Splash code removal ***SOLVED***
- bevins
- Thank you received: 338
03 Oct 2019 23:09 #147040
by bevins
Replied by bevins on topic Splash code removal
It's the ini file regardless of hardware you are using.
If you spelled it correctly and putting it in the right place then it will work.
- Thank you received: 7468
03 Oct 2019 23:17 #147043
Replied by tommylight on topic Splash code removal
Can you try
open_file=""
I can not recall exactly what i did, but i know i did remove that.
Or just delete axis.ngc from where it is loading it.
open_file=""
- bevins
03 Oct 2019 23:26 #147047
by bevins
I add my company logo, so everytime my customers open linuxcnc, they see my logo....
03 Oct 2019 23:29 #147049
I put "cnc by toma" since i do not have a logo. Yet!
I do the same thing, that is why it baffles me it is not working for him !I add my company logo, so everytime my customers open linuxcnc, they see my logo....
The following user(s) said Thank You: Scot
- Scot
- Thank you received: 6
03 Oct 2019 23:40 #147052
by Scot
Replied by Scot on topic Splash code removal
It was missing the quotation marks. Tommy below added those. I placed it in the display section at the bottom as the last comment.
You were right. The spelling was in correct. The placement in my .ini file is odd, too. There are many comments regarding the files associated with Display.
Thanks. It worked!
Thanks. It worked!
- Scot
03 Oct 2019 23:41 #147053
by Scot
The quotations were the key. Thank you. I placed it in the bottom of the DISPLAY section.
Time to create page: 0.087 seconds
