Usage of hud in vismach?
- Thank you received: 2138
15 Jan 2023 17:39 #262050
Replied by Aciera on topic Usage of hud in vismach?
Thanks for the feedback! I have not noticed, but with this editor nothing surprises me.
I revisited my code and modified a few things while including your pin expansion that is more powerful than what I had before.I tried to make things a bit more user friendly than what I had before and also tried to make old vismach model code work with it.Here is what the result looks like:
The corresponding vismach code is a lot more wysiwyg then the lists I was using before:
# start hud
myhud = Hud()
myhud.show("Legacy")
myhud.show_txt(" XYZABC-TRSRN")
myhud.show_txt("----------------------------")
myhud.show_txt("")
myhud.show_msg("Kinematics ", ["IDENTITY","TCP","TOOL","TOOL-2"],"motion.switchkins-type", " active")
myhud.show_txt("")
myhud.show_pin("X abs: ","gen_xyzabc_trsrn_kins.abs-pos-x","{:8.3f}","mm")
myhud.show_pin("Y abs: ","gen_xyzabc_trsrn_kins.abs-pos-y","{:8.3f}","mm")
myhud.show_pin("Z abs: ","gen_xyzabc_trsrn_kins.abs-pos-z","{:8.3f}","mm")
myhud.show_txt("")
myhud.show_txt("")
myhud.show_txt("Supports x,y,z offsets only!")
myhud.show_txt("Does not support G52 or G92")
myhud.show_txt("")
# end hud
15 Jan 2023 17:43 #262052
Btw, do you know if there are any other fonts that can be used?
I had a look around the source code and, if I remember correctly, I only found "8x12" that worked.
16 Jan 2023 09:15 #262112
Using the GLUT library gives some more fonts to choose from
from OpenGL.GLUT import *
then initalize the glut library in the class O:
class O(rs274.OpenGLTk.Opengl):
def __init__(self, *args, **kw):
rs274.OpenGLTk.Opengl.__init__(self, *args, **kw)
self.r_back = self.g_back = self.b_back = 0 # sets the background color of the vismach display
glutInit(sys.argv) # initialize the GLUT library
Let's us use the other fonts:
for string in drawtext:
maxlen = max(maxlen, len(string))
glRasterPos2i(xmargin, int(ypos))
for char in string:
#glCallList(self.fontbase + ord(char))
glutBitmapCharacter(GLUT_BITMAP_HELVETICA_18, ord(char));
ypos -= char_height
i = i + 1
With some adjustments to the character spacing:
#char_width, char_height = 9, 15
char_width, char_height = 14, 20
for char in string:
ypos -= char_height
i = i + 1
- Thank you received: 2164
17 Jan 2023 02:04 #262205
Replied by cmorley on topic Usage of hud in vismach?
I don't think you need string2
myhud.show_val("X : ", "joint.0.pos-fb", "{:8.3f}", "mm")
vrs:
myhud.show_val("X : ", "joint.0.pos-fb", "{:8.3f} mm")
we probably don't need the first string either actually:
myhud.show_val("", "joint.0.pos-fb", "X: {:8.3f} mm")
vrs:
17 Jan 2023 06:02 - 17 Jan 2023 17:36 #262214
Cool, thanks for the tip!
[edit]
So here is the latest version:
- added optional tags for the hud lines. A line can have more than one tag (ie a list of tags). Tagged lines are hidden until activated.
- added functions to show tagged lines either by explicitly passing a tag or a list of tags when a halpin value is equal to a given value or if a halpin value is itself equal to a line tag
- added a function to set the hud color and transparency (static)
- added a function to set the hud text color (static)
[edit]
#hud
myhud = Hud()
myhud.show(" XYZABC-TRSRN")
myhud.show("----------------------------")
myhud.show("")
myhud.add_txt("IDENTITY",[0,3])
myhud.add_txt("TCP",1)
myhud.add_txt("TOOL",2)
myhud.add_txt("TOOL_2",2)
myhud.add_txt("")
myhud.add_pin("X abs: {:8.3f} mm","gen_xyzabc_trsrn_kins.abs-pos-x",4)
myhud.add_pin("Y abs: {:8.3f} mm","gen_xyzabc_trsrn_kins.abs-pos-y",5)
myhud.add_pin("Z abs: {:8.3f} mm","gen_xyzabc_trsrn_kins.abs-pos-z",[2,5])
myhud.add_txt("")
myhud.add_txt("")
myhud.add_txt("Supports x,y,z offsets only!")
myhud.add_txt("Does not support G52 or G92")
myhud.add_txt("")
myhud.show_tags_in_pin("motion.switchkins-type")
myhud.hide_all("halui.estop.is-activated")
myhud.show_tag_if_same([1,2,3,4],"motion.is-all-homed")
myhud.set_hud_rgba(0.5,0.5,0.5,0.9)
myhud.set_hud_text_rgb(0,0,0)
#/hudAttachments:
Last edit: 17 Jan 2023 17:36 by Aciera.
Time to create page: 0.248 seconds
