Usage of hud in vismach?
17 Dec 2019 18:08 - 18 Dec 2019 09:19 #152804 by ross_dev
Usage of hud in vismach? was created by ross_dev
Hi
I have been trying to get the vismach HUD to display updating values, but am drawing a bit of a blank. In vismach.py, in the definition of the hud class, there is a comment:
class Hud(object):
	'''head up display - draws a semi-transparent text box.
	use HUD.strs for things that must be updated constantly,
	and HUD.show("stuff") for one-shot things like error messages'''
	def __init__(self,  showme=1):
		self.app = []
		self.strs = []
		self.messages = []
		self.showme = 0
Creating an object via myhud = Hud() and using myhud.show("example"), I can get the hud to display that text. However I want to stream live data such as joint positions and ultimately, tool number somehow.
Looking at the code for the HUD class, I have tried a few different things in my vismach script unsuccessfully, such as:
myhud = Hud()
myhud.strs = [c.joint0]
myhud.draw()
as draw() appears to work with the strs array. I tried passing c.joint as this is the HAL component for the x axis. Unfortunately the HUD does not appear with the draw command, only with the show which can only handle a static output.
I also tried:
myhud.show(myhud.strs)
Which gives a stack overflow.
This all comes before the final call to main, and I have experimented with using hud=myhud or hud=1 as the hud parameter.
Any suggestions on how best to use this function please?
Cheers!
Last edit: 18 Dec 2019 09:19 by ross_dev.
27 Dec 2019 23:01 #153333 by andypugh
Replied by andypugh on topic Usage of hud in vismach?
Is there any indication that the live display is expecting to be associated with a HAL pin, like the joint positions are?
10 Jan 2020 11:03 #154535 by ross_dev
Replied by ross_dev on topic Usage of hud in vismach?
Hi Andy
I will check - I have kind of shelved this aspect of things for now as it was more of a "nice to have"!
Cheers
Ross
16 Apr 2021 08:19 - 16 Apr 2021 08:20 #206091 by udoS
Replied by udoS on topic Usage of hud in vismach?
Hi Andy / ross_dev
there any new information on the vismach.
Because as soon as I try to start the hud, the vismach is not starting any more.
can someone help with that.
Best Regards
Last edit: 16 Apr 2021 08:20 by udoS.
16 Apr 2021 08:27 #206092 by andypugh
I don't have the answer, but any info learned I will put in the (scant) Vismach docs.
02 Sep 2021 06:30 #219408 by udoS
@ross_dev
Hi ross_dev,
is there any new docu or information on how to get the HUD working.
Best rgds
08 Jan 2023 13:47 - 08 Jan 2023 14:13 #261262 by Aciera
Replied by Aciera on topic Usage of hud in vismach?
I've been playing around with vismach lately and wanted  the hud to display updated axis values. I have modified the 'Hud(object)' class to create a new class 'HalHud(object)' which lets me pass any number of pins to the hud from my vismach script like this:
# start hud
myhud = HalHud(c, ['axis-x: ' ,'axis-y: ', 'axis-z: '], ["{:10.4f}","{:10.4f}","{:10.4f}"], ["axis_x", "axis_y", "axis_z"])
myhud.show_top("XYZABC-TRSRN")
myhud.show_top("------------")
myhud.show("-------------")
myhud.show("The End")
# end hud
class HalHud(object):
        def __init__(self, comp, strings, formats, var):
                self.showme = 0
                self.app =
                self.strs =
                self.messages =
                self.messages_top =
                self.fontbase =
                self.comp = comp
                self.strings = strings
                self.formats = formats
                self.var = var
        def show_top(self, string):
                self.showme = 1
                self.messages_top += [str(string)]
        def show(self, string):
                self.showme = 1
                self.messages += [str(string)]
        def hide(self):
                self.showme = 0
        def clear(self):
                self.messages =
        def draw(self):
                self.strs =
                # create the strings with the updated values using the corresponding list elements
                for n in range(len(self.strings)):
                    self.strs += [self.strings[n] + str(self.formats[n].format(self.comp[self.var[n]]))]
                drawtext = self.messages_top + self.strs + self.messages
                self.lines = len(drawtext)
                #draw head-up-display
                #see axis.py for more font/color configurability
                if ((self.showme == 0) or (self.lines == 0)):
                        return
                glMatrixMode(GL_PROJECTION)
                glPushMatrix()
                glLoadIdentity()
                if not self.fontbase:
                        self.fontbase = int(self.app.loadbitmapfont("9x15"))
