parport 2 limit switches setup
  • utoto
  • utoto's Avatar Topic Author
  • Visitor
  • Visitor
07 Oct 2019 04:29 #147310 by utoto
parport 2 limit switches setup was created by utoto
Hello all,
I have my 2nd parport installed via pcie card. Lcnc allows me to select 2 parports in stepconfig, but, I cant seem to test it?
Has anyone setup this?
07 Oct 2019 07:17 #147312 by pl7i92
Replied by pl7i92 on topic parport 2 limit switches setup
hi
what version of Linuxcnc are you using
the stepconf wizard does support 2 parports
why are you using 2 parports
you may need to config the files by hand as you got more then 4 axis/joints
we need more infos on your system
  • utoto
  • Visitor
  • Visitor
08 Oct 2019 02:59 #147413 by utoto
Replied by utoto on topic parport 2 limit switches setup
2nd gen optiplex gx620
debian wheezy
2.7.4 lcnc
3 axis
2nd and 3rd parallel ports via pcie (only 2nd used)
using 2nd parport for 3 homing XYZ switches, 5 machine limit switches XMin-Max,YMin-Max,ZMax, probe, etc
08 Oct 2019 13:11 #147461 by Todd Zuercher
Replied by Todd Zuercher on topic parport 2 limit switches setup
Have you been able to identify the addresses used by your parallel port card?
  • utoto
  • Visitor
  • Visitor
09 Oct 2019 02:47 #147525 by utoto
yes
0 onboard = 0x378
1 pcie card = 0xdcc8
2 pcie card ribbon cable = 0xdcd8
Time to create page: 0.111 seconds
