Feed & Spindle override on Mesa 7i76e using two potentiometer.
  • dsergison
  • dsergison's Avatar Topic Author
  • New Member
  • New Member
10 Dec 2019 20:02 #152453 by dsergison
I have read how to wire up for incremental encoder pulse generators, but I want to use a simple analog potentiometers. Is this possible without anything fancy?
Thanks,
10 Dec 2019 20:40 #152454 by Leon82
Thanks,
I came across this in my searches. Not sure if it's what your looking for
store.mesanet.com/index.php?route=produc...t_id=205&search=spin
  • dsergison
  • New Member
  • New Member
10 Dec 2019 21:15 #152455 by dsergison
I think that's backwards? I want my pots to tell linuxcnc to slow down the spindle or the feed. Maybe I misunderstood it
10 Dec 2019 21:16 - 10 Dec 2019 21:18 #152456 by Todd Zuercher
Yes it is possible. No, you don't need to do anything fancy, you simply need to configure the hostmot2 driver to enable the analog input pins on your 7i76e card. (see pg 18 of the manual for the 7i76e.)
Last edit: 10 Dec 2019 21:18 by Todd Zuercher.
27 Dec 2019 23:14 #153339 by andypugh
And then set the halui.spindle−override.direct−value pin to true and make suitable HAL connections.
linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
Time to create page: 0.159 seconds
