Error while opening Linuxcnc
- zbysiek12345
26 Sep 2019 11:54 - 26 Sep 2019 12:09 #146247
by zbysiek12345
Error while opening Linuxcnc was created by zbysiek12345
Hi!
This is my first post on forum.
I have LinuxCNC 2.7.14 on Debian, but I also need this on Ubuntu (Because of CAD/CAM software). So I install LinuxCNC 2.7.14 on Ubuntu Precise 12.04 x86 (32-bit) with the 3.4-9-rtai-686-pae RTAI kernel. Everything was seems to be fine, LinuxCNC opening on sample configs, but I can't figure out why he doesn't on my machine configuration.
This is my error log:
So I try to install it in run in place way. Then I got this error in my linuxcnc_debug and linuxcnc_print files:
EDIT:Ok so in rip installation error occurred because config was made for 2.7.14 and rip is in 2.8. So somebody have an idea why in normal installation I have problem?
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/damian/linuxcnc/configs/Mach3Mill'
Machine configuration file is 'Mach3Mill.ini'
INIFILE=/home/damian/linuxcnc/configs/Mach3Mill/Mach3Mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Mach3Mill.hal
Killing task linuxcncsvr, PID=6906
Debug file information:
insmod: error inserting '/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/trivkins.ko': -1 Unknown symbol in module
./Mach3Mill.hal:4: exit value: 1
./Mach3Mill.hal:4: insmod for trivkins failed, returned -1
See the output of 'dmesg' for more information.
6906
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000b83c5000 (usable)
[ 0.000000] BIOS-e820: 00000000b83c5000 - 00000000b83cc000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000b83cc000 - 00000000b8821000 (usable)
[ 0.000000] BIOS-e820: 00000000b8821000 - 00000000b8c58000 (reserved)
[ 0.000000] BIOS-e820: 00000000b8c58000 - 00000000cc59f000 (usable)
[ 0.000000] BIOS-e820: 00000000cc59f000 - 00000000cc629000 (reserved)
[ 0.000000] BIOS-e820: 00000000cc629000 - 00000000cc642000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cc642000 - 00000000ccb7e000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ccb7e000 - 00000000cdfff000 (reserved)
[ 0.000000] BIOS-e820: 00000000cdfff000 - 00000000ce000000 (usable)
[ 0.000000] BIOS-e820: 00000000cf000000 - 00000000df200000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000021fe00000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: ASUS All Series/H81M-K, BIOS 1104 02/22/2016
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xce000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7E00000000 write-back
[ 0.000000] 1 base 0200000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00D0000000 mask 7FF0000000 uncachable
[ 0.000000] 4 base 00CF000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 021FE00000 mask 7FFFE00000 uncachable
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd770] fd770
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363f4000 - 371f2000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT cc62e080 0007C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP cc63c540 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT cc62e198 0E3A3 (v02 ALASKA A M I 00000031 INTL 20091112)
[ 0.000000] ACPI: FACS ccb7c080 00040
[ 0.000000] ACPI: APIC cc63c650 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT cc63c6c8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: LPIT cc63c710 0005C (v01 ALASKA A M I 00000000 AMI. 00000005)
[ 0.000000] ACPI: SSDT cc63c770 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20091112)
[ 0.000000] ACPI: SSDT cc63ccb0 00AD8 (v01 PmRef CpuPm 00003000 INTL 20091112)
[ 0.000000] ACPI: MCFG cc63d788 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET cc63d7c8 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT cc63d800 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT cc63db70 034E1 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.000000] ACPI: BGRT cc6410b0 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2408MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000ce000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000b83c5
[ 0.000000] 0: 0x000b83cc -> 0x000b8821
[ 0.000000] 0: 0x000b8c58 -> 0x000cc59f
[ 0.000000] 0: 0x000cdfff -> 0x000ce000
[ 0.000000] On node 0 totalpages: 835823
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4a34200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4817 pages used for memmap
[ 0.000000] HighMem zone: 603795 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 829230
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=99c90f44-dc07-4dce-9274-f1b476e28f99 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6750080 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000ce000)
[ 0.000000] Memory: 3288996k/3375104k available (3496k kernel code, 54296k reserved, 1237k data, 416k init, 2434448k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3591.721 MHz processor.
[ 0.000000] Calibrating delay loop (skipped), value calculated using timer frequency.. 7183.44 BogoMIPS (lpj=14366884)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000024] Security Framework initialized
[ 0.000026] AppArmor: AppArmor disabled by boot time parameter
[ 0.000034] Mount-cache hash table entries: 512
[ 0.000134] Initializing cgroup subsys cpuacct
[ 0.000136] Initializing cgroup subsys memory
[ 0.000140] Initializing cgroup subsys devices
[ 0.000141] Initializing cgroup subsys freezer
[ 0.000142] Initializing cgroup subsys net_cls
[ 0.000143] Initializing cgroup subsys blkio
[ 0.000146] Initializing cgroup subsys perf_event
[ 0.000161] CPU: Physical Processor ID: 0
[ 0.000162] CPU: Processor Core ID: 0
[ 0.000165] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000165] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.001586] mce: CPU supports 7 MCE banks
[ 0.001593] CPU0: Thermal monitoring enabled (TM1)
[ 0.001649] ACPI: Core revision 20120320
[ 0.007919] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.008290] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.047961] CPU0: Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz stepping 03
[ 0.154895] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.154899] ... version: 3
[ 0.154900] ... bit width: 48
[ 0.154901] ... generic registers: 4
[ 0.154902] ... value mask: 0000ffffffffffff
[ 0.154903] ... max period: 000000007fffffff
[ 0.154904] ... fixed-purpose events: 3
[ 0.154905] ... event mask: 000000070000000f
[ 0.166932] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.178911] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[ 0.178912] Booting Node 0, Processors #1
[ 0.189103] Initializing CPU#1
[ 0.193434] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.198906] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[ 0.198908] #2
[ 0.209098] Initializing CPU#2
[ 0.213429] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.218900] CPU 3 irqstacks, hard=f3d3c000 soft=f3d3e000
[ 0.218901] #3 Ok.
[ 0.229089] Initializing CPU#3
[ 0.233420] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.233439] Brought up 4 CPUs
[ 0.233441] Total of 4 processors activated (28733.76 BogoMIPS).
[ 0.235593] devtmpfs: initialized
[ 0.235720] PM: Registering ACPI NVS region [mem 0xb83c5000-0xb83cbfff] (28672 bytes)
[ 0.235722] PM: Registering ACPI NVS region [mem 0xcc642000-0xccb7dfff] (5488640 bytes)
[ 0.235856] dummy:
[ 0.235890] NET: Registered protocol family 16
[ 0.235953] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.235954] ACPI: bus type pci registered
[ 0.235983] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.235985] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.235986] PCI: Using MMCONFIG for extended config space
[ 0.235987] PCI: Using configuration type 1 for base access
[ 0.236327] bio: create slab <bio-0> at 0
[ 0.236383] ACPI: Added _OSI(Module Device)
[ 0.236385] ACPI: Added _OSI(Processor Device)
[ 0.236386] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.236387] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.238312] ACPI: EC: Look up EC in DSDT
[ 0.240449] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.243445] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.244032] ACPI: SSDT cc61ec18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20091112)
[ 0.244528] ACPI: Dynamic OEM Table Load:
[ 0.244530] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20091112)
[ 0.244731] ACPI: SSDT cc61e618 005AA (v01 PmRef ApIst 00003000 INTL 20091112)
[ 0.245300] ACPI: Dynamic OEM Table Load:
[ 0.245302] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20091112)
[ 0.245385] ACPI: SSDT cc61dd98 00119 (v01 PmRef ApCst 00003000 INTL 20091112)
[ 0.245883] ACPI: Dynamic OEM Table Load:
[ 0.245885] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20091112)
[ 0.246383] ACPI: Interpreter enabled
[ 0.246387] ACPI: (supports S0 S3 S4 S5)
[ 0.246406] ACPI: Using IOAPIC for interrupt routing
[ 0.251034] ACPI: Power Resource [FN00] (off)
[ 0.251085] ACPI: Power Resource [FN01] (off)
[ 0.251134] ACPI: Power Resource [FN02] (off)
[ 0.251183] ACPI: Power Resource [FN03] (off)
[ 0.251232] ACPI: Power Resource [FN04] (off)
[ 0.251778] ACPI: No dock devices found.
[ 0.251782] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.252013] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.252339] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.252340] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.252341] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.252343] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.252344] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.252345] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.252346] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.252347] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.252349] pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
[ 0.252366] PCI host bridge to bus 0000:00
[ 0.252367] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.252369] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.252370] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.252371] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.252372] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.252373] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.252374] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.252376] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.252377] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
[ 0.252383] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.252408] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[ 0.252428] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.252442] pci 0000:00:02.0: [8086:041e] type 00 class 0x030000
[ 0.252451] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.252456] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.252460] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.252496] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.252511] pci 0000:00:14.0: reg 10: [mem 0xf7f00000-0xf7f0ffff 64bit]
[ 0.252552] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.252568] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.252584] pci 0000:00:16.0: reg 10: [mem 0xf7f1a000-0xf7f1a00f 64bit]
[ 0.252628] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.252653] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.252671] pci 0000:00:1a.0: reg 10: [mem 0xf7f18000-0xf7f183ff]
[ 0.252733] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.252753] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.252765] pci 0000:00:1b.0: reg 10: [mem 0xf7f10000-0xf7f13fff 64bit]
[ 0.252808] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.252824] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.252867] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.252884] pci 0000:00:1c.1: [8086:8c12] type 01 class 0x060400
[ 0.252927] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.252944] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[ 0.252987] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.253011] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.253029] pci 0000:00:1d.0: reg 10: [mem 0xf7f17000-0xf7f173ff]
[ 0.253091] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.253112] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[ 0.253206] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[ 0.253218] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.253224] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.253230] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.253236] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.253242] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.253248] pci 0000:00:1f.2: reg 24: [mem 0xf7f16000-0xf7f167ff]
[ 0.253269] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.253281] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.253293] pci 0000:00:1f.3: reg 10: [mem 0xf7f15000-0xf7f150ff 64bit]
[ 0.253309] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.253343] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.253397] pci 0000:02:00.0: [1c00:3250] type 00 class 0x070005
[ 0.253417] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.253431] pci 0000:02:00.0: reg 14: [mem 0xf0100000-0xf0107fff pref]
[ 0.253445] pci 0000:02:00.0: reg 18: [io 0xe100-0xe103]
[ 0.253497] pci 0000:02:00.0: reg 30: [mem 0xf7e00000-0xf7e07fff pref]
[ 0.253536] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.258889] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.258891] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.258894] pci 0000:00:1c.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.258898] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf01fffff 64bit pref]
[ 0.258954] pci 0000:03:00.0: [8086:10d3] type 00 class 0x020000
[ 0.258976] pci 0000:03:00.0: reg 10: [mem 0xf7dc0000-0xf7ddffff]
[ 0.258992] pci 0000:03:00.0: reg 14: [mem 0xf7d00000-0xf7d7ffff]
[ 0.259008] pci 0000:03:00.0: reg 18: [io 0xd000-0xd01f]
[ 0.259024] pci 0000:03:00.0: reg 1c: [mem 0xf7de0000-0xf7de3fff]
[ 0.259070] pci 0000:03:00.0: reg 30: [mem 0xf7d80000-0xf7dbffff pref]
[ 0.259120] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.266883] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.266886] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff]
[ 0.266888] pci 0000:00:1c.1: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.266938] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.266953] pci 0000:04:00.0: reg 10: [io 0xc000-0xc0ff]
[ 0.266979] pci 0000:04:00.0: reg 18: [mem 0xf7c00000-0xf7c00fff 64bit]
[ 0.266995] pci 0000:04:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.267041] pci 0000:04:00.0: supports D1 D2
[ 0.267042] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.274878] pci 0000:00:1c.2: PCI bridge to [bus 04-04]
[ 0.274881] pci 0000:00:1c.2: bridge window [io 0xc000-0xcfff]
[ 0.274883] pci 0000:00:1c.2: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.274887] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.274900] pci_bus 0000:00: on NUMA node 0
