Install linuxcnc on my Pi3B+
- CCimer001
23 Nov 2019 16:02 #151054
by CCimer001
Install linuxcnc on my Pi3B+ was created by CCimer001
I would like to run Linuxcnc on my Pi3B+. But did not succed the installation. Tried to install with usb key, but didnot get anywhere.
I bought a micro SD card, but how can i load the install files on it in proper order?
I'm not a Pi specialist, neither Linux. More a workshop man!
Actually my Pi runs with Rasbian, having used the joined NOOBS to launch it.
However I find nowhere any mention of Rasbian running with linuxcnc.
Is there anywhere a description on how to install Linuxcnc on my Pi?
Thanks in advance for your response
Martin
Martin
The following user(s) said Thank You: Todd Zuercher
- scotta
- Thank you received: 489
24 Nov 2019 00:08 #151086
by scotta
Replied by scotta on topic Install linuxcnc on my Pi3B+
I'm running LinuxCNC on several RPi's but with an external board for real time step generation.
Check out my instructions.
scottalford75.github.io/LinuxCNC-on-RPi/
Regards
Scott
Regards
Scott
- Thank you received: 4652
25 Nov 2019 14:22 #151221
Replied by andypugh on topic Install linuxcnc on my Pi3B+
A good starting point would be one of the pre-made realtime (preempt-rt) SD car images from RealtimePi.
github.com/guysoft/RealtimePi
