Vibrations in circular interpolation
  • Moderator
  • Moderator
04 Dec 2019 14:34 #151999 by tommylight
Replied by tommylight on topic Vibrations in circular interpolation
@Jools,
Not the same thing, you have resonance from motors, he has chatter from something loose only on one side of the XY plane.
  • Samu_97
  • Samu_97's Avatar Topic Author
  • New Member
  • New Member
08 Dec 2019 22:26 #152342 by Samu_97
Replied by Samu_97 on topic Vibrations in circular interpolation
Goodnight.
I could only check to machine different arches, and surprise, the vibration disappears when the radius is greater than about 40mm.
The vibration disappears completely if I use an tool less than 8mm, although it use the same depth and lateral pass.
That makes me think that perhaps the step between teeth of the larger tool induces vibration (or also that they force the machine too much)
Soon I will try to machine at different points of the table and cut an internal diameter, I not have time yet.
Responding to the user Jools, I tell you that was my first suspicion.
I had the same problem, the vibration was also produced machining in the air. The solution was to introduce greater freedom of tolerance to movements, with a G64 in my code G. (if anyone knows how to do this by default in linuxcnc I appreciate it)
Now only the vibration appears during machining and in the quadrant of which we are speaking.
My question regarding the resonance you comment is, this harmonic vibration should disappear or move from that band of rpm if I do a higher microstepping and consequently the motors induce a lower vibration. I'm right? It was the first thing I tried and the result was identical. I do not know.
Thanks.
08 Dec 2019 22:39 - 08 Dec 2019 22:41 #152344 by Leon82
Replied by Leon82 on topic Vibrations in circular interpolation
You can put the g64p value in your preamble or set it to post out on every program.
Size of the cutter can effect radial chip thinning. Also bigger cutters require more horsepower and rigidity
Last edit: 08 Dec 2019 22:41 by Leon82.
12 Dec 2019 21:28 #152554 by jools
Replied by jools on topic Vibrations in circular interpolation
Mine only produce it at low rpm's. For me it's in the 400-700mm a minute region. The problem with arcs and circles is that at some point one axis is at low speed when the other is at high round the points of the arc so you can't power through it as such.
I had backlash on my x axis so I'm double ball nutting that one to remove it, it was quite bad so hopefully this will sort it.
Once the mechanicals are done I'm going to tune the PID loop in the hybrid stepper motor driver system. Mine are from leadshine so have this ability. If your's do then maybe this is an area to look at.
For me vibration only occurs on the Y axis. As mine is a gantry this axis moves the X and Z axis too so pushes the most weight. The Y axis has the same motor and that is perfect.
Jools
  • Samu_97
  • New Member
  • New Member
16 Jan 2020 22:54 #155036 by Samu_97
Good evening, sorry for the delay, you know they are complicated dates.
After performing all the tests that you have proposed to me, the result has been the same in all: vibration in the same quadrant.
I have searched with a gauge for possible gaps, in each guide block, forcing them and the results are correct.
So I decided to mount my spindle bearings with more tightly. The problem continues and this will end my personal health ...
I don't want to bother you anymore, you've already helped me a lot. I'm almost ruling out it's a mechanical problem. Maybe it is resonance. Any ideas with any software configuration that I can try to see if it improves?
Thank you all.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
17 Jan 2020 00:55 #155040 by Todd Zuercher
Replied by Todd Zuercher on topic Vibrations in circular interpolation
Grasping at straws now. Are you using a Mesa card? What does the latency look like?
17 Jan 2020 02:17 #155043 by Leon82
Google spies on me and others as you know so this popped up in my chrome browser
hackaday.com/2020/01/16/analyzing-cnc-to...atter-with-audacity/
The following user(s) said Thank You: Mike_Eitel
Time to create page: 0.221 seconds