[ 0.274902] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.275000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.275029] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.275057] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.275102] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.275190] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.279339] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.279374] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.279407] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 0.279440] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.279473] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.279505] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.279539] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.279571] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.279614] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.279619] vgaarb: loaded
[ 0.279620] vgaarb: bridge control possible 0000:00:02.0
[ 0.279635] PCI: Using ACPI for IRQ routing
[ 0.280800] PCI: pci_cache_line_size set to 64 bytes
[ 0.280846] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.280848] reserve RAM buffer: 00000000b83c5000 - 00000000bbffffff
[ 0.280849] reserve RAM buffer: 00000000b8821000 - 00000000bbffffff
[ 0.280850] reserve RAM buffer: 00000000cc59f000 - 00000000cfffffff
[ 0.280852] reserve RAM buffer: 00000000ce000000 - 00000000cfffffff
[ 0.280919] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.280924] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.282936] Switching to clocksource hpet
[ 0.282970] pnp: PnP ACPI init
[ 0.282975] ACPI: bus type pnp registered
[ 0.283153] pnp 00:00: [bus 00-3e]
[ 0.283154] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.283156] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.283157] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.283158] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.283159] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.283160] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.283161] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.283162] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.283164] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.283165] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.283166] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.283167] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.283168] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.283169] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.283170] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.283171] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.283172] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.283174] pnp 00:00: [mem 0xdf200000-0xfeafffff window]
[ 0.283205] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.283219] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.283238] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.283240] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.283247] pnp 00:02: [io 0x0000-0x001f]
[ 0.283248] pnp 00:02: [io 0x0081-0x0091]
[ 0.283249] pnp 00:02: [io 0x0093-0x009f]
[ 0.283250] pnp 00:02: [io 0x00c0-0x00df]
[ 0.283251] pnp 00:02: [dma 4]
[ 0.283262] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.283266] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.283277] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.283324] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.283336] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.283353] pnp 00:05: [io 0x00f0]
[ 0.283358] pnp 00:05: [irq 13]
[ 0.283369] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.283429] pnp 00:06: [io 0x002e-0x002f]
[ 0.283430] pnp 00:06: [io 0x004e-0x004f]
[ 0.283431] pnp 00:06: [io 0x0061]
[ 0.283432] pnp 00:06: [io 0x0063]
[ 0.283434] pnp 00:06: [io 0x0065]
[ 0.283435] pnp 00:06: [io 0x0067]
[ 0.283436] pnp 00:06: [io 0x0070]
[ 0.283437] pnp 00:06: [io 0x0080]
[ 0.283437] pnp 00:06: [io 0x0092]
[ 0.283438] pnp 00:06: [io 0x00b2-0x00b3]
[ 0.283439] pnp 00:06: [io 0x0680-0x069f]
[ 0.283440] pnp 00:06: [io 0xffff]
[ 0.283441] pnp 00:06: [io 0xffff]
[ 0.283442] pnp 00:06: [io 0xffff]
[ 0.283443] pnp 00:06: [io 0x1c00-0x1cfe]
[ 0.283444] pnp 00:06: [io 0x1d00-0x1dfe]
[ 0.283445] pnp 00:06: [io 0x1e00-0x1efe]
[ 0.283446] pnp 00:06: [io 0x1f00-0x1ffe]
[ 0.283447] pnp 00:06: [io 0x1800-0x18fe]
[ 0.283448] pnp 00:06: [io 0x164e-0x164f]
[ 0.283472] system 00:06: [io 0x0680-0x069f] has been reserved
[ 0.283473] system 00:06: [io 0xffff] has been reserved
[ 0.283474] system 00:06: [io 0xffff] has been reserved
[ 0.283476] system 00:06: [io 0xffff] has been reserved
[ 0.283477] system 00:06: [io 0x1c00-0x1cfe] has been reserved
[ 0.283478] system 00:06: [io 0x1d00-0x1dfe] has been reserved
[ 0.283480] system 00:06: [io 0x1e00-0x1efe] has been reserved
[ 0.283481] system 00:06: [io 0x1f00-0x1ffe] has been reserved
[ 0.283483] system 00:06: [io 0x1800-0x18fe] has been reserved
[ 0.283484] system 00:06: [io 0x164e-0x164f] has been reserved
[ 0.283486] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.283490] pnp 00:07: [io 0x0070-0x0077]
[ 0.283493] pnp 00:07: [irq 8]
[ 0.283505] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.283521] pnp 00:08: [io 0x1854-0x1857]
[ 0.283540] system 00:08: [io 0x1854-0x1857] has been reserved
[ 0.283541] system 00:08: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.283597] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.283598] pnp 00:09: [io 0x0a00-0x0a1f]
[ 0.283599] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.283600] pnp 00:09: [io 0x0290-0x029f]
[ 0.283601] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.283621] system 00:09: [io 0x0a00-0x0a1f] has been reserved
[ 0.283622] system 00:09: [io 0x0290-0x029f] has been reserved
[ 0.283624] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.283637] pnp 00:0a: [io 0x0060]
[ 0.283638] pnp 00:0a: [io 0x0064]
[ 0.283641] pnp 00:0a: [irq 1]
[ 0.283656] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.283677] pnp 00:0b: [io 0x0010-0x001f]
[ 0.283678] pnp 00:0b: [io 0x0022-0x003f]
[ 0.283679] pnp 00:0b: [io 0x0044-0x005f]
[ 0.283680] pnp 00:0b: [io 0x0062-0x0063]
[ 0.283681] pnp 00:0b: [io 0x0065-0x006f]
[ 0.283682] pnp 00:0b: [io 0x0072-0x007f]
[ 0.283683] pnp 00:0b: [io 0x0080]
[ 0.283684] pnp 00:0b: [io 0x0084-0x0086]
[ 0.283685] pnp 00:0b: [io 0x0088]
[ 0.283686] pnp 00:0b: [io 0x008c-0x008e]
[ 0.283687] pnp 00:0b: [io 0x0090-0x009f]
[ 0.283688] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.283689] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.283690] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.283711] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.283713] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.284024] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.284025] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.284026] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.284028] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.284029] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.284030] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.284031] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.284032] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.284033] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.284034] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.284035] pnp 00:0c: [mem 0xf7fdf000-0xf7fdffff]
[ 0.284036] pnp 00:0c: [mem 0xf7fe0000-0xf7feffff]
[ 0.284068] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.284070] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.284071] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.284073] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.284074] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.284075] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.284077] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.284078] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.284080] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.284081] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.284083] system 00:0c: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.284084] system 00:0c: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.284086] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.284260] pnp: PnP ACPI: found 13 devices
[ 0.284260] ACPI: ACPI bus type pnp unregistered
[ 0.284262] PnPBIOS: Disabled by ACPI PNP
[ 0.319745] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.319751] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.319752] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.319756] pci 0000:00:1c.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.319759] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf01fffff 64bit pref]
[ 0.319763] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.319765] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff]
[ 0.319768] pci 0000:00:1c.1: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.319774] pci 0000:00:1c.2: PCI bridge to [bus 04-04]
[ 0.319776] pci 0000:00:1c.2: bridge window [io 0xc000-0xcfff]
[ 0.319779] pci 0000:00:1c.2: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.319782] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.319807] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.319808] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.319810] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.319811] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.319812] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.319813] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff]
[ 0.319814] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000e3fff]
[ 0.319815] pci_bus 0000:00: resource 11 [mem 0x000e4000-0x000e7fff]
[ 0.319816] pci_bus 0000:00: resource 12 [mem 0xdf200000-0xfeafffff]
[ 0.319818] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.319819] pci_bus 0000:02: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.319820] pci_bus 0000:02: resource 2 [mem 0xf0100000-0xf01fffff 64bit pref]
[ 0.319821] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.319822] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.319823] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
[ 0.319825] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.319826] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.319875] NET: Registered protocol family 2
[ 0.319907] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.319997] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.320141] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.320229] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.320230] TCP: reno registered
[ 0.320232] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.320235] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.320281] NET: Registered protocol family 1
[ 0.320288] pci 0000:00:02.0: Boot video device
[ 0.320453] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.320456] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.358944] PCI: CLS 64 bytes, default 64
[ 0.358967] Unpacking initramfs...
[ 0.528956] Freeing initrd memory: 14328k freed
[ 0.530586] audit: initializing netlink socket (disabled)
[ 0.530596] type=2000 audit(1569491104.420:1): initialized
[ 0.538186] highmem bounce pool size: 64 pages
[ 0.538188] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.538323] VFS: Disk quotas dquot_6.5.2
[ 0.538339] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.538380] msgmni has been set to 1697
[ 0.538474] alg: No test for stdrng (krng)
[ 0.538492] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.538494] io scheduler noop registered
[ 0.538495] io scheduler deadline registered
[ 0.538508] io scheduler cfq registered (default)
[ 0.538659] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.538668] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.538669] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.538977] vesafb: mode is 1920x1200x32, linelength=7680, pages=0
[ 0.538978] vesafb: scrolling: redraw
[ 0.538980] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.539484] vesafb: framebuffer at 0xe0000000, mapped to 0xf8080000, using 9024k, total 9024k
[ 0.539510] fbcon: VESA VGA (fb0) is primary device
[ 0.666169] Console: switching to colour frame buffer device 240x75
[ 0.792819] fb0: VESA VGA frame buffer device
[ 0.792860] GHES: HEST is not enabled!
[ 0.792867] isapnp: Scanning for PnP cards...
[ 1.101908] isapnp: No Plug & Play device found
[ 1.101932] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.102328] Linux agpgart interface v0.103
[ 1.102418] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.102419] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.103050] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.103099] mousedev: PS/2 mouse device common for all mice
[ 1.103117] rtc_cmos 00:07: RTC can wake from S4
[ 1.103208] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 1.103230] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.103304] TCP: cubic registered
[ 1.103344] NET: Registered protocol family 10
[ 1.103462] Mobile IPv6
[ 1.103464] NET: Registered protocol family 17
[ 1.103466] Registering the dns_resolver key type
[ 1.103495] Using IPI No-Shortcut mode
[ 1.103549] PM: Hibernation image not present or could not be loaded.
[ 1.103555] registered taskstats version 1
[ 1.103947] rtc_cmos 00:07: setting system clock to 2019-09-26 09:45:05 UTC (1569491105)
[ 1.104012] Freeing unused kernel memory: 416k freed
[ 1.104084] Write protecting the kernel text: 3500k
[ 1.104096] Write protecting the kernel read-only data: 980k
[ 1.112716] udevd[63]: starting version 175
[ 1.125829] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.125894] usbcore: registered new interface driver usbfs
[ 1.125911] usbcore: registered new interface driver hub
[ 1.128691] ACPI: Fan [FAN0] (off)
[ 1.128724] ACPI: Fan [FAN1] (off)
[ 1.128754] ACPI: Fan [FAN2] (off)
[ 1.128780] ACPI: Fan [FAN3] (off)
[ 1.128806] ACPI: Fan [FAN4] (off)
[ 1.129959] usbcore: registered new device driver usb
[ 1.130258] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.130306] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.130310] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.130323] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.130330] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.130350] r8169 0000:04:00.0: (unregistered net_device): unknown MAC, using family default
[ 1.130376] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.130527] r8169 0000:04:00.0: eth0: RTL8168b/8111b at 0xf802e000, 38:d5:47:24:53:c9, XID 0c000800 IRQ 18
[ 1.130530] r8169 0000:04:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 1.134274] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.134293] ehci_hcd 0000:00:1a.0: irq 20, io mem 0xf7f18000
[ 1.137895] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1.137898] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 1.137912] e1000e 0000:03:00.0: Disabling ASPM L0s L1
[ 1.138030] e1000e 0000:03:00.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.143215] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.143235] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.143238] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.143240] usb usb1: Product: EHCI Host Controller
[ 1.143242] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.143243] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.143503] hub 1-0:1.0: USB hub found
[ 1.143507] hub 1-0:1.0: 2 ports detected
[ 1.143606] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.143610] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.143617] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.143636] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.144442] SCSI subsystem initialized
[ 1.145826] libata version 3.00 loaded.
