Linuxcnc cutting 1/2 scale ?
31 Aug 2019 16:15 #143734 by DonnieT
Linuxcnc cutting 1/2 scale ? was created by DonnieT
Hi everyone. I'm new to the CNC world. Just a hobby for now. My machine was working fine until I moved it to a different shop. Now it is cutting All programs fine only at half scale. 4x2 piece becomes 2x1 . Have fat fingered something ? Thanks for any ideas.
  • Moderator
  • Moderator
31 Aug 2019 17:58 #143738 by tommylight
Replied by tommylight on topic Linuxcnc cutting 1/2 scale ?
Most probably the drives are set to a higher microstepping, so check that first.
31 Aug 2019 19:36 #143743 by DonnieT
Replied by DonnieT on topic Linuxcnc cutting 1/2 scale ?
Thanks. All I did was unplug, move everything and reconnect. It's got me stumped.
02 Sep 2019 20:56 #143944 by andypugh
Replied by andypugh on topic Linuxcnc cutting 1/2 scale ?
If the drives have microstep ratio DIP switches then just change the setting and move on...
Let the cause remain a mystery.
03 Sep 2019 01:33 #143996 by DonnieT
Thank you. Didn't know that could be done. Like I said, I'm new to this. This forum is very helpful.
Time to create page: 0.080 seconds
