Known good USB wifi for linux....
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Sep 2019 20:45 #144547 by bevins
Known good USB wifi for linux.... was created by bevins
Anyone have any suggestions for a good known working usb wifi adaptor on Amazon?
I have bought two and both I cannot get to work with linux.
Thanks,
08 Sep 2019 21:29 #144548 by tommylight
Replied by tommylight on topic Known good USB wifi for linux....
There was a topic here last year about wheezy and stretch and those usb dongles, someone has writen a short post about how to.
They need proprietary drivers that are not included with debian.
forum.linuxcnc.org/pathpilot/33493-reliable-usb-wifi
forum.linuxcnc.org/9-installing-linuxcnc...sic-linuxcnc-install
The following user(s) said Thank You: bevins
  • bevins
  • Platinum Member
  • Platinum Member
09 Sep 2019 02:40 #144557 by bevins
Replied by bevins on topic Known good USB wifi for linux....
Thanks,
Ordered pone of dim dare things.
  • bevins
  • Platinum Member
  • Platinum Member
11 Sep 2019 00:04 #144757 by bevins
I fell into the black hole. 6 hours later I climb out with a working usb wifi adaptor and my 10 network for the 7i92M.
JEEEZ!!
17 Sep 2019 12:43 #145385 by andypugh
Replied by andypugh on topic Known good USB wifi for linux....
Too late to the party, but have had good luck with the ones sold for use with the Raspberry Pi, as those are almost by definition Debian compatible.
  • bevins
  • Platinum Member
  • Platinum Member
17 Sep 2019 13:01 #145388 by bevins
That would have been nice info to have....lol
The drivers that came with the adaptor was fubar.
I had to hunt and compile a quite a few before it worked. And now I don't know which one worked......but it has been working great....
22 May 2025 02:52 #328889 by claytoncramer
Replied by claytoncramer on topic Known good USB wifi for linux....
Ciould you give a brand and model number. I have an RTL88 TP Link USB WiFi working at about 40 Kbps, with thr special driver for it. My laqptop in the same spot has abiout 70 Mbps. I would like to buy a known working USB WiFi with whatever driver is needed.
24 May 2025 09:48 #329033 by rodw
Replied by rodw on topic Known good USB wifi for linux....
Wifi has always been problematic for Linux. Google enough and you should find a driver for your hardware to compile. The newer the Linux version, the more likelihood it will work out of the box. I would try Debian Trixie but we don't have an ISO for it. But it should include v 2.9.4 when released in its repos
27 May 2025 19:35 #329265 by clayton2ndtry
Replied by clayton2ndtry on topic Known good USB wifi for linux....
Someone here told me to get a now I cannot remember which chipset, but SMC Wireless USB 2.0 Adapter matched it on Amazon. I just plugged it in and now, instead of 24 Kbps, I have 15 Mbps. (My shop is several feet below the router. A refrigerator is also in the path.)
Time to create page: 0.130 seconds