[ 1.147514] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.147531] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7f17000
[ 1.158673] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.158697] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.158699] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.158700] usb usb2: Product: EHCI Host Controller
[ 1.158701] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.158702] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.158783] hub 2-0:1.0: USB hub found
[ 1.158786] hub 2-0:1.0: 2 ports detected
[ 1.158839] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 1.158845] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 1.158879] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.158881] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.158887] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.158954] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.158987] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.158988] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.158989] usb usb3: Product: xHCI Host Controller
[ 1.158990] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.158992] usb usb3: SerialNumber: 0000:00:14.0
[ 1.159035] xHCI xhci_add_endpoint called for root hub
[ 1.159037] xHCI xhci_check_bandwidth called for root hub
[ 1.159060] hub 3-0:1.0: USB hub found
[ 1.159069] hub 3-0:1.0: 10 ports detected
[ 1.159128] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.159131] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 1.159144] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.159146] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.159147] usb usb4: Product: xHCI Host Controller
[ 1.159149] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.159151] usb usb4: SerialNumber: 0000:00:14.0
[ 1.159193] xHCI xhci_add_endpoint called for root hub
[ 1.159195] xHCI xhci_check_bandwidth called for root hub
[ 1.159216] hub 4-0:1.0: USB hub found
[ 1.159220] hub 4-0:1.0: 2 ports detected
[ 1.162701] ahci 0000:00:1f.2: version 3.0
[ 1.162767] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x12 impl SATA mode
[ 1.162771] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems
[ 1.162774] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.170892] scsi0 : ahci
[ 1.170957] scsi1 : ahci
[ 1.170992] scsi2 : ahci
[ 1.171029] scsi3 : ahci
[ 1.171064] scsi4 : ahci
[ 1.171401] ata1: DUMMY
[ 1.171403] ata2: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16180 irq 19
[ 1.171404] ata3: DUMMY
[ 1.171405] ata4: DUMMY
[ 1.171406] ata5: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16300 irq 19
[ 1.241694] e1000e 0000:03:00.0: eth1: (PCI Express:2.5GT/s:Width x1) 00:1b:21:5e:79:0a
[ 1.241696] e1000e 0000:03:00.0: eth1: Intel(R) PRO/1000 Network Connection
[ 1.241708] e1000e 0000:03:00.0: eth1: MAC: 3, PHY: 8, PBA No: E42641-005
[ 1.454539] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.490527] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.490542] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.490608] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.490613] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f3c5aea8), AE_NOT_FOUND (20120320/psparse-536)
[ 1.490666] ata2.00: ATA-11: SSDPR-CX400-256, SBFM61.3, max UDMA/133
[ 1.490668] ata2.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.490741] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.490744] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f3c5aea8), AE_NOT_FOUND (20120320/psparse-536)
[ 1.490795] ata2.00: configured for UDMA/133
[ 1.490867] scsi 1:0:0:0: Direct-Access ATA SSDPR-CX400-256 SBFM PQ: 0 ANSI: 5
[ 1.492012] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.492016] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5add0), AE_NOT_FOUND (20120320/psparse-536)
[ 1.492078] ata5.00: supports DRM functions and may not be fully accessible
[ 1.492118] ata5.00: ATA-9: Samsung SSD 850 EVO 120GB, EMT02B6Q, max UDMA/133
[ 1.492119] ata5.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 1.492300] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.492303] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5add0), AE_NOT_FOUND (20120320/psparse-536)
[ 1.492386] ata5.00: supports DRM functions and may not be fully accessible
[ 1.492426] ata5.00: configured for UDMA/133
[ 1.492466] scsi 4:0:0:0: Direct-Access ATA Samsung SSD 850 EMT0 PQ: 0 ANSI: 5
[ 1.494583] sd 1:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 1.494599] sd 4:0:0:0: [sdb] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 1.494627] sd 1:0:0:0: [sda] Write Protect is off
[ 1.494630] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.494643] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.494653] sd 4:0:0:0: [sdb] Write Protect is off
[ 1.494655] sd 4:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.494670] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.495078] sda: sda1 sda2 < sda5 >
[ 1.495103] sdb: sdb1 sdb2 < sdb5 >
[ 1.495276] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.495299] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 1.526505] Refined TSC clocksource calibration: 3591.682 MHz.
[ 1.526509] Switching to clocksource tsc
[ 1.527823] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.586797] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.586799] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.586939] hub 1-1:1.0: USB hub found
[ 1.587044] hub 1-1:1.0: 4 ports detected
[ 1.613593] init: ureadahead main process (278) terminated with status 5
[ 1.656018] Adding 8058876k swap on /dev/sda5. Priority:-1 extents:1 across:8058876k SS
[ 1.698435] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.701156] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 1.717396] udevd[407]: starting version 175
[ 1.746621] lp: driver loaded but no devices found
[ 1.787244] wmi: Mapper loaded
[ 1.807649] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.813984] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x19
[ 1.814785] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.814790] ACPI: Power Button [PWRB]
[ 1.814939] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.814942] ACPI: Power Button [PWRF]
[ 1.822433] ppdev: user-space parallel port driver
[ 1.831064] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.831067] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.831490] hub 2-1:1.0: USB hub found
[ 1.831696] hub 2-1:1.0: 6 ports detected
[ 1.874227] Bluetooth: Core ver 2.16
[ 1.874239] NET: Registered protocol family 31
[ 1.874241] Bluetooth: HCI device and connection manager initialized
[ 1.874243] Bluetooth: HCI socket layer initialized
[ 1.874245] Bluetooth: L2CAP socket layer initialized
[ 1.874249] Bluetooth: SCO socket layer initialized
[ 1.878743] Bluetooth: RFCOMM TTY layer initialized
[ 1.878747] Bluetooth: RFCOMM socket layer initialized
[ 1.878749] Bluetooth: RFCOMM ver 1.11
[ 1.890159] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.890162] Bluetooth: BNEP filters: protocol multicast
[ 1.916779] asus_wmi: ASUS WMI generic driver loaded
[ 1.919659] asus_wmi: Initialization: 0x0
[ 1.919685] asus_wmi: BIOS WMI version: 0.9
[ 1.919724] asus_wmi: SFUN value: 0x0
[ 1.920557] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input3
[ 1.921882] asus_wmi: Backlight controlled by ACPI video driver
[ 1.928678] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x19
[ 1.936961] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x19
[ 1.938431] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x19
[ 1.943932] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.998330] usb 3-4: new low-speed USB device number 2 using xhci_hcd
[ 2.018926] usb 3-4: New USB device found, idVendor=09da, idProduct=000a
[ 2.018929] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.018931] usb 3-4: Product: USB Optical Mouse
[ 2.018932] usb 3-4: Manufacturer: A4Tech
[ 2.019026] usb 3-4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.023014] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 2.023237] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 2.023900] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 2.024761] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 2.025600] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 2.042307] usbcore: registered new interface driver usbhid
[ 2.042308] usbhid: USB HID core driver
[ 2.049080] input: A4Tech USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/input/input9
[ 2.049236] a4tech 0003:09DA:000A.0001: input,hidraw0: USB HID v1.10 Mouse [A4Tech USB Optical Mouse] on usb-0000:00:14.0-4/input0
[ 2.328256] NET: Registered protocol family 4
[ 2.330210] NET: Registered protocol family 5
[ 2.362870] init: failsafe main process (935) killed by TERM signal
[ 2.513426] [drm] Initialized drm 1.1.0 20060810
[ 2.514812] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 2.517208] [drm:i915_init] *ERROR* drm/i915 can't work without intel_agp module!
[ 2.522794] r8169 0000:04:00.0: eth0: link down
[ 2.522873] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 2.803178] fuse init (API version 7.18)
[ 5.222144] e1000e: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 5.222365] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 15.897284] eth1: no IPv6 routers present
[ 46.397452] I-pipe: head domain RTAI registered.
[ 46.397455] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 46.397497] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 46.397498] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 46.397500] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 46.397501] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6154250
[ 46.404958] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 46.404978] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 46.404980] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 46.404982] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 46.404983] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 46.414904] RTAI[math]: loaded.
[ 46.449332] config string '0xe100 out'
[ 46.450049] PARPORT: ERROR: request_region(0xe100) failed
[ 48.604991] RTAI[math]: unloaded.
[ 48.605872] SCHED releases registered named ALIEN PEDV$D
[ 48.611646] RTAI[malloc]: unloaded.
[ 48.710895] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 48.711763] I-pipe: head domain RTAI unregistered.
[ 48.711814] RTAI[hal]: unmounted.
[ 107.826418] I-pipe: head domain RTAI registered.
[ 107.826421] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 107.826463] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 107.826465] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 107.826466] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 107.826468] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5841250
[ 107.830629] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 107.830650] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 107.830653] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 107.830655] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 107.830657] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 107.836602] RTAI[math]: loaded.
[ 107.862865] config string '0xe100 out'
[ 107.863485] PARPORT: ERROR: request_region(0xe100) failed
[ 110.007094] RTAI[math]: unloaded.
[ 110.007882] SCHED releases registered named ALIEN PEDV$D
[ 110.013292] RTAI[malloc]: unloaded.
[ 110.109946] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 110.110778] I-pipe: head domain RTAI unregistered.
[ 110.110827] RTAI[hal]: unmounted.
[ 140.635869] I-pipe: head domain RTAI registered.
[ 140.635873] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 140.635919] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 140.635921] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 140.635924] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 140.635926] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6223500
[ 140.639591] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 140.639614] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 140.639619] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 140.639623] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 140.639626] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 140.642619] RTAI[math]: loaded.
[ 140.766431] General Mechatronics: Driver version 1.1.3 loading...
[ 140.766434] HAL: initializing component 'hal_gm'
[ 140.766437] RTAPI: initing module HAL_hal_gm
[ 140.766439] RTAPI: module 'HAL_hal_gm' loaded, ID: 7
[ 140.766441] HAL: component 'hal_gm' initialized, ID = 07
[ 140.766462] HAL: removing component 07
[ 140.766464] RTAPI: module 7 exiting
[ 140.766467] RTAPI: module 7 exited, name: 'HAL_hal_gm'
[ 140.766469] HAL: component 07 removed, name = 'hal_gm'
[ 140.858921] HAL: removing component 06
[ 140.858924] RTAPI: module 6 exiting
[ 140.858926] RTAPI: module 6 exited, name: 'HAL_trivkins'
[ 140.858927] HAL: component 06 removed, name = 'trivkins'
[ 140.888941] HAL_LIB: removing kernel lib
[ 140.888962] RTAPI: shmem 01 freed by module 01
[ 140.888964] RTAPI: module 1 exiting
[ 140.888966] RTAPI: module 1 exited, name: 'HAL_LIB'
[ 140.888967] HAL_LIB: kernel lib removed successfully
[ 140.889768] RTAPI: Exiting
[ 140.889779] RTAPI: Exit complete
[ 140.890543] RTAI[math]: unloaded.
[ 140.891319] SCHED releases registered named ALIEN PEDV$D
[ 140.893427] RTAI[malloc]: unloaded.
[ 140.991310] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 140.992180] I-pipe: head domain RTAI unregistered.
[ 140.992230] RTAI[hal]: unmounted.
[ 239.323739] I-pipe: head domain RTAI registered.
[ 239.323743] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 239.323789] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 239.323792] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 239.323794] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 239.323797] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6148250
[ 239.327791] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 239.327814] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 239.327818] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 239.327820] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 239.327822] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 239.335548] RTAI[math]: loaded.
[ 239.361229] config string '0xe100 out'
[ 239.361842] PARPORT: ERROR: request_region(0xe100) failed
[ 241.519841] RTAI[math]: unloaded.
[ 241.520605] SCHED releases registered named ALIEN PEDV$D
[ 241.522852] RTAI[malloc]: unloaded.
[ 241.620533] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 241.621409] I-pipe: head domain RTAI unregistered.
[ 241.621460] RTAI[hal]: unmounted.
[ 280.387545] I-pipe: head domain RTAI registered.
[ 280.387549] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 280.387593] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 280.387596] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 280.387598] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 280.387600] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6225750
[ 280.391128] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 280.391153] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 280.391156] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 280.391159] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 280.391161] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 280.399704] RTAI[math]: loaded.
[ 280.425989] config string '0xe100 out'
[ 280.426620] PARPORT: ERROR: request_region(0xe100) failed
[ 282.582615] RTAI[math]: unloaded.
[ 282.583378] SCHED releases registered named ALIEN PEDV$D
[ 282.584357] RTAI[malloc]: unloaded.
[ 282.677143] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 282.678050] I-pipe: head domain RTAI unregistered.
[ 282.678101] RTAI[hal]: unmounted.
[ 1263.735050] I-pipe: head domain RTAI registered.
[ 1263.735053] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 1263.735095] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1263.735097] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 1263.735098] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1263.735100] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5186750
[ 1263.739440] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1263.739463] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1263.739466] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 1263.739469] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 1263.739471] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1263.746691] RTAI[math]: loaded.
[ 1263.773369] config string '0xe100 out'
[ 1263.773997] PARPORT: ERROR: request_region(0xe100) failed
[ 1265.923287] RTAI[math]: unloaded.
[ 1265.924059] SCHED releases registered named ALIEN PEDV$D
[ 1265.927812] RTAI[malloc]: unloaded.
