- LinuxCNC
- General LinuxCNC Questions
- Delta A3 Servo motor + 2kw laser + mesa +Lcnc acoustic head hight control
- taloot
- Thank you received: 89
05 Oct 2019 00:54 #147148
by taloot
Delta A3 Servo motor + 2kw laser + mesa +Lcnc acoustic head hight control was created by taloot
Hello guy,
im building cnc laser machine.. its fiber laser but im facing problem for the torch high control which is acoustic in most controller
is there any interface that can handle the laser head tracking based on acoustic
- pl7i92
- Thank you received: 358
05 Oct 2019 09:34 #147173
by pl7i92
Replied by pl7i92 on topic Delta A3 Servo motor + 2kw laser + mesa +Lcnc acoustic head hight control
this will be a hell of a Power consumer
and make some real good safty around it
- taloot
06 Oct 2019 22:20 #147298
by taloot
Replied by taloot on topic Delta A3 Servo motor + 2kw laser + mesa +Lcnc acoustic head hight control
yes but im stuck on the torch height control thing
- Thank you received: 4652
09 Oct 2019 04:02 #147531
Replied by andypugh on topic Delta A3 Servo motor + 2kw laser + mesa +Lcnc acoustic head hight control
This sounds a lot like a plasma cutter THC problem, except that the feed back is from a different type of sensor.
So this sounds like a job for "external offsets"
linuxcnc.org/docs/2.8/html/motion/external-offsets.html
- taloot
09 Oct 2019 04:52 #147532
by taloot
but the problem now is the capacitive torch height controller polling rate
similar to plasma yes
13 Oct 2019 01:05 #147768
If the feedback is slow then you will need a soft-tuned PID, but it still ought to work.
- LinuxCNC
Time to create page: 0.243 seconds
