5 axis router LinuxCNC setup
7 years 3 weeks ago #147553 by Wireline
Hi
I am looking into building a 5 axis router setup using linuxcnc similar to this in geometry:
image missing https://www.shopbottools.com/img/product/5axis/5axis09.jpg
Please can you advise how straightforward it would be to set up with LCNC, which kinematics modules can be used, if there are ready-to-go config files (or just a simple case of running the wizard?).
We intend to use BLDC drives such as this one
www.maxongroup.co.uk/medias/sys_master/r...102046/19-EN-275.pdf
Is it feasible to use the BLDC HAL component? We are currently assessing driver boards and looking at the STMBL + Mesa as well as Maxon and other commercial offerings.
Are there any particular issues to be aware of with a 5 axis router and LCNC?
Many thanks
7 years 3 weeks ago #147562 by lisandromassera
I've built one myself, and you have to take a lot of care with the dimensions and squareness of the head, most dimensions are quite critical.
I would say you are quite low on the rotary axis torque. You will need a lot of reduction. Depends on the tool length and the material you will be cutting, but for cutting 6mm HIPS at a tool length of 200mm my setup has a max 30Nm.
Also consider that a low backlash reduction is very important.
7 years 2 weeks ago #148186 by andypugh
There is a very similar geometry available as one of the LinuxCNC Vismach demos:
sim/axis/vismach/5axis/bridgemill
That demo uses a moving gantry, and it looks like you are considering a moving table, but the two configs are kinematically identical.
Time to create page: 0.739 seconds
