7i92 and 7i76 DB25 ribbon cable
- bevins
- Thank you received: 338
25 Nov 2019 19:27 #151245
by bevins
7i92 and 7i76 DB25 ribbon cable was created by bevins
I ordered some mesa boards but forgot to order the ribbon cable to go between the 7i92 and 7i76. I know the cable between a 5i25 and 7i77/6 are critical but am just wondering if this is the case with the 7i92 also?
I was thinking about getting two DB25 and make my own cable about a foot long. Any issues I should watch out for?
I have a router retrofit this weekend and I need to do something.
- Thank you received: 1472
25 Nov 2019 19:34 #151246
Replied by Todd Zuercher on topic 7i92 and 7i76 DB25 ribbon cable
They are not anything special, If you have a pile of old junk computers you may even already have a few.
As cheap as something like this is, why bother making them.
www.ebay.com/p/1845903256?iid=2332175054...SEAkYAiABEgKiRvD_BwE
- Thank you received: 5321
25 Nov 2019 20:57 #151249
Replied by PCW on topic 7i92 and 7i76 DB25 ribbon cable
You need a DB25M --> IDC26 cable
these are a bit less common than the DB25F-IDC cables used for parallel
port expansion shown above.
We use
AMP 1658613-2 (Male 25 pin IDC) and AMP 1658621-6 26 pin IDC header
DB25 Pin1 --> IDC26 Pin 1 (wire 26 cut at DB25 end)
We use
25 Nov 2019 21:41 #151251
oops soory, I forgot to think about gender.
25 Nov 2019 21:46 #151252
They are available just not as common:
www.ebay.com/itm/DB25-Male-to-26-Pin-2x1...4:g:makAAOSwZqZaLekO
- bevins
25 Nov 2019 22:18 #151254
by bevins
Replied by bevins on topic 7i92 and 7i76 DB25 ribbon cable
Or I can just plug the 7i92 directly in the db25 of the 7i76.
25 Nov 2019 22:20 #151255
If you have a 7I92M you can
Time to create page: 0.325 seconds