[ 1266.024054] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1266.024963] I-pipe: head domain RTAI unregistered.
[ 1266.025015] RTAI[hal]: unmounted.
[ 2129.133081] [Hardware Error]: Machine check events logged
[ 3545.637883] I-pipe: head domain RTAI registered.
[ 3545.637886] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3545.637932] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3545.637934] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3545.637935] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3545.637937] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5733250
[ 3545.645490] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3545.645512] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3545.645515] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3545.645517] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3545.645519] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3545.652247] RTAI[math]: loaded.
[ 3545.702809] motion.c: Creating unlock hal pins for joint 4
[ 3552.026272] RTAI[math]: unloaded.
[ 3552.027052] SCHED releases registered named ALIEN PEDV$D
[ 3552.031595] RTAI[malloc]: unloaded.
[ 3552.128150] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3552.129283] I-pipe: head domain RTAI unregistered.
[ 3552.129335] RTAI[hal]: unmounted.
[ 3610.647545] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 3740.876260] I-pipe: head domain RTAI registered.
[ 3740.876263] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3740.876310] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3740.876312] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3740.876314] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3740.876317] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6228750
[ 3740.880083] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3740.880102] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3740.880105] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3740.880107] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3740.880108] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3740.888211] RTAI[math]: loaded.
[ 3740.914809] config string '0xe100 out'
[ 3740.919713] PARPORT: ERROR: request_region(0xe100) failed
[ 3743.084277] RTAI[math]: unloaded.
[ 3743.085094] SCHED releases registered named ALIEN PEDV$D
[ 3743.087146] RTAI[malloc]: unloaded.
[ 3743.186976] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3743.187913] I-pipe: head domain RTAI unregistered.
[ 3743.187963] RTAI[hal]: unmounted.
[ 3764.328654] I-pipe: head domain RTAI registered.
[ 3764.328658] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3764.328702] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3764.328705] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3764.328707] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3764.328709] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5960250
[ 3764.332412] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3764.332433] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3764.332436] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3764.332439] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3764.332440] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3764.337901] RTAI[math]: loaded.
[ 3764.466249] config string '0xe100 out'
[ 3764.466889] PARPORT: ERROR: request_region(0xe100) failed
[ 3766.632008] RTAI[math]: unloaded.
[ 3766.632801] SCHED releases registered named ALIEN PEDV$D
[ 3766.636662] RTAI[malloc]: unloaded.
[ 3766.734441] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3766.735322] I-pipe: head domain RTAI unregistered.
[ 3766.735372] RTAI[hal]: unmounted.
[ 3778.824795] I-pipe: head domain RTAI registered.
[ 3778.824799] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3778.824844] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3778.824846] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3778.824848] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3778.824851] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5735000
[ 3778.828509] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3778.828528] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3778.828530] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3778.828532] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3778.828533] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3778.835343] RTAI[math]: loaded.
[ 3778.887356] motion.c: Creating unlock hal pins for joint 4
[ 3788.775754] RTAI[math]: unloaded.
[ 3788.776546] SCHED releases registered named ALIEN PEDV$D
[ 3788.779530] RTAI[malloc]: unloaded.
[ 3788.878426] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3788.879363] I-pipe: head domain RTAI unregistered.
[ 3788.879414] RTAI[hal]: unmounted.
[ 3852.410611] I-pipe: head domain RTAI registered.
[ 3852.410615] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3852.410660] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3852.410662] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3852.410664] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3852.410667] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5911750
[ 3852.414708] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3852.414732] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3852.414735] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3852.414737] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3852.414739] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3852.422313] RTAI[math]: loaded.
[ 3852.472432] motion.c: Creating unlock hal pins for joint 4
[ 3864.215977] RTAI[math]: unloaded.
[ 3864.216770] SCHED releases registered named ALIEN PEDV$D
[ 3864.219208] RTAI[malloc]: unloaded.
[ 3864.319110] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3864.320108] I-pipe: head domain RTAI unregistered.
[ 3864.320159] RTAI[hal]: unmounted.
[ 4216.062829] I-pipe: head domain RTAI registered.
[ 4216.062833] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4216.062877] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4216.062880] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4216.062882] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4216.062884] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5284750
[ 4216.067880] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4216.067914] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4216.067918] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4216.067920] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4216.067922] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4216.075488] RTAI[math]: loaded.
[ 4216.102900] config string '0xe100 out'
[ 4216.103533] PARPORT: ERROR: request_region(0xe100) failed
[ 4218.267204] RTAI[math]: unloaded.
[ 4218.268015] SCHED releases registered named ALIEN PEDV$D
[ 4218.270074] RTAI[malloc]: unloaded.
[ 4218.366887] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4218.367766] I-pipe: head domain RTAI unregistered.
[ 4218.367816] RTAI[hal]: unmounted.
[ 4304.512737] I-pipe: head domain RTAI registered.
[ 4304.512740] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4304.512783] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4304.512785] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4304.512786] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4304.512788] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5927500
[ 4304.516559] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4304.516580] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4304.516583] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4304.516584] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4304.516586] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4304.524287] RTAI[math]: loaded.
[ 4304.550713] config string '0xe100 out'
[ 4304.551373] PARPORT: ERROR: request_region(0xe100) failed
[ 4306.716411] RTAI[math]: unloaded.
[ 4306.717224] SCHED releases registered named ALIEN PEDV$D
[ 4306.721849] RTAI[malloc]: unloaded.
[ 4306.818853] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4306.819728] I-pipe: head domain RTAI unregistered.
[ 4306.819778] RTAI[hal]: unmounted.
[ 4369.296032] I-pipe: head domain RTAI registered.
[ 4369.296035] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4369.296077] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4369.296078] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4369.296080] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4369.296081] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5935000
[ 4369.299803] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4369.299825] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4369.299828] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4369.299830] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4369.299832] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4369.308417] RTAI[math]: loaded.
[ 4369.334890] config string '0xe100 out'
[ 4369.335535] PARPORT: ERROR: request_region(0xe100) failed
[ 4371.502226] spurious APIC interrupt on CPU#3, should never happen.
[ 4371.503878] RTAI[math]: unloaded.
[ 4371.504787] SCHED releases registered named ALIEN PEDV$D
[ 4371.506233] RTAI[malloc]: unloaded.
[ 4371.603394] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4371.604283] I-pipe: head domain RTAI unregistered.
[ 4371.604334] RTAI[hal]: unmounted.
[ 4387.633974] I-pipe: head domain RTAI registered.
[ 4387.633978] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4387.634023] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4387.634025] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4387.634028] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4387.634030] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6226750
[ 4387.637645] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4387.637771] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4387.637774] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4387.637775] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4387.637777] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4387.642018] RTAI[math]: loaded.
[ 4387.769232] config string '0xe100 out'
[ 4387.769917] PARPORT: ERROR: request_region(0xe100) failed
[ 4389.937376] RTAI[math]: unloaded.
[ 4389.938193] SCHED releases registered named ALIEN PEDV$D
[ 4389.940692] RTAI[malloc]: unloaded.
[ 4390.036722] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4390.037610] I-pipe: head domain RTAI unregistered.
[ 4390.037661] RTAI[hal]: unmounted.
[ 4523.331771] I-pipe: head domain RTAI registered.
[ 4523.331774] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4523.331816] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4523.331818] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4523.331820] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4523.331821] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5468750
[ 4523.335542] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4523.335568] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4523.335570] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4523.335572] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4523.335573] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4523.338956] RTAI[math]: loaded.
[ 4523.465784] config string '0xe100 out'
[ 4523.466416] PARPORT: ERROR: request_region(0xe100) failed
[ 4525.630989] RTAI[math]: unloaded.
[ 4525.631788] SCHED releases registered named ALIEN PEDV$D
[ 4525.633232] RTAI[malloc]: unloaded.
[ 4525.727582] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4525.728455] I-pipe: head domain RTAI unregistered.
[ 4525.728507] RTAI[hal]: unmounted.
[ 4860.080147] udevd[4524]: starting version 175
[ 4900.606494] I-pipe: head domain RTAI registered.
[ 4900.606498] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4900.606541] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4900.606543] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4900.606545] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4900.606547] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6180500
[ 4900.610753] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4900.610771] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4900.610773] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4900.610775] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4900.610776] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4900.617643] RTAI[math]: loaded.
[ 4900.644308] config string '0xe100 out'
[ 4900.644966] PARPORT: ERROR: request_region(0xe100) failed
[ 4902.814938] RTAI[math]: unloaded.
[ 4902.815837] SCHED releases registered named ALIEN PEDV$D
[ 4902.818848] RTAI[malloc]: unloaded.
[ 4902.914986] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4902.915853] I-pipe: head domain RTAI unregistered.
[ 4902.915903] RTAI[hal]: unmounted.
[ 6885.412188] I-pipe: head domain RTAI registered.
[ 6885.412191] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 6885.412234] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6885.412235] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 6885.412237] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6885.412238] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6045500
[ 6885.415895] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6885.415916] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6885.415919] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 6885.415921] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 6885.415923] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 6885.423566] RTAI[math]: loaded.
[ 6885.450329] config string '0xe100 out'
[ 6885.450966] PARPORT: ERROR: request_region(0xe100) failed
[ 6887.617698] RTAI[math]: unloaded.
[ 6887.618488] SCHED releases registered named ALIEN PEDV$D
[ 6887.623694] RTAI[malloc]: unloaded.
[ 6887.720202] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6887.721121] I-pipe: head domain RTAI unregistered.
[ 6887.721172] RTAI[hal]: unmounted.
[ 7105.509429] I-pipe: head domain RTAI registered.
[ 7105.509434] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 7105.509479] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7105.509481] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 7105.509483] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7105.509486] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6226250
[ 7105.513097] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7105.513115] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7105.513117] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 7105.513119] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 7105.513120] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7105.520597] RTAI[math]: loaded.
[ 7115.709453] RTAI[math]: unloaded.
[ 7115.710252] SCHED releases registered named ALIEN PEDV$D
[ 7115.712647] RTAI[malloc]: unloaded.
[ 7115.809591] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7115.810548] I-pipe: head domain RTAI unregistered.
[ 7115.810597] RTAI[hal]: unmounted.
[ 7120.476175] I-pipe: head domain RTAI registered.
[ 7120.476179] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 7120.476223] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7120.476226] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 7120.476228] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7120.476231] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6225750
[ 7120.479740] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7120.479759] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7120.479761] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 7120.479763] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 7120.479764] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7120.485023] RTAI[math]: loaded.
[ 7120.604022] trivkins: Unknown parameter `coordinates'
[ 7120.739182] RTAI[math]: unloaded.
[ 7120.739972] SCHED releases registered named ALIEN PEDV$D
[ 7120.744290] RTAI[malloc]: unloaded.
[ 7120.843780] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7120.844621] I-pipe: head domain RTAI unregistered.
[ 7120.844673] RTAI[hal]: unmounted.
[ 7205.274797] [Hardware Error]: Machine check events logged
[ 7544.749223] I-pipe: head domain RTAI registered.
[ 7544.749226] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 7544.749268] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7544.749270] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 7544.749271] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7544.749273] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6229750
[ 7544.753026] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7544.753058] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7544.753061] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 7544.753063] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 7544.753064] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7544.759579] RTAI[math]: loaded.
[ 7544.779153] trivkins: Unknown parameter `coordinates'
[ 7544.928618] RTAI[math]: unloaded.
[ 7544.929499] SCHED releases registered named ALIEN PEDV$D
[ 7544.931835] RTAI[malloc]: unloaded.
[ 7545.030174] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7545.031298] I-pipe: head domain RTAI unregistered.
[ 7545.031348] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/damian/linuxcnc/configs/Mach3Mill'
Machine configuration file is 'Mach3Mill.ini'
INIFILE=/home/damian/linuxcnc/configs/Mach3Mill/Mach3Mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Mach3Mill.hal
Killing task linuxcncsvr, PID=6906
Debug file information:
insmod: error inserting '/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/trivkins.ko': -1 Unknown symbol in module
./Mach3Mill.hal:4: exit value: 1
./Mach3Mill.hal:4: insmod for trivkins failed, returned -1
See the output of 'dmesg' for more information.
