Tool table export/import
  • Kiddekanin
  • Kiddekanin's Avatar Topic Author
  • Junior Member
  • Junior Member
21 Aug 2019 05:02 #142679 by Kiddekanin
Tool table export/import was created by Kiddekanin
Hello.
Fusion 360 is able to export the user custom tooltable. Has enyone had eny luck importing (only the needed columns and rows) into the linuxcnc tool table.
(I would like to only have to enter the tool information once in fusion, and hereafter be able to update the linuxcnc tool table with this exported excell file
21 Aug 2019 15:13 #142727 by pl7i92
Replied by pl7i92 on topic Tool table export/import
simply export it as a Standard iso file
then delete the Colums in CSV mode calc
and save it to your mashine file folder
The following user(s) said Thank You: Kiddekanin
Time to create page: 0.072 seconds
