issue with "home all" after power failure
- jamby
- Thank you received: 6
01 Nov 2019 18:01 #149379
by jamby
issue with "home all" after power failure was created by jamby
Hi
I have a bridgeport clone milling machine and after a power failure it has been reporting "axis beyond soft limits when trying to home all. Another problem is I have an auxiliary head mounted to the Zaxis spindle and a second lower limit switch that works with the axu-head.
Is there a way to manually home each axis separately even with the home definition it the .ini file?
Jim
Jim
- Thank you received: 1472
01 Nov 2019 18:28 - 01 Nov 2019 19:53 #149382
Replied by Todd Zuercher on topic issue with "home all" after power failure
Yes each axis can be homed independently. Check the Machine pull down menu in Axis.
Your other problem may be a corrupted .var file.
Last edit: 01 Nov 2019 19:53 by Todd Zuercher.
- jamby
01 Nov 2019 19:29 #149385
by jamby
Replied by jamby on topic issue with "home all" after power failure
Thanks Todd
Time to create page: 0.071 seconds