6906
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000b83c5000 (usable)
[ 0.000000] BIOS-e820: 00000000b83c5000 - 00000000b83cc000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000b83cc000 - 00000000b8821000 (usable)
[ 0.000000] BIOS-e820: 00000000b8821000 - 00000000b8c58000 (reserved)
[ 0.000000] BIOS-e820: 00000000b8c58000 - 00000000cc59f000 (usable)
[ 0.000000] BIOS-e820: 00000000cc59f000 - 00000000cc629000 (reserved)
[ 0.000000] BIOS-e820: 00000000cc629000 - 00000000cc642000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cc642000 - 00000000ccb7e000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ccb7e000 - 00000000cdfff000 (reserved)
[ 0.000000] BIOS-e820: 00000000cdfff000 - 00000000ce000000 (usable)
[ 0.000000] BIOS-e820: 00000000cf000000 - 00000000df200000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000021fe00000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: ASUS All Series/H81M-K, BIOS 1104 02/22/2016
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xce000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7E00000000 write-back
[ 0.000000] 1 base 0200000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00D0000000 mask 7FF0000000 uncachable
[ 0.000000] 4 base 00CF000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 021FE00000 mask 7FFFE00000 uncachable
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd770] fd770
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363f4000 - 371f2000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT cc62e080 0007C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP cc63c540 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT cc62e198 0E3A3 (v02 ALASKA A M I 00000031 INTL 20091112)
[ 0.000000] ACPI: FACS ccb7c080 00040
[ 0.000000] ACPI: APIC cc63c650 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT cc63c6c8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: LPIT cc63c710 0005C (v01 ALASKA A M I 00000000 AMI. 00000005)
[ 0.000000] ACPI: SSDT cc63c770 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20091112)
[ 0.000000] ACPI: SSDT cc63ccb0 00AD8 (v01 PmRef CpuPm 00003000 INTL 20091112)
[ 0.000000] ACPI: MCFG cc63d788 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET cc63d7c8 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT cc63d800 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT cc63db70 034E1 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.000000] ACPI: BGRT cc6410b0 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2408MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000ce000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000b83c5
[ 0.000000] 0: 0x000b83cc -> 0x000b8821
[ 0.000000] 0: 0x000b8c58 -> 0x000cc59f
[ 0.000000] 0: 0x000cdfff -> 0x000ce000
[ 0.000000] On node 0 totalpages: 835823
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4a34200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4817 pages used for memmap
[ 0.000000] HighMem zone: 603795 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 829230
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=99c90f44-dc07-4dce-9274-f1b476e28f99 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6750080 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000ce000)
[ 0.000000] Memory: 3288996k/3375104k available (3496k kernel code, 54296k reserved, 1237k data, 416k init, 2434448k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3591.721 MHz processor.
[ 0.000000] Calibrating delay loop (skipped), value calculated using timer frequency.. 7183.44 BogoMIPS (lpj=14366884)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000024] Security Framework initialized
[ 0.000026] AppArmor: AppArmor disabled by boot time parameter
[ 0.000034] Mount-cache hash table entries: 512
[ 0.000134] Initializing cgroup subsys cpuacct
[ 0.000136] Initializing cgroup subsys memory
[ 0.000140] Initializing cgroup subsys devices
[ 0.000141] Initializing cgroup subsys freezer
[ 0.000142] Initializing cgroup subsys net_cls
[ 0.000143] Initializing cgroup subsys blkio
[ 0.000146] Initializing cgroup subsys perf_event
[ 0.000161] CPU: Physical Processor ID: 0
[ 0.000162] CPU: Processor Core ID: 0
[ 0.000165] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000165] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.001586] mce: CPU supports 7 MCE banks
[ 0.001593] CPU0: Thermal monitoring enabled (TM1)
[ 0.001649] ACPI: Core revision 20120320
[ 0.007919] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.008290] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.047961] CPU0: Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz stepping 03
[ 0.154895] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.154899] ... version: 3
[ 0.154900] ... bit width: 48
[ 0.154901] ... generic registers: 4
[ 0.154902] ... value mask: 0000ffffffffffff
[ 0.154903] ... max period: 000000007fffffff
[ 0.154904] ... fixed-purpose events: 3
[ 0.154905] ... event mask: 000000070000000f
[ 0.166932] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.178911] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[ 0.178912] Booting Node 0, Processors #1
[ 0.189103] Initializing CPU#1
[ 0.193434] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.198906] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[ 0.198908] #2
[ 0.209098] Initializing CPU#2
[ 0.213429] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.218900] CPU 3 irqstacks, hard=f3d3c000 soft=f3d3e000
[ 0.218901] #3 Ok.
[ 0.229089] Initializing CPU#3
[ 0.233420] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.233439] Brought up 4 CPUs
[ 0.233441] Total of 4 processors activated (28733.76 BogoMIPS).
[ 0.235593] devtmpfs: initialized
[ 0.235720] PM: Registering ACPI NVS region [mem 0xb83c5000-0xb83cbfff] (28672 bytes)
[ 0.235722] PM: Registering ACPI NVS region [mem 0xcc642000-0xccb7dfff] (5488640 bytes)
[ 0.235856] dummy:
[ 0.235890] NET: Registered protocol family 16
[ 0.235953] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.235954] ACPI: bus type pci registered
[ 0.235983] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.235985] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.235986] PCI: Using MMCONFIG for extended config space
[ 0.235987] PCI: Using configuration type 1 for base access
[ 0.236327] bio: create slab <bio-0> at 0
[ 0.236383] ACPI: Added _OSI(Module Device)
[ 0.236385] ACPI: Added _OSI(Processor Device)
[ 0.236386] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.236387] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.238312] ACPI: EC: Look up EC in DSDT
[ 0.240449] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.243445] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.244032] ACPI: SSDT cc61ec18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20091112)
[ 0.244528] ACPI: Dynamic OEM Table Load:
[ 0.244530] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20091112)
[ 0.244731] ACPI: SSDT cc61e618 005AA (v01 PmRef ApIst 00003000 INTL 20091112)
[ 0.245300] ACPI: Dynamic OEM Table Load:
[ 0.245302] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20091112)
[ 0.245385] ACPI: SSDT cc61dd98 00119 (v01 PmRef ApCst 00003000 INTL 20091112)
[ 0.245883] ACPI: Dynamic OEM Table Load:
[ 0.245885] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20091112)
[ 0.246383] ACPI: Interpreter enabled
[ 0.246387] ACPI: (supports S0 S3 S4 S5)
[ 0.246406] ACPI: Using IOAPIC for interrupt routing
[ 0.251034] ACPI: Power Resource [FN00] (off)
[ 0.251085] ACPI: Power Resource [FN01] (off)
[ 0.251134] ACPI: Power Resource [FN02] (off)
[ 0.251183] ACPI: Power Resource [FN03] (off)
[ 0.251232] ACPI: Power Resource [FN04] (off)
[ 0.251778] ACPI: No dock devices found.
[ 0.251782] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.252013] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.252339] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.252340] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.252341] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.252343] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.252344] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.252345] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.252346] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.252347] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.252349] pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
[ 0.252366] PCI host bridge to bus 0000:00
[ 0.252367] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.252369] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.252370] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.252371] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.252372] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.252373] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.252374] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.252376] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.252377] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
[ 0.252383] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.252408] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[ 0.252428] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.252442] pci 0000:00:02.0: [8086:041e] type 00 class 0x030000
[ 0.252451] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.252456] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.252460] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.252496] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.252511] pci 0000:00:14.0: reg 10: [mem 0xf7f00000-0xf7f0ffff 64bit]
[ 0.252552] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.252568] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.252584] pci 0000:00:16.0: reg 10: [mem 0xf7f1a000-0xf7f1a00f 64bit]
[ 0.252628] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.252653] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.252671] pci 0000:00:1a.0: reg 10: [mem 0xf7f18000-0xf7f183ff]
[ 0.252733] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.252753] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.252765] pci 0000:00:1b.0: reg 10: [mem 0xf7f10000-0xf7f13fff 64bit]
[ 0.252808] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.252824] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.252867] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.252884] pci 0000:00:1c.1: [8086:8c12] type 01 class 0x060400
[ 0.252927] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.252944] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[ 0.252987] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.253011] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.253029] pci 0000:00:1d.0: reg 10: [mem 0xf7f17000-0xf7f173ff]
[ 0.253091] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.253112] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[ 0.253206] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[ 0.253218] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.253224] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.253230] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.253236] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.253242] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.253248] pci 0000:00:1f.2: reg 24: [mem 0xf7f16000-0xf7f167ff]
[ 0.253269] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.253281] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.253293] pci 0000:00:1f.3: reg 10: [mem 0xf7f15000-0xf7f150ff 64bit]
[ 0.253309] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.253343] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.253397] pci 0000:02:00.0: [1c00:3250] type 00 class 0x070005
[ 0.253417] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.253431] pci 0000:02:00.0: reg 14: [mem 0xf0100000-0xf0107fff pref]
[ 0.253445] pci 0000:02:00.0: reg 18: [io 0xe100-0xe103]
[ 0.253497] pci 0000:02:00.0: reg 30: [mem 0xf7e00000-0xf7e07fff pref]
[ 0.253536] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.258889] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.258891] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.258894] pci 0000:00:1c.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.258898] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf01fffff 64bit pref]
[ 0.258954] pci 0000:03:00.0: [8086:10d3] type 00 class 0x020000
[ 0.258976] pci 0000:03:00.0: reg 10: [mem 0xf7dc0000-0xf7ddffff]
[ 0.258992] pci 0000:03:00.0: reg 14: [mem 0xf7d00000-0xf7d7ffff]
[ 0.259008] pci 0000:03:00.0: reg 18: [io 0xd000-0xd01f]
[ 0.259024] pci 0000:03:00.0: reg 1c: [mem 0xf7de0000-0xf7de3fff]
[ 0.259070] pci 0000:03:00.0: reg 30: [mem 0xf7d80000-0xf7dbffff pref]
[ 0.259120] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.266883] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.266886] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff]
[ 0.266888] pci 0000:00:1c.1: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.266938] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.266953] pci 0000:04:00.0: reg 10: [io 0xc000-0xc0ff]
[ 0.266979] pci 0000:04:00.0: reg 18: [mem 0xf7c00000-0xf7c00fff 64bit]
[ 0.266995] pci 0000:04:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.267041] pci 0000:04:00.0: supports D1 D2
[ 0.267042] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.274878] pci 0000:00:1c.2: PCI bridge to [bus 04-04]
[ 0.274881] pci 0000:00:1c.2: bridge window [io 0xc000-0xcfff]
[ 0.274883] pci 0000:00:1c.2: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.274887] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.274900] pci_bus 0000:00: on NUMA node 0
[ 0.274902] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.275000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.275029] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.275057] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.275102] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.275190] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.279339] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.279374] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.279407] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 0.279440] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.279473] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.279505] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.279539] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.279571] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.279614] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.279619] vgaarb: loaded
[ 0.279620] vgaarb: bridge control possible 0000:00:02.0
[ 0.279635] PCI: Using ACPI for IRQ routing
[ 0.280800] PCI: pci_cache_line_size set to 64 bytes
[ 0.280846] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.280848] reserve RAM buffer: 00000000b83c5000 - 00000000bbffffff
[ 0.280849] reserve RAM buffer: 00000000b8821000 - 00000000bbffffff
[ 0.280850] reserve RAM buffer: 00000000cc59f000 - 00000000cfffffff
[ 0.280852] reserve RAM buffer: 00000000ce000000 - 00000000cfffffff
[ 0.280919] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.280924] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.282936] Switching to clocksource hpet
[ 0.282970] pnp: PnP ACPI init
[ 0.282975] ACPI: bus type pnp registered
[ 0.283153] pnp 00:00: [bus 00-3e]
[ 0.283154] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.283156] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.283157] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.283158] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.283159] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.283160] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.283161] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.283162] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.283164] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.283165] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.283166] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.283167] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.283168] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.283169] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.283170] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.283171] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.283172] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.283174] pnp 00:00: [mem 0xdf200000-0xfeafffff window]
[ 0.283205] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.283219] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.283238] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.283240] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.283247] pnp 00:02: [io 0x0000-0x001f]
[ 0.283248] pnp 00:02: [io 0x0081-0x0091]
[ 0.283249] pnp 00:02: [io 0x0093-0x009f]
[ 0.283250] pnp 00:02: [io 0x00c0-0x00df]
[ 0.283251] pnp 00:02: [dma 4]
[ 0.283262] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.283266] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.283277] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.283324] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.283336] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.283353] pnp 00:05: [io 0x00f0]
[ 0.283358] pnp 00:05: [irq 13]
[ 0.283369] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.283429] pnp 00:06: [io 0x002e-0x002f]
[ 0.283430] pnp 00:06: [io 0x004e-0x004f]
