Setup a Logging file for LinuxCNC
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
18 Nov 2019 12:31 #150576 by Diederik
Setup a Logging file for LinuxCNC was created by Diederik
Hello, please could someone assist us to setup a configuration that logs all errors within LinuxCNC only.
We need date and time and details of the error that occurred. Such as the Smart serial card errors, joint 1 on limit switch error.
Thank you,
18 Nov 2019 13:28 #150578 by rodw
Replied by rodw on topic Setup a Logging file for LinuxCNC
Easiest way is to start linuxcnc from the command line and erorrs are logged to the terminal window. Perhaps linuxcnc > mylog.txt might work..
18 Nov 2019 18:04 #150590 by pl7i92
Replied by pl7i92 on topic Setup a Logging file for LinuxCNC
Smart serial card errors are only if the 5v isent correct hook up a thick 2000uA Elko and you are fine on that
joint1 limit swich is a EMI detatct so is the cable grounded to this switch is the E-chain grounded if it is a Metall Plastic one
  • Moderator
  • Moderator
18 Nov 2019 23:52 #150601 by tommylight
Replied by tommylight on topic Setup a Logging file for LinuxCNC
That should be 2000uF, i think.
Time to create page: 0.210 seconds
