Choosing a spindle encoder
29 Aug 2019 17:53 #143585 by andypugh
Replied by andypugh on topic Choosing a spindle encoder
I wasn't suggesting splitting the spindle, but if there is any access to the inside of the head without removing the spindle from the bearings then I think that something might be doable. You could split a gear and assemble it around the spindle shaft.
Some ideas:
This is a setup I did using ATS667: photos.app.goo.gl/Jmc4fy9Uvtqed6Lx7
Running in oil and using an existing gear.
These are some fine pitch target wheels I had laser cut, cost was £50 the pair.
photos.app.goo.gl/HfEbXHtSL9qLVf9a7
Here is an encoder made with a slitting saw and mounted to a drive pulley:
photos.app.goo.gl/gotf1D6iMkMGR9Er5
Time to create page: 0.075 seconds