[ 0.283431] pnp 00:06: [io 0x0061]
[ 0.283432] pnp 00:06: [io 0x0063]
[ 0.283434] pnp 00:06: [io 0x0065]
[ 0.283435] pnp 00:06: [io 0x0067]
[ 0.283436] pnp 00:06: [io 0x0070]
[ 0.283437] pnp 00:06: [io 0x0080]
[ 0.283437] pnp 00:06: [io 0x0092]
[ 0.283438] pnp 00:06: [io 0x00b2-0x00b3]
[ 0.283439] pnp 00:06: [io 0x0680-0x069f]
[ 0.283440] pnp 00:06: [io 0xffff]
[ 0.283441] pnp 00:06: [io 0xffff]
[ 0.283442] pnp 00:06: [io 0xffff]
[ 0.283443] pnp 00:06: [io 0x1c00-0x1cfe]
[ 0.283444] pnp 00:06: [io 0x1d00-0x1dfe]
[ 0.283445] pnp 00:06: [io 0x1e00-0x1efe]
[ 0.283446] pnp 00:06: [io 0x1f00-0x1ffe]
[ 0.283447] pnp 00:06: [io 0x1800-0x18fe]
[ 0.283448] pnp 00:06: [io 0x164e-0x164f]
[ 0.283472] system 00:06: [io 0x0680-0x069f] has been reserved
[ 0.283473] system 00:06: [io 0xffff] has been reserved
[ 0.283474] system 00:06: [io 0xffff] has been reserved
[ 0.283476] system 00:06: [io 0xffff] has been reserved
[ 0.283477] system 00:06: [io 0x1c00-0x1cfe] has been reserved
[ 0.283478] system 00:06: [io 0x1d00-0x1dfe] has been reserved
[ 0.283480] system 00:06: [io 0x1e00-0x1efe] has been reserved
[ 0.283481] system 00:06: [io 0x1f00-0x1ffe] has been reserved
[ 0.283483] system 00:06: [io 0x1800-0x18fe] has been reserved
[ 0.283484] system 00:06: [io 0x164e-0x164f] has been reserved
[ 0.283486] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.283490] pnp 00:07: [io 0x0070-0x0077]
[ 0.283493] pnp 00:07: [irq 8]
[ 0.283505] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.283521] pnp 00:08: [io 0x1854-0x1857]
[ 0.283540] system 00:08: [io 0x1854-0x1857] has been reserved
[ 0.283541] system 00:08: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.283597] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.283598] pnp 00:09: [io 0x0a00-0x0a1f]
[ 0.283599] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.283600] pnp 00:09: [io 0x0290-0x029f]
[ 0.283601] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.283621] system 00:09: [io 0x0a00-0x0a1f] has been reserved
[ 0.283622] system 00:09: [io 0x0290-0x029f] has been reserved
[ 0.283624] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.283637] pnp 00:0a: [io 0x0060]
[ 0.283638] pnp 00:0a: [io 0x0064]
[ 0.283641] pnp 00:0a: [irq 1]
[ 0.283656] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.283677] pnp 00:0b: [io 0x0010-0x001f]
[ 0.283678] pnp 00:0b: [io 0x0022-0x003f]
[ 0.283679] pnp 00:0b: [io 0x0044-0x005f]
[ 0.283680] pnp 00:0b: [io 0x0062-0x0063]
[ 0.283681] pnp 00:0b: [io 0x0065-0x006f]
[ 0.283682] pnp 00:0b: [io 0x0072-0x007f]
[ 0.283683] pnp 00:0b: [io 0x0080]
[ 0.283684] pnp 00:0b: [io 0x0084-0x0086]
[ 0.283685] pnp 00:0b: [io 0x0088]
[ 0.283686] pnp 00:0b: [io 0x008c-0x008e]
[ 0.283687] pnp 00:0b: [io 0x0090-0x009f]
[ 0.283688] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.283689] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.283690] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.283711] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.283713] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.284024] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.284025] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.284026] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.284028] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.284029] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.284030] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.284031] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.284032] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.284033] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.284034] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.284035] pnp 00:0c: [mem 0xf7fdf000-0xf7fdffff]
[ 0.284036] pnp 00:0c: [mem 0xf7fe0000-0xf7feffff]
[ 0.284068] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.284070] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.284071] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.284073] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.284074] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.284075] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.284077] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.284078] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.284080] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.284081] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.284083] system 00:0c: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.284084] system 00:0c: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.284086] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.284260] pnp: PnP ACPI: found 13 devices
[ 0.284260] ACPI: ACPI bus type pnp unregistered
[ 0.284262] PnPBIOS: Disabled by ACPI PNP
[ 0.319745] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.319751] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.319752] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.319756] pci 0000:00:1c.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.319759] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf01fffff 64bit pref]
[ 0.319763] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.319765] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff]
[ 0.319768] pci 0000:00:1c.1: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.319774] pci 0000:00:1c.2: PCI bridge to [bus 04-04]
[ 0.319776] pci 0000:00:1c.2: bridge window [io 0xc000-0xcfff]
[ 0.319779] pci 0000:00:1c.2: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.319782] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.319807] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.319808] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.319810] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.319811] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.319812] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.319813] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff]
[ 0.319814] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000e3fff]
[ 0.319815] pci_bus 0000:00: resource 11 [mem 0x000e4000-0x000e7fff]
[ 0.319816] pci_bus 0000:00: resource 12 [mem 0xdf200000-0xfeafffff]
[ 0.319818] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.319819] pci_bus 0000:02: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.319820] pci_bus 0000:02: resource 2 [mem 0xf0100000-0xf01fffff 64bit pref]
[ 0.319821] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.319822] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.319823] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
[ 0.319825] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.319826] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.319875] NET: Registered protocol family 2
[ 0.319907] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.319997] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.320141] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.320229] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.320230] TCP: reno registered
[ 0.320232] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.320235] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.320281] NET: Registered protocol family 1
[ 0.320288] pci 0000:00:02.0: Boot video device
[ 0.320453] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.320456] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.358944] PCI: CLS 64 bytes, default 64
[ 0.358967] Unpacking initramfs...
[ 0.528956] Freeing initrd memory: 14328k freed
[ 0.530586] audit: initializing netlink socket (disabled)
[ 0.530596] type=2000 audit(1569491104.420:1): initialized
[ 0.538186] highmem bounce pool size: 64 pages
[ 0.538188] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.538323] VFS: Disk quotas dquot_6.5.2
[ 0.538339] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.538380] msgmni has been set to 1697
[ 0.538474] alg: No test for stdrng (krng)
[ 0.538492] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.538494] io scheduler noop registered
[ 0.538495] io scheduler deadline registered
[ 0.538508] io scheduler cfq registered (default)
[ 0.538659] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.538668] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.538669] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.538977] vesafb: mode is 1920x1200x32, linelength=7680, pages=0
[ 0.538978] vesafb: scrolling: redraw
[ 0.538980] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.539484] vesafb: framebuffer at 0xe0000000, mapped to 0xf8080000, using 9024k, total 9024k
[ 0.539510] fbcon: VESA VGA (fb0) is primary device
[ 0.666169] Console: switching to colour frame buffer device 240x75
[ 0.792819] fb0: VESA VGA frame buffer device
[ 0.792860] GHES: HEST is not enabled!
[ 0.792867] isapnp: Scanning for PnP cards...
[ 1.101908] isapnp: No Plug & Play device found
[ 1.101932] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.102328] Linux agpgart interface v0.103
[ 1.102418] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.102419] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.103050] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.103099] mousedev: PS/2 mouse device common for all mice
[ 1.103117] rtc_cmos 00:07: RTC can wake from S4
[ 1.103208] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 1.103230] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.103304] TCP: cubic registered
[ 1.103344] NET: Registered protocol family 10
[ 1.103462] Mobile IPv6
[ 1.103464] NET: Registered protocol family 17
[ 1.103466] Registering the dns_resolver key type
[ 1.103495] Using IPI No-Shortcut mode
[ 1.103549] PM: Hibernation image not present or could not be loaded.
[ 1.103555] registered taskstats version 1
[ 1.103947] rtc_cmos 00:07: setting system clock to 2019-09-26 09:45:05 UTC (1569491105)
[ 1.104012] Freeing unused kernel memory: 416k freed
[ 1.104084] Write protecting the kernel text: 3500k
[ 1.104096] Write protecting the kernel read-only data: 980k
[ 1.112716] udevd[63]: starting version 175
[ 1.125829] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.125894] usbcore: registered new interface driver usbfs
[ 1.125911] usbcore: registered new interface driver hub
[ 1.128691] ACPI: Fan [FAN0] (off)
[ 1.128724] ACPI: Fan [FAN1] (off)
[ 1.128754] ACPI: Fan [FAN2] (off)
[ 1.128780] ACPI: Fan [FAN3] (off)
[ 1.128806] ACPI: Fan [FAN4] (off)
[ 1.129959] usbcore: registered new device driver usb
[ 1.130258] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.130306] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.130310] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.130323] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.130330] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.130350] r8169 0000:04:00.0: (unregistered net_device): unknown MAC, using family default
[ 1.130376] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.130527] r8169 0000:04:00.0: eth0: RTL8168b/8111b at 0xf802e000, 38:d5:47:24:53:c9, XID 0c000800 IRQ 18
[ 1.130530] r8169 0000:04:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 1.134274] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.134293] ehci_hcd 0000:00:1a.0: irq 20, io mem 0xf7f18000
[ 1.137895] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1.137898] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 1.137912] e1000e 0000:03:00.0: Disabling ASPM L0s L1
[ 1.138030] e1000e 0000:03:00.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.143215] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.143235] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.143238] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.143240] usb usb1: Product: EHCI Host Controller
[ 1.143242] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.143243] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.143503] hub 1-0:1.0: USB hub found
[ 1.143507] hub 1-0:1.0: 2 ports detected
[ 1.143606] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.143610] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.143617] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.143636] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.144442] SCSI subsystem initialized
[ 1.145826] libata version 3.00 loaded.
[ 1.147514] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.147531] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7f17000
[ 1.158673] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.158697] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.158699] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.158700] usb usb2: Product: EHCI Host Controller
[ 1.158701] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.158702] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.158783] hub 2-0:1.0: USB hub found
[ 1.158786] hub 2-0:1.0: 2 ports detected
[ 1.158839] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 1.158845] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 1.158879] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.158881] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.158887] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.158954] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.158987] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.158988] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.158989] usb usb3: Product: xHCI Host Controller
[ 1.158990] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.158992] usb usb3: SerialNumber: 0000:00:14.0
[ 1.159035] xHCI xhci_add_endpoint called for root hub
[ 1.159037] xHCI xhci_check_bandwidth called for root hub
[ 1.159060] hub 3-0:1.0: USB hub found
[ 1.159069] hub 3-0:1.0: 10 ports detected
[ 1.159128] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.159131] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 1.159144] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.159146] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.159147] usb usb4: Product: xHCI Host Controller
[ 1.159149] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.159151] usb usb4: SerialNumber: 0000:00:14.0
[ 1.159193] xHCI xhci_add_endpoint called for root hub
[ 1.159195] xHCI xhci_check_bandwidth called for root hub
[ 1.159216] hub 4-0:1.0: USB hub found
[ 1.159220] hub 4-0:1.0: 2 ports detected
[ 1.162701] ahci 0000:00:1f.2: version 3.0
[ 1.162767] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x12 impl SATA mode
[ 1.162771] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems
[ 1.162774] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.170892] scsi0 : ahci
[ 1.170957] scsi1 : ahci
[ 1.170992] scsi2 : ahci
[ 1.171029] scsi3 : ahci
[ 1.171064] scsi4 : ahci
[ 1.171401] ata1: DUMMY
[ 1.171403] ata2: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16180 irq 19
[ 1.171404] ata3: DUMMY
[ 1.171405] ata4: DUMMY
[ 1.171406] ata5: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16300 irq 19
[ 1.241694] e1000e 0000:03:00.0: eth1: (PCI Express:2.5GT/s:Width x1) 00:1b:21:5e:79:0a
[ 1.241696] e1000e 0000:03:00.0: eth1: Intel(R) PRO/1000 Network Connection
[ 1.241708] e1000e 0000:03:00.0: eth1: MAC: 3, PHY: 8, PBA No: E42641-005
[ 1.454539] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.490527] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.490542] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.490608] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.490613] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f3c5aea8), AE_NOT_FOUND (20120320/psparse-536)
[ 1.490666] ata2.00: ATA-11: SSDPR-CX400-256, SBFM61.3, max UDMA/133
[ 1.490668] ata2.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.490741] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.490744] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f3c5aea8), AE_NOT_FOUND (20120320/psparse-536)
[ 1.490795] ata2.00: configured for UDMA/133
[ 1.490867] scsi 1:0:0:0: Direct-Access ATA SSDPR-CX400-256 SBFM PQ: 0 ANSI: 5
[ 1.492012] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.492016] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5add0), AE_NOT_FOUND (20120320/psparse-536)
[ 1.492078] ata5.00: supports DRM functions and may not be fully accessible
[ 1.492118] ata5.00: ATA-9: Samsung SSD 850 EVO 120GB, EMT02B6Q, max UDMA/133
[ 1.492119] ata5.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 1.492300] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.492303] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5add0), AE_NOT_FOUND (20120320/psparse-536)
[ 1.492386] ata5.00: supports DRM functions and may not be fully accessible
[ 1.492426] ata5.00: configured for UDMA/133
[ 1.492466] scsi 4:0:0:0: Direct-Access ATA Samsung SSD 850 EMT0 PQ: 0 ANSI: 5
[ 1.494583] sd 1:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 1.494599] sd 4:0:0:0: [sdb] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 1.494627] sd 1:0:0:0: [sda] Write Protect is off
[ 1.494630] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.494643] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.494653] sd 4:0:0:0: [sdb] Write Protect is off
[ 1.494655] sd 4:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.494670] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.495078] sda: sda1 sda2 < sda5 >
[ 1.495103] sdb: sdb1 sdb2 < sdb5 >
[ 1.495276] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.495299] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 1.526505] Refined TSC clocksource calibration: 3591.682 MHz.
