Trouble when I cut large files - fails down or up Z axis
  • Moderator
  • Moderator
10 Sep 2019 14:49 #144704 by tommylight
Like everyone else, My money is on lost steps on the Z axis. In my experience, this usually happens on up travel with the weight of the Z axis pushing down.
That is the general consensus regarding the issue, but he is adamant otherwise!
Although someone mentioned it here, it could be memory and that would be very hard to pinpoint, it could also be memory controller on the motherboard and that is even harder to localise.
One more thing to check is the HDD, if it is failing it will cause latency issues.
Did you get a warning about latency excursions ?
10 Sep 2019 15:42 #144713 by zaxlex
no any latency warning I didn't have
10 Sep 2019 15:45 #144714 by zaxlex
In last case my Z axis fails UP not down, it hapens not very often but it happens.
  • Moderator
  • Moderator
10 Sep 2019 15:48 #144715 by tommylight
Wait, what microstepping is set on the drives ? And what drives ?
10 Sep 2019 16:51 #144716 by pl7i92
to provent this we use a G4 P0.5 at Torch off
so the maybe regarding high emi does not interrupt the Z drive
this happens only on Z where the touch off is mounted
at least on our 5 plasmas
10 Sep 2019 18:54 #144730 by zaxlex
400 impulse per round, chinas noname 7 Amper 90 volt
  • Moderator
  • Moderator
10 Sep 2019 19:11 #144732 by tommylight
That is OK.
Thank you.
10 Sep 2019 19:12 #144733 by zaxlex
its my config may be helpfull
17 Sep 2019 12:29 #145383 by andypugh
My first thought was that this might be temperature dependent, but running the same cycle from subdivided files seems to eliminate that possibility.
Is there anything in the dmesg log to indicate a problem with the HDD or memory?
Also, put a mark across the joint between the shafts and couplers, just to be sure that this isn't a mechanical problem with something slipping when hot.
Time to create page: 0.280 seconds
