Rotatory 4 axis lathe
30 Aug 2019 14:06 #143657 by Retiere
Rotatory 4 axis lathe was created by Retiere
Hello everyone, I have a problem with my lathe. It turns obviously under linux cnc, but at the level of the rotation my machine does not turn a continuous. For example to go from 360 to 10 degrees, she will go back. I think it's possible to finally tell him to continue to turn in the same direction. This poses me problem for parts where the speaker varies on the same turn.
Do not hesitate to tell me if I am not clear enough (I am French)
30 Aug 2019 14:52 #143658 by pl7i92
Replied by pl7i92 on topic Rotatory 4 axis lathe
this is part of the postprocessor
did you tell the postprocessor to use +9999 deg and -9999 deg
go short way
then in the mashine Wrapp_rotary=0
so it can run over 360
thats the main thing
10deg is 10 deg and 360 is 360
so postprozess shoudt say go 370
The following user(s) said Thank You: Retiere
02 Sep 2019 20:23 #143935 by andypugh
