CNC machine on network
- kainkelly
30 Aug 2019 05:40 #143633
by kainkelly
CNC machine on network was created by kainkelly
Can Linux CNC be accessed over a network? The idea being I can load gcode into a machine and run it with out having to plug my laptop into anything. With the catch being if I pulled my laptop off the network the computer would have all the gcode already loaded up. Almost like a wireless printer sort of.
So maybe a SSH/FTP/SFTP plugin? This is a weekends worth of work for me to write if no one has done this before. (I would think monitoring/controlling machines over network would be pretty standard.)
- Thank you received: 7468
30 Aug 2019 08:47 #143641
Replied by tommylight on topic CNC machine on network
One solution is to use Filezilla to send the files to the machine and use VNC to open and start the machine and monitor it's progress.
Or you can use Samba sharing for files.
The following user(s) said Thank You: kainkelly
- bevins
- Thank you received: 338
30 Aug 2019 11:21 #143647
by bevins
I setup samba on all my machines. You can create a share and then all your microcrap machines can access it just like any other shared
folder on the network. I share my gcode directory under linuxcnc and I just dump my gcode files there.
Replied by bevins on topic CNC machine on network
- pl7i92
- Thank you received: 358
30 Aug 2019 15:06 #143663
by pl7i92
Replied by pl7i92 on topic CNC machine on network
if it is a real shop solution it is bettr also to use only one filename for the mashine
and then there is only one file on the mashine done from the CAM guy so on the Folder in the network it is real save
As off multiple mashines sharing network
- kainkelly
30 Aug 2019 19:52 #143688
by kainkelly
Replied by kainkelly on topic CNC machine on network
This is just a hobby shop, but I will provide do that with my machines just so I don't run the wrong gcode on the wrong machine.
- kainkelly
30 Aug 2019 19:55 #143689
by kainkelly
This is by far the simplest utmost bullet proof solution simple and few well developed moving parts.
- kainkelly
30 Aug 2019 20:02 #143690
by kainkelly
While I am still picking around on the fourms what are you using to run linuxCNC if I may ask, I was looking at the X86 atomic pi being the first that comes to my mind. How ever it's unclear to me if that is actually the best way to host LinuxCNC.
30 Aug 2019 21:17 #143695
The best way to run Linuxcnc is on older enterprise edition Dell or HP computers, core2duo or better. At 70 to 150 euro a piece they are also economicaly viable, they almost never fail, and there are still plenty of them on the market.
SBC's are not a good choice for running machines due to to much power saving features causing latency issues.
Some tests done on RPI 4 by some forum members sugest they are pretty good, but i am giving it some more time.
There are also some ITX boards that work well with Linuxcnc, and if you want something new-ish i can give you the spec of one of my PC's that works wery good, but it is a bit pricy.
- Thank you received: 4652
02 Sep 2019 20:42 #143940
Yes. Install Samba and Avahi and the LinuxCNC machines will be visible on the network.
I save straight to the CNC machine from the CAM package running on the Mac indoors.
Replied by andypugh on topic CNC machine on network
- kainkelly
03 Sep 2019 03:25 #144013
by kainkelly
Thank you, I was hoping for a embedded solution due to the face that this would be going into my shop, which is a uninsulated and unair-conditioned shed in Texas. (Hot, humid, and dusty.) However I think I can make a old machine like that work well enough in that environment. Really may just put filters on all the fans, and relocate internals to main electronics box.
Time to create page: 0.312 seconds
