7i92M default IP
- bevins
- Thank you received: 338
30 Nov 2019 14:30 #151568
by bevins
7i92M default IP was created by bevins
THe manual says it is 192.168.1.121, but the last time I got one it was 10.0.0.1.
So what is the default IP for a 7i92M? I cant talk to either...... so thats another story, but I need to know what they are shipped with.
- Thank you received: 7468
30 Nov 2019 14:43 #151570
Replied by tommylight on topic 7i92M default IP
Normally with 192.168.1.121.
There is a jumper for setting it to 10.10.10.10, and i always set them at that.
The following user(s) said Thank You: bevins
- bevins
30 Nov 2019 14:52 #151573
by bevins
Replied by bevins on topic 7i92M default IP
I got it to where I can ping it.
I am having an with my install.
I installed with debs I built. I got 2.9 running but it doesnt include mesaflash. sudo apt-get install mesaflash doesnt find it.
Can I install mesaflash another way?
- bevins
30 Nov 2019 15:08 #151574
by bevins
Should I have installed the linuxcnc-uspace-dev_2.9.0-pre0_amd64.deb?
Does that contain mesaflash?
- Thank you received: 5321
30 Nov 2019 15:17 #151576
Replied by PCW on topic 7i92M default IP
- bevins
30 Nov 2019 15:29 - 30 Nov 2019 15:32 #151577
by bevins
Yeah, I got it from github and it seems to have the correct firmware.
But I cant get it to load.
hm2_eth: ERROR: 102.168.1.121: Could not retrieve mac address
I can ping it and mesaflash talks to it.
This is straight from pncconf,
Error file:
github.com/jethornton/mesaflash
( install instructions on bottom of page )
Warning: Spoiler!
# Generated by PNCconf at Sat Nov 30 09:20:28 2019
# Using LinuxCNC version: UNAVAILABLE
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="102.168.1.121" config=" num_encoders=2 num_pwmgens=0 num_stepgens=10 sserial_port_0=0000xx"
setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i92.0.write servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.stepgen.timer-number 1
# external output signals
# external input signals
# --- BOTH-X ---
net both-x <= hm2_7i92.0.7i76.0.0.input-01
# --- BOTH-Y ---
net both-y <= hm2_7i92.0.7i76.0.0.input-02
# --- BOTH-Z ---
net both-z <= hm2_7i92.0.7i76.0.0.input-03
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp hm2_7i92.0.stepgen.05.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i92.0.stepgen.05.dirhold [JOINT_0]DIRHOLD
setp hm2_7i92.0.stepgen.05.steplen [JOINT_0]STEPLEN
setp hm2_7i92.0.stepgen.05.stepspace [JOINT_0]STEPSPACE
setp hm2_7i92.0.stepgen.05.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i92.0.stepgen.05.step_type 0
setp hm2_7i92.0.stepgen.05.control-type 1
setp hm2_7i92.0.stepgen.05.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.05.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_7i92.0.stepgen.05.velocity-cmd
net x-pos-fb <= hm2_7i92.0.stepgen.05.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i92.0.stepgen.05.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net both-x => joint.0.neg-lim-sw-in
net both-x => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp hm2_7i92.0.stepgen.06.dirsetup [JOINT_1]DIRSETUP
setp hm2_7i92.0.stepgen.06.dirhold [JOINT_1]DIRHOLD
setp hm2_7i92.0.stepgen.06.steplen [JOINT_1]STEPLEN
setp hm2_7i92.0.stepgen.06.stepspace [JOINT_1]STEPSPACE
setp hm2_7i92.0.stepgen.06.position-scale [JOINT_1]STEP_SCALE
setp hm2_7i92.0.stepgen.06.step_type 0
setp hm2_7i92.0.stepgen.06.control-type 1
setp hm2_7i92.0.stepgen.06.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.06.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output <= hm2_7i92.0.stepgen.06.velocity-cmd
net y-pos-fb <= hm2_7i92.0.stepgen.06.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => hm2_7i92.0.stepgen.06.enable
net y-home-sw => joint.1.home-sw-in
net both-y => joint.1.neg-lim-sw-in
net both-y => joint.1.pos-lim-sw-in
