Is there a way to avoid resetting of gcode line number on switching to auto mode
01 Dec 2019 05:53 #151631 by Reinhard
I succeeded in implementing step from line command with a fake command sequence.
Now I realized, that on stop the taskmode changes to manual. When I switch back to auto mode, the line number from gcode is resetted to 0.
That is pretty poor.
For example: when I have to change inserts of a cutting head on a long running 3D-Operation, I need to jog from current cutpath to a position, where the tool can be removed.
After changing the inserts I like to continue the interupted task.
But ...
run from line is the only nml-command, where a line number can be transmitted.
I tried to exec run from line without movement in combination of taskabort, but it was not possible to restore line number.
Is there a configuration option or something similar I can use to avoid resetting of gcode line numer (motion line)?
01 Dec 2019 09:24 #151643 by cmorley
IFAIK there is no way to stop reset of line current number.
You don't mention what screen you use - some are easier to customize then others.
The trick would be to record the current line before aborting.
Linuxcnc's behavior for restarting a program leaves much to be desired - but its a difficult problem to fix.
01 Dec 2019 11:52 #151651 by Reinhard
Hi Chris,
Oh, sad to read that.
Hm, do you remember, that I'm working on an complete UI-app with java language? I have completed base functionality and I'm working on minor issues already.
But ...
... my UI-app is just a NML-interface without own intelligence, which means, it shows, what can be read from shared memory and writes commands as NML-messages. Command-response is read from shared memory. No planned way to break that rule.
The only intelligence of my UI-App is the tool-manager, which could serve as a master to CAM and linuxcnc.
OK, when there is no way to imped the backend resetting line number, I may have to add some intelligence to the UI-App.
Ok, I'll check it out. Thanks for your reply!
