7i92-7i76 gantry 2 moptors on X key mappings
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Dec 2019 12:16 - 10 Dec 2019 12:54 #151982 by bevins
The keyboard jogging is weird and not right with tandem X config.
page-up/down moves the machine in Y. and before homing......
The rest shows you cant jog before homing. I would think page-up/down would do the same but on Z instead of Y.
I don't have drivers and steppers connected, I am trying to set this up before I go onsite this weekend.
Linuxcnc 2.9 running on linuxmint 18.3
INI file:
Warning: Spoiler!
HALFile:
Warning: Spoiler!
Last edit: 10 Dec 2019 12:54 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
04 Dec 2019 12:46 - 04 Dec 2019 12:49 #151984 by bevins
Also I am trying to home with hitting the home/limit switches. Z works fine but when I go to hit the Y the first time I hit the home switch, it goes to 0 in the display and start Y moving again, and if I hit switch again I get "joint 2 on limit switch error"
Last edit: 04 Dec 2019 12:49 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
04 Dec 2019 13:03 #151986 by bevins
I though you weren't allowed to jog in world mode with gantry.
04 Dec 2019 13:27 #151989 by dgarrett
Replied by dgarrett on topic 7i92-7i76 gantry 2 moptors on X key mappings
Prior to homing:
When operating in joint mode prior to homing,
keyboard jog keys are assigned in a fixed sequence:
left/right: joint0, up/down: joint1, page up/page down:
joint2, left/right bracket: joint3
Ref: linuxcnc.org/docs/2.8/html/config/ini-co...tml#_display_section
Disallowed jogging prior to homing (joint mode):
Joint mode jogging of joints having a negative
HOME_SEQUENCE is disallowed. In common gantry
applications, such jogging can lead to misalignment
(racking). Note that conventional jogging in world
coordinates is always available once a machine is
homed.
Ref: linuxcnc.org/docs/2.8/html/config/ini-homing.html
Workaround:
System integrators can allow joint jogging prior
to homing with hal logic that switches the
[JOINT_N]HOME_SEQUENCE items. This logic should also
assert the motion.homing-inhibit pin to ensure that
homing is not inadvertently initiated when joint
jogging is enabled.
An example simulation config (gantry_jjog.ini) that
demonstrates joint jogging when using negative home
sequences is located in the: configs/sim/axis/gantry/
directory.
For using keyboard jog keys with the axis gui before
and after homing, the most consistent
coordinate_letter-to-joint_number specification is
coordinates=xyzy.
see also:
forum.linuxcnc.org/plasma-laser/36837-ne...tion?start=70#144976
forum.linuxcnc.org/plasma-laser/36837-ne...tion?start=80#145001
The following user(s) said Thank You: bevins
  • bevins
  • Platinum Member
  • Platinum Member
08 Dec 2019 16:40 #152334 by bevins
I have all axis running homing manually. This machine has a really rigid gantry and only has one homing switch on the dual motor axis.
Can I 'home all" and have the dual motor axis home with both motors but with only one switch? Or would I have to install a switch on the other joint? This is a bigger deal, and wont be able to do it today onsite.
  • bevins
  • Platinum Member
  • Platinum Member
08 Dec 2019 18:35 #152336 by bevins
I'm just going to install a switch on the other joint, and that will be that.
27 Dec 2019 22:55 #153331 by andypugh
Replied by andypugh on topic 7i92-7i76 gantry 2 moptors on X key mappings
Yes, gantries have been working that way for years, prior to the proper support offered in 2.8+
Time to create page: 0.237 seconds
