#linuxcnc
  • utoto
  • utoto's Avatar Topic Author
  • Visitor
  • Visitor
27 Sep 2019 02:21 #146316 by utoto
#linuxcnc was created by utoto
Hi. I am not able to register my nickname so that I may speak on #linuxcnc. Can anyone please help? I have logged on with my primary nick, I have seen what to register with, yet, I do not know actually where to put it so that I can hit ENTER and it will work. Help?
27 Sep 2019 02:23 #146317 by bevins
Replied by bevins on topic #linuxcnc
on irc?
type in
/msg nickserv identify (your password here)
27 Sep 2019 03:25 #146322 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic #linuxcnc
What is irc?
  • utoto
  • Visitor
  • Visitor
27 Sep 2019 03:30 #146323 by utoto
Replied by utoto on topic #linuxcnc
Yes! That is exactly my point! I simply do not know where to type "/msg nickserv identify (your password here)" into. I cant stop chuckling because I think I'm totally missing something VERY obvious here.
  • utoto
  • Visitor
  • Visitor
27 Sep 2019 03:32 #146324 by utoto
I had to look it up. Apparently it means Internet Relay Chat (IRC).
27 Sep 2019 03:52 #146326 by Dinuka_Shehan
What is your client app?
  • utoto
  • Visitor
  • Visitor
27 Sep 2019 04:37 #146327 by utoto
I started with HexChat since that was what was spoken of here, I can't remember by who. But, I eventually navigated to the actual site webchat.freenode.chat where I logged on. and yet, i still cant send a message from there either!
27 Sep 2019 06:50 #146335 by pl7i92
Replied by pl7i92 on topic #linuxcnc
as you have registert from a Cliant speeking of hexchat the webchat will not work from the same Ip location
use the client so you got all nice performences
@dunkin it is a live Free Linuxcnc Helpchannel
where you can lock on from the real CNC mashie and get help right at the keypress or cnc run
  • utoto
  • Visitor
  • Visitor
27 Sep 2019 15:07 #146403 by utoto
I appreciate your response, but, have I found both situations deliver the same issue. I'd rather use the client and I'm sure will, however, neither is offering something I can see to fix the issue. It seems odd to me. Normally I'd expect to see a prompt or pop up window to add in the registration request or whatever. Yet, there just seems to be nothing. It seems illogical that if they want people to register and use this, they wouldn't make it more obvious to those that are trying. Again, perhaps I'm in the middle of a major brain fart. I can't rule that out as I have been concentrating on getting my cnc step config dialed in, which in fact caused me to look through the forum bringing the Hexchat to my notice. Argh! Thanks so much for all your responses.
  • Moderator
  • Moderator
27 Sep 2019 15:33 #146406 by tommylight
Replied by tommylight on topic #linuxcnc
after login to freenode
/msg nickserv register yourpassword youremailaddress
enter
follow the instructions
Time to create page: 0.117 seconds
