Seems to find some useful leads including
www.isel-us.com/aluminum-extrusion-t-slot-table-plate/pt-25
Last edit: 15 Aug 2019 17:54 by andypugh.
Time to create page: 0.071 seconds
