I Need help for 4 axis cnc
6 years 11 months ago #150015 by Endless
Replied by Endless on topic I Need help for 4 axis cnc
pl7i92 wrote: hi welcome
i got some 4th axis running on linuxcnc and it is a realy nice mashine setup
no problem to do XYZA or XYZb or even XYZC
yes I know it can be done with linux cnc but I don't know how to do it
6 years 11 months ago #150017 by tommylight
Endless wrote: yes I know but the cost is too much. I do not have much money. Did you find a problem with my design?
No, it looks OK.
I would set the gantry a bit lower as it would be more rigid, but maybe you need all that space below.
6 years 11 months ago #150021 by Endless
No, it looks OK.
I originally designed it with a 5 axis head. so the bridge was high I could drop it a little more. The cnc dimension is 2750 mm x 1500 mm x 750 mm. What is the ideal ideal bridge height? What badly affects the high bridge?
6 years 11 months ago #150030 by tommylight
Well if you go that high, you have to set the carriages much wider, and strengthen the sides that carry the gantry.
6 years 11 months ago #150035 by Endless
tommylight wrote: Well if you go that high, you have to set the carriages much wider, and strengthen the sides that carry the gantry.
I used this carriages
25 and large
www.sahinrulman.com/lineer-ray-araba-shn...r-ray-araba-shn-25-a
6 years 11 months ago #150036 by tommylight
Time to create page: 0.057 seconds
