7i92M default IP
- Mike29
- Thank you received: 3
04 Jan 2020 00:23 #153937
by Mike29
Replied by Mike29 on topic 7i92M default IP
Thank you for taking a look at this. I'm not familiar enough with Raspian to know if this is incorrect directory or just using the wrong command.
pi@cnc:~/mesaflash/mesaflash $ ls
anyio.c eeprom_remote.c hostmot2.o pci_encoder_read.o
anyio.h eeprom_remote.h lbp16.c serial_boards.c
anyio.o eeprom_remote.o lbp16.h serial_boards.h
bitfile.c encoder_module.c lbp16.o serial_boards.o
bitfile.h encoder_module.h lbp.c spi_boards.c
bitfile.o encoder_module.o lbp.h spi_boards.h
boards.h epp_boards.c lbp.o spi_boards.o
common.c epp_boards.h libanyio.a sserial_module.c
common.h epp_boards.o libpci.dll sserial_module.h
common.o eth_boards.c Makefile sserial_module.o
eeprom.c eth_boards.h mesaflash.c types.h
eeprom.h eth_boards.o mesaflash.o usb_boards.c
eeprom_local.c examples pci_analog_write.o usb_boards.h
eeprom_local.h hostmot2.c pci_boards.c usb_boards.o
eeprom_local.o hostmot2_def.h pci_boards.h WinIo32.dll
eeprom.o hostmot2.h pci_boards.o WinIo32.sys
pi@cnc:~/mesaflash/mesaflash $ sudo ./Makefile
./Makefile: 20: ./Makefile: TARGET: not found
./Makefile: 21: ./Makefile: LIBNAME: not found
./Makefile: 22: ./Makefile: LIBNAME: not found
./Makefile: 22: ./Makefile: LIBANYIO: not found
./Makefile: 24: ./Makefile: CC: not found
./Makefile: 25: ./Makefile: RM: not found
./Makefile: 26: ./Makefile: AR: not found
./Makefile: 27: ./Makefile: RANLIB: not found
./Makefile: 28: ./Makefile: MATHLIB: not found
./Makefile: 29: ./Makefile: OPT: not found
./Makefile: 33: ./Makefile: DEBUG: not found
./Makefile: 35: ./Makefile: Syntax error: word unexpected (expecting ")")
- Thank you received: 5321
04 Jan 2020 00:26 - 04 Jan 2020 00:53 #153938
Replied by PCW on topic 7i92M default IP
Typically you would just type "make" to compile mesaflash (or other simple programs)
(Makefiles are not executable)
perhaps followed by
sudo make install
If you succeed in the first step
perhaps followed by
sudo make install
Last edit: 04 Jan 2020 00:53 by PCW.
- Thank you received: 7468
05 Jan 2020 08:52 - 05 Jan 2020 08:53 #154081
Replied by tommylight on topic 7i92M default IP
10.10.10.11 should be your PC or RPI.
Mesa is 10.10.10.10
Never mind, to late.
Mesa is 10.10.10.10
Last edit: 05 Jan 2020 08:53 by tommylight. Reason: more info
Time to create page: 0.098 seconds
