G38.3 gives error: "No characters found in reading real value"
17 Aug 2019 18:37 - 17 Aug 2019 18:56 #142404 by zhivko
I get "No characters found in reading real value" while using G38.3 in MDI mode.
My MDI command is:
G38.3 Z
My config is in:
github.com/zhivko/PipeCutter/blob/master...achinekit/CRAMPS.ini
What could be wrong?
Zhivko
Last edit: 17 Aug 2019 18:56 by zhivko.
17 Aug 2019 18:57 #142405 by zhivko
It works with: G38.3 Z10 F50
Everything OK...
thanks
17 Aug 2019 20:11 #142409 by BigJohnT
From the mighty document for LinxuCNC
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g38
It is an error if:
    the current point is the same as the programmed point.
    no axis word is used
    cutter compensation is enabled
    the feed rate is zero
    the probe is already in the target state
JT
18 Aug 2019 08:45 #142422 by zhivko
Thanks John, is it possible to reset parameter
parameters #5061
so I could programmatically see when parameter is set and procedure completed?
18 Aug 2019 10:40 #142427 by BigJohnT
You could use 5070 to test the result of the probe.
JT
Time to create page: 0.079 seconds
