Information hierarchy
15 Sep 2019 08:28 #145216 by Reinhard
Information hierarchy was created by Reinhard
as I'm attracted by the idea of a java-client for linuxcnc I continued the work and got signals and led working.
On function checking I found out, that field "enabled" from JOINT_STAT behaves different than expected.
I thought, that field would reflect, whether a machine has certain axis or not.
With axis as master, I found out. that the enabled state switches at turning machine on or off, so what's the difference between signal "machine_on" and joint.enabled?
I could parse the ini-file by myself, but what's the leading information?
The axis are defined in display section as geometry and in traj section as coordinates and last not least each joint and each axis has its own section.
Which information wins? Where can I know from, if a machine has certain axis or not?
Just in case, that the different informations are not synchronized / don't match ...
17 Sep 2019 07:24 #145376 by pl7i92
Replied by pl7i92 on topic Information hierarchy
joint.enable can be used to stop a A B C axis as not needed for 3Axius work
mashine enable is a general Switch for the internal as well as external use
17 Sep 2019 22:09 #145455 by andypugh
Replied by andypugh on topic Information hierarchy
[TRAJ]COORDINATES is the important one, [DISPLAY] only controls the GUI preview layout.
18 Sep 2019 02:50 #145477 by Reinhard
Replied by Reinhard on topic Information hierarchy
Thank you Andy,
that information helps!
Time to create page: 0.070 seconds