                char_width, char_height = 9, 15
                xmargin,ymargin = 5,5
                ypos = float(self.app.winfo_height())
                glOrtho(0.0, self.app.winfo_width(), 0.0, ypos, -1.0, 1.0)
                glMatrixMode(GL_MODELVIEW)
                glPushMatrix()
                glLoadIdentity()
                #draw the text box
                maxlen = max([len(p) for p in drawtext])
                box_width = maxlen * char_width
                glDepthFunc(GL_ALWAYS)
                glDepthMask(GL_FALSE)
                glDisable(GL_LIGHTING)
                glEnable(GL_BLEND)
                glEnable(GL_NORMALIZE)
                glBlendFunc(GL_ONE, GL_CONSTANT_ALPHA)
                glColor3f(0,0.2,0) # sets the color of the hud overlay
                glBlendColor(0,0,0,0.5) #rgba, sets the transparency of the overlay using the 'a' value
                glBegin(GL_QUADS)
                glVertex3f(0, ypos, 1) #upper left
                glVertex3f(0, ypos - 2*ymargin - char_height*len(drawtext), 1) #lower left
                glVertex3f(box_width+2*xmargin, ypos - 2*ymargin - char_height*len(drawtext), 1) #lower right
                glVertex3f(box_width+2*xmargin,  ypos , 1) #upper right
                glEnd()
                glDisable(GL_BLEND)
                glEnable(GL_LIGHTING)
                #fill the box with text
                maxlen = 0
                ypos -= char_height+ymargin
                i=0
                glColor3f(0.9,0.9,0.0) # sets the color of the text in the hud
                for string in drawtext:
                        maxlen = max(maxlen, len(string))
                        glRasterPos2i(xmargin, int(ypos))
                        for char in string:
                                glCallList(self.fontbase + ord(char))
                        ypos -= char_height
                        i = i + 1
                glDepthFunc(GL_LESS)
                glDepthMask(GL_TRUE)
                glPopMatrix()
                glPopMatrix()
Last edit: 08 Jan 2023 14:13 by Aciera. Reason: This editor is KILLING me
10 Jan 2023 02:54 #261414 by cmorley
Replied by cmorley on topic Usage of hud in vismach?
I added this to qt_vismach in 2.9 and master.
I used slightly different code to set the HAL pin lines.
Very nice thank you.
10 Jan 2023 16:22 - 10 Jan 2023 16:27 #261465 by Aciera
I guess what I should have done is use optional arguments in the existing class instead of creating another one. This should also work with any existing code:
class Hud(object):
        # for updating pin values use the optional argument lists. Display will be:
        # 'strings[0]' var[0] formated by formats[0]]
        # 'strings[1]' var[1] formated by formats[1]]
        # and so on
        # Example:
        # Hud(c,["Axis-X: ", "Axis-Y: "], ["{:8.3f}","{:8.3f}"], ["halpin_pos_x", "halpin_pos_y"])
        # for static messages to be displayed before the updating values use Hud.show_top("your_string_here")
        # for static messages to be displayed after the updating values use Hud.show("your_string_here")
        def __init__(self, comp=None, strings=, formats=, var=):
                self.showme = 0
                self.app =
                self.strs =
                self.messages =
                self.messages_top =
                self.fontbase =
                self.comp = comp
                self.var = var
                self.showme = 1
                self.showme = 1
        def hide(self):
                self.showme = 0
        def clear(self):
                self.messages =
        def draw(self):
                self.strs =
                        return
                glPushMatrix()
                glLoadIdentity()
                glPushMatrix()
                glLoadIdentity()
                #draw the text box
                glEnable(GL_BLEND)
                glBegin(GL_QUADS)
                glEnd()
                glDisable(GL_BLEND)
                maxlen = 0
                i=0
                glColor3f(1,0.8,0.4) # sets the color of the text in the hud
                        for char in string:
                        ypos -= char_height
                        i = i + 1
                glPopMatrix()
                glPopMatrix()
Last edit: 10 Jan 2023 16:27 by Aciera. Reason: typo
10 Jan 2023 19:31 - 10 Jan 2023 19:32 #261485 by cmorley
(I don't know if you noticed put posting it seems to strip some of the brackets [] from the code.)
I added a function:
def add_pin(self, text, form, pinname):
rather then define the strings at initialization time.
And made the code be able to read any HAL pin rather then just the component pin.
It is a great idea thank you!
Last edit: 10 Jan 2023 19:32 by cmorley.
