MPG config
10 Dec 2019 01:29 #152415 by PCW
Replied by PCW on topic MPG config
Should work though stiffer pullups (say 1K) might be better
The following user(s) said Thank You: bevins
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Dec 2019 12:59 #152432 by bevins
Replied by bevins on topic MPG config
OK,I'll add some 1k's and see what it does. Whats the threshold? 3.5v?
  • bevins
  • Platinum Member
  • Platinum Member
10 Dec 2019 13:28 #152433 by bevins
I just thought about something. I checked from 5 volt ground to the pin, not field power ground.
should that matter? If field power is isolated, then how would it ref the 5v gnd?
10 Dec 2019 15:01 - 10 Dec 2019 15:02 #152435 by PCW
You have to connect the MPG and Field power grounds for this to work
Last edit: 10 Dec 2019 15:02 by PCW.
  • bevins
  • Platinum Member
  • Platinum Member
10 Dec 2019 15:45 #152437 by bevins
OK, it is the same 5v power I am using for the 7i92 and 7i76. I take it this would be no problem?
10 Dec 2019 16:03 #152439 by PCW
As long as you connect the 5V ground and field power ground it should be OK
  • bevins
  • Platinum Member
  • Platinum Member
12 Dec 2019 17:28 #152551 by bevins
Finally got back and put some pullups. Works like a charm.
Time to create page: 0.087 seconds