# AXIS Z JOINT 2
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp hm2_7i92.0.stepgen.07.dirsetup [JOINT_2]DIRSETUP
setp hm2_7i92.0.stepgen.07.dirhold [JOINT_2]DIRHOLD
setp hm2_7i92.0.stepgen.07.steplen [JOINT_2]STEPLEN
setp hm2_7i92.0.stepgen.07.stepspace [JOINT_2]STEPSPACE
setp hm2_7i92.0.stepgen.07.position-scale [JOINT_2]STEP_SCALE
setp hm2_7i92.0.stepgen.07.step_type 0
setp hm2_7i92.0.stepgen.07.control-type 1
setp hm2_7i92.0.stepgen.07.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.07.maxvel [JOINT_2]STEPGEN_MAXVEL
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-vel-cmd <= joint.2.vel-cmd
net z-output <= hm2_7i92.0.stepgen.07.velocity-cmd
net z-pos-fb <= hm2_7i92.0.stepgen.07.position-fb
net z-pos-fb => joint.2.motor-pos-fb
net z-enable <= joint.2.amp-enable-out
net z-enable => hm2_7i92.0.stepgen.07.enable
net z-home-sw => joint.2.home-sw-in
net both-z => joint.2.neg-lim-sw-in
net both-z => joint.2.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-preparedError file:
Warning: Spoiler!
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/fab1/linuxcnc/configs/AXYZ-1'
Machine configuration file is 'AXYZ-1.ini'
INIFILE=/home/fab1/linuxcnc/configs/AXYZ-1/AXYZ-1.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./AXYZ-1.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./AXYZ-1.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./AXYZ-1.hal:9: /usr/bin/rtapi_app exited without becoming ready
./AXYZ-1.hal:9: insmod for hm2_eth failed, returned -1
7512
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Sat Nov 30 10:26:37 EST 2019
UTC Date: Sat Nov 30 15:26:37 UTC 2019
this program: /usr/bin/linuxcnc_info
uptime: 10:26:37 up 1:18, 1 user, load average: 0.58, 0.50, 0.43
lsb_release -sa: LinuxMint Linux Mint 18.3 Sylvia 18.3 sylvia
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/fab1/linuxcnc/configs/AXYZ-1
USER: fab1
LOGNAME: fab1
HOME: /home/fab1
EDITOR:
VISUAL:
LANGUAGE: en_US
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1600x900 pixels (423x238 millimeters)
PATH: /usr/bin:/home/fab1/linuxcnc/configs/AXYZ-1/bin:/usr/bin:/home/fab1/bin:/home/fab1/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
uname items:
nodename -n: AXYZ-1
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Thu Nov 28 17:03:52 EST 2019
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.1-rt3 root=UUID=79161947-d3cb-4f61-a46c-161602296caa ro quiet splash vt.handoff=7
model name: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
cores: 4
cpu MHz: 1838.956
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 5.4.0-6ubuntu1~16.04.12) 5.4.0 20160609
python: Python 2.7.12
git: git version 2.7.4
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.9.0~pre0 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.0~pre0 amd64 motion controller for CNC machines and robots
Last edit: 30 Nov 2019 15:32 by bevins.
30 Nov 2019 15:31 #151578
you have a typo in the ip address (should be 192.168.1.121)
- bevins
30 Nov 2019 15:33 - 30 Nov 2019 15:46 #151579
by bevins
ME <== SLAP
Thanks for pointing out the obvious.... It's working....
ME <== SLAP
Last edit: 30 Nov 2019 15:46 by bevins.
- Mike29
03 Jan 2020 19:13 #153918
by Mike29
Replied by Mike29 on topic 7i92M default IP
sorry to jump into the middle of this but I am trying to get a 7i92M to work with RasPi 4. I can ping 10.10.10.11 but cannot get mesa flash to install following the the instructions listed at github.com/jethornton/mesaflash. I'm able to see the files in the directory but this is the received error make: *** [Makefile:70: mesaflash] Error 1 any help is appreciated.
03 Jan 2020 21:20 #153927
Can you copy-paste a directory listing, your command, and all messages from make?
I have built mesaflash from JETs github source on a RPI3 but i had built LinuxCNC from source on that system so all the tools were there
Time to create page: 0.162 seconds
