Explaning linuxcnc implement kinematics of a new robot
7 years 1 month ago #144513 by Mohamed
Can any one tell me what is .ini and .hal files do, and if i want to make my own robot configurations and kinematics from scratch, from where should i begin and what are the things i should know to make or implement my kinematics of my robot to linuxcnc, then make a simulation using Vismach?
I believe the answers will be useful to a lot of people just like me who don't know how to implement there robot into linuxcnc and make it move like the original examples in linuxcnc
7 years 1 month ago #144526 by pl7i92
ini is the Joint configuration UP to 12 Joints ISO and 24 more are posile
HAL is the connection from pins to interpreter
the Kinetics is just a translator
you shoudt start With a DOF6 or a scara Hexapot kinetics depending on where you want to go
can you give us a image if the ROBOT so we will tell you best options
The following user(s) said Thank You: Mohamed
7 years 1 month ago - 7 years 1 month ago #144543 by Mohamed
Thank you so much for your time....
my robot is a hyprid 5DOF consisting of a tripod and a 2DOF serial arm at the end of the tripod, iam also gonna use a Break out board for that.
can i also ask what is the difference between ISO and posile?
and how to configure both .ini and .hal, is it written in python or what and how to verify i write it correctly ?
Last edit: 7 years 1 month ago by Mohamed.
7 years 1 month ago #144604 by pl7i92
iso are XYZABCUVW AXIS
posible are JOINT_0 - JOINT_16
this is run eighter by internal matrix ISO or a PID loop at Joint mode
so you can mix up your need
in your case i woudt run the tripod as a XYZ
the arm is a Rotary with UVW ofset
7 years 1 month ago #144614 by Mohamed
Thank you so much for these info, it really helped my out,,,
Now i can pretty much know what are .hal and .ini and joints in the .ini do,
but now i want to ask is the kinematics has a file or extension for itself so that i can go there and change it.
Also i saw the vismach hexapod example, and i saw about 6 files including .ini and .hal and another ones, but i didn't see .py for python file, so i wonder where the visualization of the hexapod came from in the (tk) window?
7 years 1 month ago #144766 by andypugh
Every HAL file has something like "loadrt trivkins" or "loadrt genserkins"
Sometimes the actual kins name is read in from the ini:
"loadrt [KINS]KINEMATICS"
But in all cases, that is where the kinematics executable is loaded.
Time to create page: 0.267 seconds