[ 1.526509] Switching to clocksource tsc
[ 1.527823] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.586797] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.586799] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.586939] hub 1-1:1.0: USB hub found
[ 1.587044] hub 1-1:1.0: 4 ports detected
[ 1.613593] init: ureadahead main process (278) terminated with status 5
[ 1.656018] Adding 8058876k swap on /dev/sda5. Priority:-1 extents:1 across:8058876k SS
[ 1.698435] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.701156] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 1.717396] udevd[407]: starting version 175
[ 1.746621] lp: driver loaded but no devices found
[ 1.787244] wmi: Mapper loaded
[ 1.807649] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.813984] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x19
[ 1.814785] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.814790] ACPI: Power Button [PWRB]
[ 1.814939] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.814942] ACPI: Power Button [PWRF]
[ 1.822433] ppdev: user-space parallel port driver
[ 1.831064] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.831067] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.831490] hub 2-1:1.0: USB hub found
[ 1.831696] hub 2-1:1.0: 6 ports detected
[ 1.874227] Bluetooth: Core ver 2.16
[ 1.874239] NET: Registered protocol family 31
[ 1.874241] Bluetooth: HCI device and connection manager initialized
[ 1.874243] Bluetooth: HCI socket layer initialized
[ 1.874245] Bluetooth: L2CAP socket layer initialized
[ 1.874249] Bluetooth: SCO socket layer initialized
[ 1.878743] Bluetooth: RFCOMM TTY layer initialized
[ 1.878747] Bluetooth: RFCOMM socket layer initialized
[ 1.878749] Bluetooth: RFCOMM ver 1.11
[ 1.890159] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.890162] Bluetooth: BNEP filters: protocol multicast
[ 1.916779] asus_wmi: ASUS WMI generic driver loaded
[ 1.919659] asus_wmi: Initialization: 0x0
[ 1.919685] asus_wmi: BIOS WMI version: 0.9
[ 1.919724] asus_wmi: SFUN value: 0x0
[ 1.920557] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input3
[ 1.921882] asus_wmi: Backlight controlled by ACPI video driver
[ 1.928678] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x19
[ 1.936961] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x19
[ 1.938431] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x19
[ 1.943932] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.998330] usb 3-4: new low-speed USB device number 2 using xhci_hcd
[ 2.018926] usb 3-4: New USB device found, idVendor=09da, idProduct=000a
[ 2.018929] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.018931] usb 3-4: Product: USB Optical Mouse
[ 2.018932] usb 3-4: Manufacturer: A4Tech
[ 2.019026] usb 3-4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.023014] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 2.023237] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 2.023900] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 2.024761] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 2.025600] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 2.042307] usbcore: registered new interface driver usbhid
[ 2.042308] usbhid: USB HID core driver
[ 2.049080] input: A4Tech USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/input/input9
[ 2.049236] a4tech 0003:09DA:000A.0001: input,hidraw0: USB HID v1.10 Mouse [A4Tech USB Optical Mouse] on usb-0000:00:14.0-4/input0
[ 2.328256] NET: Registered protocol family 4
[ 2.330210] NET: Registered protocol family 5
[ 2.362870] init: failsafe main process (935) killed by TERM signal
[ 2.513426] [drm] Initialized drm 1.1.0 20060810
[ 2.514812] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 2.517208] [drm:i915_init] *ERROR* drm/i915 can't work without intel_agp module!
[ 2.522794] r8169 0000:04:00.0: eth0: link down
[ 2.522873] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 2.803178] fuse init (API version 7.18)
[ 5.222144] e1000e: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 5.222365] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 15.897284] eth1: no IPv6 routers present
[ 46.397452] I-pipe: head domain RTAI registered.
[ 46.397455] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 46.397497] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 46.397498] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 46.397500] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 46.397501] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6154250
[ 46.404958] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 46.404978] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 46.404980] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 46.404982] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 46.404983] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 46.414904] RTAI[math]: loaded.
[ 46.449332] config string '0xe100 out'
[ 46.450049] PARPORT: ERROR: request_region(0xe100) failed
[ 48.604991] RTAI[math]: unloaded.
[ 48.605872] SCHED releases registered named ALIEN PEDV$D
[ 48.611646] RTAI[malloc]: unloaded.
[ 48.710895] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 48.711763] I-pipe: head domain RTAI unregistered.
[ 48.711814] RTAI[hal]: unmounted.
[ 107.826418] I-pipe: head domain RTAI registered.
[ 107.826421] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 107.826463] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 107.826465] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 107.826466] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 107.826468] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5841250
[ 107.830629] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 107.830650] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 107.830653] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 107.830655] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 107.830657] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 107.836602] RTAI[math]: loaded.
[ 107.862865] config string '0xe100 out'
[ 107.863485] PARPORT: ERROR: request_region(0xe100) failed
[ 110.007094] RTAI[math]: unloaded.
[ 110.007882] SCHED releases registered named ALIEN PEDV$D
[ 110.013292] RTAI[malloc]: unloaded.
[ 110.109946] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 110.110778] I-pipe: head domain RTAI unregistered.
[ 110.110827] RTAI[hal]: unmounted.
[ 140.635869] I-pipe: head domain RTAI registered.
[ 140.635873] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 140.635919] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 140.635921] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 140.635924] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 140.635926] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6223500
[ 140.639591] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 140.639614] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 140.639619] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 140.639623] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 140.639626] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 140.642619] RTAI[math]: loaded.
[ 140.766431] General Mechatronics: Driver version 1.1.3 loading...
[ 140.766434] HAL: initializing component 'hal_gm'
[ 140.766437] RTAPI: initing module HAL_hal_gm
[ 140.766439] RTAPI: module 'HAL_hal_gm' loaded, ID: 7
[ 140.766441] HAL: component 'hal_gm' initialized, ID = 07
[ 140.766462] HAL: removing component 07
[ 140.766464] RTAPI: module 7 exiting
[ 140.766467] RTAPI: module 7 exited, name: 'HAL_hal_gm'
[ 140.766469] HAL: component 07 removed, name = 'hal_gm'
[ 140.858921] HAL: removing component 06
[ 140.858924] RTAPI: module 6 exiting
[ 140.858926] RTAPI: module 6 exited, name: 'HAL_trivkins'
[ 140.858927] HAL: component 06 removed, name = 'trivkins'
[ 140.888941] HAL_LIB: removing kernel lib
[ 140.888962] RTAPI: shmem 01 freed by module 01
[ 140.888964] RTAPI: module 1 exiting
[ 140.888966] RTAPI: module 1 exited, name: 'HAL_LIB'
[ 140.888967] HAL_LIB: kernel lib removed successfully
[ 140.889768] RTAPI: Exiting
[ 140.889779] RTAPI: Exit complete
[ 140.890543] RTAI[math]: unloaded.
[ 140.891319] SCHED releases registered named ALIEN PEDV$D
[ 140.893427] RTAI[malloc]: unloaded.
[ 140.991310] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 140.992180] I-pipe: head domain RTAI unregistered.
[ 140.992230] RTAI[hal]: unmounted.
[ 239.323739] I-pipe: head domain RTAI registered.
[ 239.323743] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 239.323789] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 239.323792] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 239.323794] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 239.323797] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6148250
[ 239.327791] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 239.327814] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 239.327818] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 239.327820] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 239.327822] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 239.335548] RTAI[math]: loaded.
[ 239.361229] config string '0xe100 out'
[ 239.361842] PARPORT: ERROR: request_region(0xe100) failed
[ 241.519841] RTAI[math]: unloaded.
[ 241.520605] SCHED releases registered named ALIEN PEDV$D
[ 241.522852] RTAI[malloc]: unloaded.
[ 241.620533] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 241.621409] I-pipe: head domain RTAI unregistered.
[ 241.621460] RTAI[hal]: unmounted.
[ 280.387545] I-pipe: head domain RTAI registered.
[ 280.387549] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 280.387593] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 280.387596] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 280.387598] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 280.387600] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6225750
[ 280.391128] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 280.391153] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 280.391156] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 280.391159] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 280.391161] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 280.399704] RTAI[math]: loaded.
[ 280.425989] config string '0xe100 out'
[ 280.426620] PARPORT: ERROR: request_region(0xe100) failed
[ 282.582615] RTAI[math]: unloaded.
[ 282.583378] SCHED releases registered named ALIEN PEDV$D
[ 282.584357] RTAI[malloc]: unloaded.
[ 282.677143] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 282.678050] I-pipe: head domain RTAI unregistered.
[ 282.678101] RTAI[hal]: unmounted.
[ 1263.735050] I-pipe: head domain RTAI registered.
[ 1263.735053] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 1263.735095] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1263.735097] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 1263.735098] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1263.735100] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5186750
[ 1263.739440] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1263.739463] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1263.739466] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 1263.739469] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 1263.739471] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1263.746691] RTAI[math]: loaded.
[ 1263.773369] config string '0xe100 out'
[ 1263.773997] PARPORT: ERROR: request_region(0xe100) failed
[ 1265.923287] RTAI[math]: unloaded.
[ 1265.924059] SCHED releases registered named ALIEN PEDV$D
[ 1265.927812] RTAI[malloc]: unloaded.
[ 1266.024054] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1266.024963] I-pipe: head domain RTAI unregistered.
[ 1266.025015] RTAI[hal]: unmounted.
[ 2129.133081] [Hardware Error]: Machine check events logged
[ 3545.637883] I-pipe: head domain RTAI registered.
[ 3545.637886] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3545.637932] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3545.637934] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3545.637935] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3545.637937] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5733250
[ 3545.645490] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3545.645512] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3545.645515] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3545.645517] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3545.645519] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3545.652247] RTAI[math]: loaded.
[ 3545.702809] motion.c: Creating unlock hal pins for joint 4
[ 3552.026272] RTAI[math]: unloaded.
[ 3552.027052] SCHED releases registered named ALIEN PEDV$D
[ 3552.031595] RTAI[malloc]: unloaded.
[ 3552.128150] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3552.129283] I-pipe: head domain RTAI unregistered.
[ 3552.129335] RTAI[hal]: unmounted.
[ 3610.647545] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 3740.876260] I-pipe: head domain RTAI registered.
[ 3740.876263] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3740.876310] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3740.876312] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3740.876314] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3740.876317] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6228750
[ 3740.880083] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3740.880102] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3740.880105] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3740.880107] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3740.880108] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3740.888211] RTAI[math]: loaded.
[ 3740.914809] config string '0xe100 out'
[ 3740.919713] PARPORT: ERROR: request_region(0xe100) failed
[ 3743.084277] RTAI[math]: unloaded.
[ 3743.085094] SCHED releases registered named ALIEN PEDV$D
[ 3743.087146] RTAI[malloc]: unloaded.
[ 3743.186976] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3743.187913] I-pipe: head domain RTAI unregistered.
[ 3743.187963] RTAI[hal]: unmounted.
[ 3764.328654] I-pipe: head domain RTAI registered.
