Touchscreen problem
7 years 2 months ago #143003 by Toolman321
Replied by Toolman321 on topic Touchscreen problem
In dmesg I saw something about possible emi causing the thing to keep shutting down, it would make some sense as the usb runs right past a dc spindle drive on my very messy test bench, I have moved the wire and the problem appears to have gone.
7 years 2 months ago #143015 by tommylight
Replied by tommylight on topic Touchscreen problem
Most new cheap USB cables have no shielding at all, some do have it but not connected to anything, so not much use.
The older ones work perfectly but i am running low on stock !
I use a lot of new ones to power things from USB, so i cut one side and the wires used are pittyful !
Time to create page: 0.248 seconds
