Very basic questions
09 Nov 2019 09:23 #149972 by UKenGB
Replied by UKenGB on topic Very basic questions
Could I then control several separate machines (each with their own breakout box) by manually switching the parallel port between the breakout boxes and selecting the appropriate LinuxCNC config?
I'm just thinking that this would enable me to control several different relatively simple machines like 3D printer, vinyl cutter (not Bridgeport or lathe) from a PC I have with an EPP capable parallel port, but no spare PCI slots.
09 Nov 2019 10:39 #149975 by pl7i92
Replied by pl7i92 on topic Very basic questions
you can do this but not at the same time
i guess you woudt like to run more then one mashine at the same PC at the same time
that is not posible at a realtime aplication
if it is a 3AXIS eatch
you can run both together using XYZ to the first and UVW to the second
using 2 parport so one for eatch mashine
they then run on the same G-code file to different direction
Wehred but posible
09 Nov 2019 10:56 #149976 by Leon82
Replied by Leon82 on topic Very basic questions
You may want to look at the raspberry pi4 thread. It would give you inexpensive CPUs but would require Ethernet cards. I'm not sure if they have it fully working
You could probably find workable PC's at a salvage center, pop in a cheap ssd
09 Nov 2019 11:26 #149977 by andypugh
Replied by andypugh on topic Very basic questions
If you mean swapping cables at the DB25, then certainly.
If you mean using a multi-port printer switch, then possibly. That would depend if the printer switch swaps all connections or just the minimum. www.ebay.co.uk/itm/143342514775 is an example of what I mean.
09 Nov 2019 11:45 #149979 by UKenGB
I was thinking of a 25 way switch, with all contacts switched. I think I have one.
I have 2 spare PCs and figuring out how I can best utilise them for different projects that I have in mind. I certainly don't intend buying another PC.
Thank you for all your help. I've got most of it pretty clear in my mind now.
Time to create page: 0.081 seconds