[ 3764.328658] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3764.328702] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3764.328705] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3764.328707] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3764.328709] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5960250
[ 3764.332412] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3764.332433] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3764.332436] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3764.332439] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3764.332440] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3764.337901] RTAI[math]: loaded.
[ 3764.466249] config string '0xe100 out'
[ 3764.466889] PARPORT: ERROR: request_region(0xe100) failed
[ 3766.632008] RTAI[math]: unloaded.
[ 3766.632801] SCHED releases registered named ALIEN PEDV$D
[ 3766.636662] RTAI[malloc]: unloaded.
[ 3766.734441] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3766.735322] I-pipe: head domain RTAI unregistered.
[ 3766.735372] RTAI[hal]: unmounted.
[ 3778.824795] I-pipe: head domain RTAI registered.
[ 3778.824799] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3778.824844] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3778.824846] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3778.824848] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3778.824851] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5735000
[ 3778.828509] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3778.828528] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3778.828530] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3778.828532] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3778.828533] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3778.835343] RTAI[math]: loaded.
[ 3778.887356] motion.c: Creating unlock hal pins for joint 4
[ 3788.775754] RTAI[math]: unloaded.
[ 3788.776546] SCHED releases registered named ALIEN PEDV$D
[ 3788.779530] RTAI[malloc]: unloaded.
[ 3788.878426] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3788.879363] I-pipe: head domain RTAI unregistered.
[ 3788.879414] RTAI[hal]: unmounted.
[ 3852.410611] I-pipe: head domain RTAI registered.
[ 3852.410615] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3852.410660] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3852.410662] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 3852.410664] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3852.410667] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5911750
[ 3852.414708] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3852.414732] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3852.414735] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 3852.414737] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 3852.414739] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3852.422313] RTAI[math]: loaded.
[ 3852.472432] motion.c: Creating unlock hal pins for joint 4
[ 3864.215977] RTAI[math]: unloaded.
[ 3864.216770] SCHED releases registered named ALIEN PEDV$D
[ 3864.219208] RTAI[malloc]: unloaded.
[ 3864.319110] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3864.320108] I-pipe: head domain RTAI unregistered.
[ 3864.320159] RTAI[hal]: unmounted.
[ 4216.062829] I-pipe: head domain RTAI registered.
[ 4216.062833] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4216.062877] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4216.062880] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4216.062882] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4216.062884] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5284750
[ 4216.067880] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4216.067914] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4216.067918] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4216.067920] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4216.067922] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4216.075488] RTAI[math]: loaded.
[ 4216.102900] config string '0xe100 out'
[ 4216.103533] PARPORT: ERROR: request_region(0xe100) failed
[ 4218.267204] RTAI[math]: unloaded.
[ 4218.268015] SCHED releases registered named ALIEN PEDV$D
[ 4218.270074] RTAI[malloc]: unloaded.
[ 4218.366887] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4218.367766] I-pipe: head domain RTAI unregistered.
[ 4218.367816] RTAI[hal]: unmounted.
[ 4304.512737] I-pipe: head domain RTAI registered.
[ 4304.512740] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4304.512783] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4304.512785] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4304.512786] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4304.512788] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5927500
[ 4304.516559] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4304.516580] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4304.516583] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4304.516584] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4304.516586] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4304.524287] RTAI[math]: loaded.
[ 4304.550713] config string '0xe100 out'
[ 4304.551373] PARPORT: ERROR: request_region(0xe100) failed
[ 4306.716411] RTAI[math]: unloaded.
[ 4306.717224] SCHED releases registered named ALIEN PEDV$D
[ 4306.721849] RTAI[malloc]: unloaded.
[ 4306.818853] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4306.819728] I-pipe: head domain RTAI unregistered.
[ 4306.819778] RTAI[hal]: unmounted.
[ 4369.296032] I-pipe: head domain RTAI registered.
[ 4369.296035] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4369.296077] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4369.296078] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4369.296080] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4369.296081] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5935000
[ 4369.299803] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4369.299825] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4369.299828] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4369.299830] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4369.299832] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4369.308417] RTAI[math]: loaded.
[ 4369.334890] config string '0xe100 out'
[ 4369.335535] PARPORT: ERROR: request_region(0xe100) failed
[ 4371.502226] spurious APIC interrupt on CPU#3, should never happen.
[ 4371.503878] RTAI[math]: unloaded.
[ 4371.504787] SCHED releases registered named ALIEN PEDV$D
[ 4371.506233] RTAI[malloc]: unloaded.
[ 4371.603394] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4371.604283] I-pipe: head domain RTAI unregistered.
[ 4371.604334] RTAI[hal]: unmounted.
[ 4387.633974] I-pipe: head domain RTAI registered.
[ 4387.633978] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4387.634023] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4387.634025] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4387.634028] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4387.634030] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6226750
[ 4387.637645] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4387.637771] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4387.637774] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4387.637775] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4387.637777] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4387.642018] RTAI[math]: loaded.
[ 4387.769232] config string '0xe100 out'
[ 4387.769917] PARPORT: ERROR: request_region(0xe100) failed
[ 4389.937376] RTAI[math]: unloaded.
[ 4389.938193] SCHED releases registered named ALIEN PEDV$D
[ 4389.940692] RTAI[malloc]: unloaded.
[ 4390.036722] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4390.037610] I-pipe: head domain RTAI unregistered.
[ 4390.037661] RTAI[hal]: unmounted.
[ 4523.331771] I-pipe: head domain RTAI registered.
[ 4523.331774] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4523.331816] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4523.331818] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4523.331820] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4523.331821] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 5468750
[ 4523.335542] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4523.335568] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4523.335570] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4523.335572] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4523.335573] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4523.338956] RTAI[math]: loaded.
[ 4523.465784] config string '0xe100 out'
[ 4523.466416] PARPORT: ERROR: request_region(0xe100) failed
[ 4525.630989] RTAI[math]: unloaded.
[ 4525.631788] SCHED releases registered named ALIEN PEDV$D
[ 4525.633232] RTAI[malloc]: unloaded.
[ 4525.727582] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4525.728455] I-pipe: head domain RTAI unregistered.
[ 4525.728507] RTAI[hal]: unmounted.
[ 4860.080147] udevd[4524]: starting version 175
[ 4900.606494] I-pipe: head domain RTAI registered.
[ 4900.606498] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 4900.606541] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4900.606543] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 4900.606545] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4900.606547] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6180500
[ 4900.610753] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4900.610771] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4900.610773] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 4900.610775] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 4900.610776] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4900.617643] RTAI[math]: loaded.
[ 4900.644308] config string '0xe100 out'
[ 4900.644966] PARPORT: ERROR: request_region(0xe100) failed
[ 4902.814938] RTAI[math]: unloaded.
[ 4902.815837] SCHED releases registered named ALIEN PEDV$D
[ 4902.818848] RTAI[malloc]: unloaded.
[ 4902.914986] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4902.915853] I-pipe: head domain RTAI unregistered.
[ 4902.915903] RTAI[hal]: unmounted.
[ 6885.412188] I-pipe: head domain RTAI registered.
[ 6885.412191] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 6885.412234] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6885.412235] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 6885.412237] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6885.412238] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6045500
[ 6885.415895] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6885.415916] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6885.415919] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 6885.415921] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 6885.415923] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 6885.423566] RTAI[math]: loaded.
[ 6885.450329] config string '0xe100 out'
[ 6885.450966] PARPORT: ERROR: request_region(0xe100) failed
[ 6887.617698] RTAI[math]: unloaded.
[ 6887.618488] SCHED releases registered named ALIEN PEDV$D
[ 6887.623694] RTAI[malloc]: unloaded.
[ 6887.720202] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6887.721121] I-pipe: head domain RTAI unregistered.
[ 6887.721172] RTAI[hal]: unmounted.
[ 7105.509429] I-pipe: head domain RTAI registered.
[ 7105.509434] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 7105.509479] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7105.509481] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 7105.509483] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7105.509486] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6226250
[ 7105.513097] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7105.513115] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7105.513117] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 7105.513119] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 7105.513120] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7105.520597] RTAI[math]: loaded.
[ 7115.709453] RTAI[math]: unloaded.
[ 7115.710252] SCHED releases registered named ALIEN PEDV$D
[ 7115.712647] RTAI[malloc]: unloaded.
[ 7115.809591] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7115.810548] I-pipe: head domain RTAI unregistered.
[ 7115.810597] RTAI[hal]: unmounted.
[ 7120.476175] I-pipe: head domain RTAI registered.
[ 7120.476179] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 7120.476223] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7120.476226] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 7120.476228] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7120.476231] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6225750
[ 7120.479740] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7120.479759] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7120.479761] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 7120.479763] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 7120.479764] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7120.485023] RTAI[math]: loaded.
[ 7120.604022] trivkins: Unknown parameter `coordinates'
[ 7120.739182] RTAI[math]: unloaded.
[ 7120.739972] SCHED releases registered named ALIEN PEDV$D
[ 7120.744290] RTAI[malloc]: unloaded.
[ 7120.843780] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7120.844621] I-pipe: head domain RTAI unregistered.
[ 7120.844673] RTAI[hal]: unmounted.
[ 7205.274797] [Hardware Error]: Machine check events logged
[ 7544.749223] I-pipe: head domain RTAI registered.
[ 7544.749226] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 7544.749268] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7544.749270] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591721000, CPU_FREQ 3591721000
[ 7544.749271] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7544.749273] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6229750
[ 7544.753026] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7544.753058] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7544.753061] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 7544.753063] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591721000 hz.
[ 7544.753064] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7544.759579] RTAI[math]: loaded.
[ 7544.779153] trivkins: Unknown parameter `coordinates'
[ 7544.928618] RTAI[math]: unloaded.
[ 7544.929499] SCHED releases registered named ALIEN PEDV$D
[ 7544.931835] RTAI[malloc]: unloaded.
[ 7545.030174] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7545.031298] I-pipe: head domain RTAI unregistered.
[ 7545.031348] RTAI[hal]: unmounted.
So I try to install it in run in place way. Then I got this error in my linuxcnc_debug and linuxcnc_print files:
Warning: Spoiler!
Can not find -sec EMC -var VERSION -num 1
5796
Stopping realtime threads
Unloading hal components
5796
Warning: Spoiler!
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/damian/linuxcnc-dev/bin
LINUXCNC_TCL_DIR=/home/damian/linuxcnc-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/damian/linuxcnc-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/damian/linuxcnc-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/damian/linuxcnc/configs/Mach3Mill/Mach3Mill.ini
VERSION=
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XYZ
EDIT:Ok so in rip installation error occurred because config was made for 2.7.14 and rip is in 2.8. So somebody have an idea why in normal installation I have problem?
Last edit: 26 Sep 2019 12:09 by zbysiek12345.
- Thank you received: 7485
26 Sep 2019 12:16 #146249
Replied by tommylight on topic Error while opening Linuxcnc
There is an incorrect symbol in the ini file before coordinates, it should be ' same as after it.
- pl7i92
- Thank you received: 358
26 Sep 2019 14:03 #146261
by pl7i92
Replied by pl7i92 on topic Error while opening Linuxcnc
at the kinetics if you go for standard XYZ you can leve the coordinates unacount
- zbysiek12345
27 Sep 2019 08:37 - 27 Sep 2019 08:42 #146351
by zbysiek12345
Replied by zbysiek12345 on topic Error while opening Linuxcnc
I was need to add my parrel port on my PCI card manually.
For others with similar problem:
lspci -v
search your parrrel port card. In my case was named "Serial controller: Device 1c00:3250"
REMEMBER adresses on I/O ports and IRQ number. I have here two adresses but only one was correct
so if in first try it won't be working try with other.
edit this file with sudo, I use vim.
sudo vi /etc/modprobe.d/alsa-base.conf
add this:
# LPC parport to PCI-E card
alias parport_low level parport_pc
options parport_pc io=0xe100 irq=16,auto
this is my config. You probably have diffrent adress and irq.
Change it with remembered one from your card.
sudo reboot
now in dev directory you should have file parport0. number depends of parrel ports you have/add.
Go to your machine config and find file "myconfig.hal" (example, I don't know how you name your canfiguration ) and find:
loadrt hal_parport cfg="0xe100 out"
"0xe100" is my card adress. write here your and save.
lspci -v
add this:
sudo reboot
Last edit: 27 Sep 2019 08:42 by zbysiek12345.
- pl7i92
27 Sep 2019 10:58 #146364
by pl7i92
you can also use a terminal to get your adress
type
dmesg | grep parpo*
respond looks like
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
type
dmesg | grep parpo*
respond looks like
Time to create page: 0.165 seconds
