Parameter not sticking in 2.9
25 Sep 2019 08:46 #146143 by Clive S
Parameter not sticking in 2.9 was created by Clive S
In the view tab axis gui 2.9
show machine position #
show relative position #
axis alway starts up with the radio button on "show machine position"
How can I change this to start with the show relative position # ?
  • Moderator
  • Moderator
25 Sep 2019 09:12 #146147 by tommylight
Replied by tommylight on topic Parameter not sticking in 2.9
I have no clue how to do that, but i wonder why would you want that ?
25 Sep 2019 11:33 #146149 by BigJohnT
25 Sep 2019 14:32 #146162 by Clive S
Replied by Clive S on topic Parameter not sticking in 2.9
Ok when I home the machine then jog an axis say 100mm then touch off at that point the DRO does not change to zero but when I then change with the radio button to "show relative position #" the DRO shows Zero.
But the gui is not remembering that state on a new startup.
25 Sep 2019 14:36 - 25 Sep 2019 14:45 #146164 by Clive S
linuxcnc.org/docs/devel/html/config/ini-...tml#_display_section
JT
Thanks I missed that:
POSITION_OFFSET = RELATIVE - The coordinate system (RELATIVE or MACHINE) to show on the DRO when the user interface starts. The RELATIVE coordinate system reflects the G92 and G5x coordinate offsets currently in effect.
I will try it later
Edit : Yes that worked, You learn all the time :)
Last edit: 25 Sep 2019 14:45 by Clive S.
Time to create page: 0.209 seconds
