Spindle control
- Dinuka_Shehan
- Thank you received: 26
21 Nov 2019 16:29 - 21 Nov 2019 19:18 #150843
by Dinuka_Shehan
Spindle control was created by Dinuka_Shehan
I wiring my bob like this.
Pin 17 use as spindle output then connect pin 17 to common pin of 5v bob relay.5v relay switch on another 5v external relay module.
external relay module switch the 3 phase motor contactor coil.
Pin 17>bob 5v relay com>ex 5v relay module+DC>contactor coil
After that I think it will work fine.i wired like this but not yet powered the bob.
I have a doubt in mind will it work or not?
Please help.
Please help.
Last edit: 21 Nov 2019 19:18 by Dinuka_Shehan.
- pl7i92
- Thank you received: 358
22 Nov 2019 16:25 #150941
by pl7i92
Replied by pl7i92 on topic Spindle control
as yu use externel raly in a row
why you will be fine
a 3phase spindel over a relay is not the best idee it gets heavy egnishen at start
why arent you using a cheep VFD at 50USD
then you got full control
The following user(s) said Thank You: Leon82
- Dinuka_Shehan
23 Nov 2019 03:40 - 23 Nov 2019 03:42 #151007
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Spindle control
I haven't got any vfd right now.
Contactor Coil voltage is 230v and it is a little coil.want low milli amperes.
If you have a vfd for 40 euros please tell me.
Last edit: 23 Nov 2019 03:42 by Dinuka_Shehan.
- Dinuka_Shehan
23 Nov 2019 03:44 #151008
by Dinuka_Shehan
I already watched your YouTube video.
So if i watch again not increase your view count.
Sorry
Sorry
- pl7i92
23 Nov 2019 09:04 #151020
by pl7i92
no need to watch
Calculate the Starting elKo very precise for relay start
- Dinuka_Shehan
23 Nov 2019 16:18 #151057
by Dinuka_Shehan
Elko?
What it is;never heard before?
- Dinuka_Shehan
23 Nov 2019 16:19 - 23 Nov 2019 16:21 #151058
by Dinuka_Shehan
Last edit: 23 Nov 2019 16:21 by Dinuka_Shehan.
- Dinuka_Shehan
23 Nov 2019 16:20 #151060
by Dinuka_Shehan
no need to watch
Just joking
- Thank you received: 7488
23 Nov 2019 17:32 #151070
Replied by tommylight on topic Spindle control
Elko = electrolytic capacitorElko?
- Dinuka_Shehan
23 Nov 2019 19:18 #151077
by Dinuka_Shehan
Can you explain further more please
I have no idea what you are saying?
