Delay motion - spindle spinup
- bevins
- Thank you received: 338
12 Dec 2019 22:59 - 13 Dec 2019 00:58 #152559
by bevins
Delay motion - spindle spinup was created by bevins
I found this code from Tod in the forum and just want some clarification.
If I read this right I could replace "sets spindle-at-speed true" with this and it will delay motion for the time delay set.
Is that correct?
Is that correct?
loadrt timedelay count=1
addf timedelay.0 servo-thread
setp timedelay.0.on-delay 5
net spindle-on => timedelay.0.in
net spindle-timer <= timedelay.0.out
net spindle-timer => motion.spindle-at-speed
Last edit: 13 Dec 2019 00:58 by bevins.
- MaHa
- Thank you received: 241
12 Dec 2019 23:42 #152562
by MaHa
Replied by MaHa on topic Delay motion - spindle spinup
I use a similar configuration, rapid moves are done while timedelay, only feed mode is stoped during delay.
- bevins
13 Dec 2019 12:49 #152598
by bevins
Replied by bevins on topic Delay motion - spindle spinup
motion.spindle-at-speed does not exist.
- Thank you received: 2181
13 Dec 2019 13:02 #152599
Replied by cmorley on topic Delay motion - spindle spinup
2.8 + it has changed:
spindle.0.at-speed
spindle.0.at-speed
- bevins
13 Dec 2019 13:26 - 13 Dec 2019 13:27 #152600
by bevins
net spindle-timer => spindle.0.at-speed
This does not work. It never gets spindle-on
Is there a quick fix for this?
Last edit: 13 Dec 2019 13:27 by bevins.
13 Dec 2019 14:12 #152602
The quickest fix would be to use halmeter/halcmd to probe where the problem is
Is the spindle-on signal connected to anything?
If it is, use halmeter to see if it changes state properly.
if not, connect it to spindle.0.on
- bevins
13 Dec 2019 15:50 - 13 Dec 2019 15:52 #152605
by bevins
ACK...... spindle-on is not connected to anything. spindle-enable is connected to spindle.0.on
Was staring me right on the face.
Last edit: 13 Dec 2019 15:52 by bevins.
- bevins
13 Dec 2019 15:58 #152607
by bevins
Why is spindle.0.on connected to spindle-enable?
Shouldn't this be connected to spindle-on? This config was built with pncconf. Was it changed on purpose or is this an error?
07 Jan 2020 15:13 #154217
Replied by andypugh on topic Delay motion - spindle spinup
If you are using a version of linuxCNC 2.8+ then the spindle pins now have names like
spindle.0.at-speed
This is a result of changes that allow LinuxCNC to control multiple spindles.
spindle.0.at-speed
07 Jan 2020 19:29 #154238
Because pncconf had a bug in it - should be fixed now.
