Tool table scanning
7 years 1 month ago #146046 by kalev
Tool table scanning was created by kalev
Hello
I have the lathe with horizontal tool turret. During the tool setup I measure the tooltip X,Z distance from rotational center of the turret
and save values into tool table V and W. Before each tool change ( maybe on tool table update ) I want to calculate maximum distance from turret's center ( combining V and W ) of tools loaded in turret. I want to estimate is tool crash into workpiece possible during turret rotation. For that I have to scan tooltable entries. Is scanning possible in O-code or it needs python stuff.
7 years 1 month ago #146068 by pl7i92
Replied by pl7i92 on topic Tool table scanning
hi most postprocessor CAM programms will let you load a External tooltable
so you can put the TXT file to your CAM like Fusion360
you can read the tooltable values of the loaded tool
7 years 1 month ago #146846 by andypugh
Replied by andypugh on topic Tool table scanning
kalev wrote: During the tool setup I measure the tooltip X,Z distance from rotational center of the turret
Why not use X and Y? (Tool X and Y are separate from coordinate system X and Y, so as long as you are consistent that might be better)
You can read the offsets of the loaded tool in G-code, #5401-5409 linuxcnc.org/docs/2.7/html/gcode/overview.html#gcode:parameters
7 years 1 month ago #146867 by pl7i92
@_Andreas_ Andy
this is only for the alredy loaded tool
There shoudt be a Component
thatt reads the entirer tootable
and gives back a wanted tool info
so someone can make dicitions on a prepared tool
7 years 1 month ago #146949 by andypugh
pl7i92 wrote: @_Andreas_ Andy
It isn't that simple in all cases. As G-code can change offsets in parts of the system that components can't see.
7 years 1 month ago #146955 by kalev
Replied by kalev on topic Tool table scanning
Hello and thank for your replies
I think I found solution. I had to use M6 remapping adding to ini
REMAP=M6 modalgroup=6 prolog=my_change_prolog ngc=m6_my
and adding to stdglue.py ( standard change script ) my_change_prolog function ( see attachment ).
Compare standard change_prolog with my_change_prolog to see changes.
Now I have all needed parameters on O-code level.
Next step I need to write m6_my o-code script to prevent turret crash.
7 years 1 month ago #146960 by pl7i92
nice effert to takel this problem
also as it is only nessasary in the tool change it is the best solution
never the less the turret shudt know all tool length
