I Need help for 4 axis cnc
- Endless
09 Nov 2019 14:49 - 09 Nov 2019 14:50 #149988
by Endless
I Need help for 4 axis cnc was created by Endless
I'm a new member of the forum I want to say hello to everyone
I discovered linux cnc while doing research. but I have little knowledge
I will be glad if you help me...
i.hizliresim.com/dLr9jD.jpg
i.hizliresim.com/qA0zqd.jpg
i.hizliresim.com/5N0j9z.jpg
I have designed such a cnc ... and in addition it has a 360 degree rotating axis.
there is a double-sided drill at the end of this axis.Drill of different diameter on 2 sides.(8 mm on one side and 10 mm on the other side) I will use it to drill the edges of the mdf.I should also note that up and down movement of this axis will be provided pneumatically
how do I configure this machine in linux cnc?
some people said post process needs to be written.Do you really need it?
I would appreciate it if you tell me where to start and what to do about it
Thank you in advance for your interest and help
Last edit: 09 Nov 2019 14:50 by Endless.
- Thank you received: 7468
09 Nov 2019 16:07 #149991
Replied by tommylight on topic I Need help for 4 axis cnc
Merhaba abey,
First you have to make the machine work as you need it to, then deal with post processing .
Did you build the machine or not yet ?
The following user(s) said Thank You: Endless
- Endless
09 Nov 2019 16:24 #149992
by Endless
Replied by Endless on topic I Need help for 4 axis cnc
I started to produce CNC. I think it'il be over in 10 days. but I don't know if I can succeed the software
09 Nov 2019 17:17 #149994
You are in Turkey, are you aware that you can buy ready made frames with linear rails, ready to be fitted with motors and electronics ?
doguskalip.com.tr/Product/l-cnc--kr1--kr2--kr3-kr4/1187
- pl7i92
- Thank you received: 358
09 Nov 2019 17:29 #149995
by pl7i92
Replied by pl7i92 on topic I Need help for 4 axis cnc
hi welcome
i got some 4th axis running on linuxcnc and it is a realy nice mashine setup
no problem to do XYZA or XYZb or even XYZC
- Endless
09 Nov 2019 21:17 #150014
by Endless
yes I know but the cost is too much. I do not have much money. Did you find a problem with my design?
- Endless
09 Nov 2019 21:20 #150015
by Endless
yes I know it can be done with linux cnc but I don't know how to do it
hi welcome
09 Nov 2019 21:46 #150017
I would set the gantry a bit lower as it would be more rigid, but maybe you need all that space below.
No, it looks OK.yes I know but the cost is too much. I do not have much money. Did you find a problem with my design?
- Endless
09 Nov 2019 22:02 #150021
by Endless
I originally designed it with a 5 axis head. so the bridge was high I could drop it a little more. The cnc dimension is 2750 mm x 1500 mm x 750 mm. What is the ideal ideal bridge height? What badly affects the high bridge?
09 Nov 2019 23:27 #150030
Well if you go that high, you have to set the carriages much wider, and strengthen the sides that carry the gantry.
