TB6600 and HBS57H differential mode?
  • Moderator
  • Moderator
16 Oct 2019 17:52 #148022 by tommylight
Replied by tommylight on topic TB6600 and DM542A differential mode? Resumee
Thanks for all the great input. For other readers and to be sure I got all points the results of this discussion are:
Does the TB6600/ DM542A support differential mode?:
  • No, a differential receiver is pretty expensive to build. Having seperated grounds has nothing to do with differential mode
  • They use standard optocouplers without a shared ground enabling two directional input
Differential mode will work for that, for sure.
How to correctly connect the TB6600/ DM542A?:
  • The correct mode is to connect either 5V constant and pulse- /dir- /enable- or use a common ground and pulse+...
That will work
  • Connecting pulse+/pulse- e.g. is possible but not really advantageuos since it might run optocouplers out of spec, raise energy consumption (and by this noise emission)
  • True, but it will also work properly as they do have resistors before optocouplers to limit that.
    Correct?
    See in RED
    16 Oct 2019 18:44 - 16 Oct 2019 18:48 #148035 by PCW
    Actually there is some benefit in driving Optocoupler LEDs with differential
    signals, they are not the best differential receivers since they typically have a
    threshold of 2-3V with typical input resistors and current thresholds vs
    ~200 mv for a good RS-422 receiver but you do improve the off state noise
    immunity by a couple of volts.
    That said most cheap Chinese drives to not have reverse protection diode across
    the Optocoupler LED so you do apply -5V across the LED. This is typically right
    at the LED reverse voltage limit of Optocoupler specs so for cheap step drives its
    probably not the best idea to use differential signals.
    (its actually a bad idea to have no reverse protection diode since LED reverse breakdown
    typically occurs at a relatively high voltage making them quite susceptible to static damage)
    Last edit: 16 Oct 2019 18:48 by PCW. Reason: clarify
    17 Oct 2019 00:31 #148066 by rollfree
    Replied by rollfree on topic TB6600 and DM542A differential mode? Resumee
    Correct?
    Yes.
    17 Oct 2019 09:28 - 17 Oct 2019 15:49 #148101 by Louis Cypher
    Replied by Louis Cypher on topic TB6600 and DM542A differential mode? Resumee
    Very good point. One could easily apply one I'd assume being a complete layman (mechanical engineer), right? If yes, any recommendations?
    Last edit: 17 Oct 2019 15:49 by Louis Cypher.
    17 Oct 2019 19:33 #148147 by rollfree
    Recommendation: do not use differential transmission, so there is no danger of reverse voltage.
    If you still have to use differential transmission, buy the cheapest diode (for example 1n4148) or similar in TH or SMD, and solder it directly to the optron legs in the driver.
    No problem and (almost) no money.
    05 Apr 2022 16:16 - 05 Apr 2022 18:49 #239355 by garrettmin
    Replied by garrettmin on topic TB6600 and HBS57H differential mode?
    Motors not Turning & Idle HOT..
    Test with LED
    Wiring Stepper Mode of Common Anode,Cathode or Differential?
    Wiring Enable?
    Driver Firmware Lock Enabled?
    EMC2 Firmware Not Enabling?
    Leadshine HBS57H documentation yes support Differential Mode
    TB6600 documentation no support for Differntial Mode
    7i76 Does Light Up LED in sequence with G-Code @ Step-+ Dir-+
    HM2 doe not have any settings for the different Common Anode, Cathode, Differential wiring schemes. We presume it is automatic or inherent in the design.
    LED TEST:
    LED Testing was the BIG Winner for the Novice.
    More often than not, Cheap Wiring & Connections have proven to be the Failure in LED Testing.
    LED VERIFICATION:
    install small LED at every connector Signal to visually verify your wiring is all working correctly.
    The problem was "Cheap Security Wire 24GA / 26GA" & Faulty Connections.
    TB6600 in Common Cathode with Good Wiring resulted Motors Turning !
    Congradulations, My first Turning Motor...
    A TB6600 with an N17 on a 7i92 7i76 with EMC2!
    Last edit: 05 Apr 2022 18:49 by garrettmin.
    07 Apr 2022 21:52 #239597 by andypugh
    Replied by andypugh on topic TB6600 and HBS57H differential mode?
    Stepper motors run hottest when not turning. (the opposite of servos)
    Time to create page: 0.172 seconds
