- Thank you received: 27
That is all good, but how did you get Z to go up to positive 208mm ? I do not see any offsets active in that screenshot.JetForMe wrote:
In gcode you have 15mm, in the screenshot it is at 208mm ? How ? Why ?
Do you have a G21 at the top of gcode ?
Yeah, I've attached the program. The Z15 is in G54, which has z=0 set to the top of work.
tommylight wrote: That is all good, but how did you get Z to go up to positive 208mm ? I do not see any offsets active in that screenshot.
