Moving to "home" before automatic toolchange
20 Dec 2019 16:25 - 20 Dec 2019 16:27 #152954 by jochen91
Hi folks,
At the moment I’m trying to retrofit and old Weboturn CNC lathe. It uses an 8 pocket ATC. I've programmed a HAL component for the toolchanger which works already.
Today i've run the first test cnc program on the lathe and realized, that i would be a good idea to move the atc to home before a toolchange to avoid crashes.
I've remapped M6 to move to my home coordinates.
But now to the problem itself:
As soon as M6 gets typed into the MDI the z and x axis start moving. So far so good... but the ATC starts changing tools as well instantly.
What I want is, that the motion gets completed first, then the tool change.
I've attached my .ini / .hal / custom hal component and my macro for the remap. If anybody has an idea how to achieve my wish I would be really thankful.
I don't want the solve this proplem via the post processor in fusion360.
Kind regards,
Jochen
Last edit: 20 Dec 2019 16:27 by jochen91.
20 Dec 2019 17:05 #152958 by Leon82
Hi folks,
Kind regards,
Jochen
You need some type of in position pin to declare it's ready for tool change
The following user(s) said Thank You: jochen91
20 Dec 2019 17:10 #152959 by jochen91
Replied by jochen91 on topic Moving to "home" before automatic toolchange
Mhhh,
so you mean by checking in the hal component if axis.N.motor−pos−fb == i.e. desired position ?
20 Dec 2019 17:14 #152961 by Leon82
I'm not sure exactly the syntax, but yes
In position,
Change tool
20 Dec 2019 17:20 #152962 by jochen91
I will try this tomorrow and post if this has worked. Thank you!
  • Moderator
  • Moderator
20 Dec 2019 20:51 #152972 by tommylight
Replied by tommylight on topic Moving to "home" before automatic toolchange
Hove not done this in a while, but i think there is an option to set the toolchange position in the ini file, something like :
tollchange_position = x0 y0 z0
or whatever values.
20 Dec 2019 22:31 #152977 by jochen91
Hi tommylight,
this should be by far the cleanest solution. Looked it up and indeed it is under the [EMCIO] Section. I will definitly give this a shoot and report my results. Pretty confident that this should work!
Thank you very much!
21 Dec 2019 11:26 - 21 Dec 2019 11:28 #152992 by jochen91
So i've tried the .ini solution and the one Leon82 suggested.
To make a long story short, the failure was on my side (as always ;) my hal component was running the whole time and started as soon as the requested tool number changed which happens as soon as M6 gets typed into the MDI.
But the request tool flag is only set, when M6 should be executed (which I didn’t check for).
So anyway… it works fine, besides one little problem. Im using the remap method cause the .ini method moves both axis simultaneously and I want to move x first then z.
If I run a demo g-code with some tool changes the ATC moves to the position in the g-code and does the change and not to the position mentioned in the remap.
Any idea would could be the problem?
The macro I posted in the first post is still the same.
Thanks in advance!
Last edit: 21 Dec 2019 11:28 by jochen91.
Time to create page: 0.604 seconds
