dual motor gantry issues, hal fix...... FIXED
- bevins
- Thank you received: 338
08 Dec 2019 22:59 #152345
by bevins
dual motor gantry issues, hal fix...... was created by bevins
I am having an issue with two different type of switches on the dual motor gantry and it is causing issues with auto squaring gantry.
One is prox and other is mechanical. The mechanical switch is releasing at a different place and it is racking a very rigid gantry.
I would like to setup machine as XYZ machine instead of XYYZ. I guess stepgen.0 needs to send same output to stepgen.1 so It will act like an XYZ machine.
IS there examples of how to hook this up in hal?
- Thank you received: 7468
08 Dec 2019 23:41 #152346
Replied by tommylight on topic dual motor gantry issues, hal fix......
You could just wire both drive inputs to the same output, and have only 1 switch for homing. Very simple and very reliable up to the point one of the drives craps out.
- bevins
08 Dec 2019 23:45 - 08 Dec 2019 23:45 #152347
by bevins
send step and dir signal from one output into two drives?
Replied by bevins on topic dual motor gantry issues, hal fix......
Last edit: 08 Dec 2019 23:45 by bevins.
08 Dec 2019 23:58 #152348
Yes.
08 Dec 2019 23:59 #152349
Just take it slow the first time you power it on and move the gantry, do just a very short jog and check if both motors are moving in the same direction.
- bevins
09 Dec 2019 00:11 #152350
by bevins
I just tied both inputs to the first switch. IT works great.
Thanks.....
Replied by bevins on topic dual motor gantry issues, hal fix...... FIXED
Thanks.....
Time to create page: 0.244 seconds
