Add Action to "Home All Axis"equence
27 Dec 2019 22:23 #153325 by james891
Add Action to "Home All Axis"equence was created by james891
I have a tool changer that I would like to home at the same time as homing my axis. That way if I change tools, I don't have to re-home it each time. Does anyone know if that's a possibility? Or could I put a homing code into the toolchange ladder logic but to only run if it's homing hasn't been done. That "homing done" bit would be reset when I close the program.
Thanks for the help.
27 Dec 2019 23:08 #153337 by andypugh
Replied by andypugh on topic Add Action to "Home All Axis"equence
If you use the "carousel" HAL component that offers a home pin, that could be connected to joint.0.is-homing to make it home at the same time.
Perhaps you could wire up your ladder in a similar way?
28 Dec 2019 12:55 #153363 by james891
Replied by james891 on topic Add Action to "Home All Axis"equence
I have the carousel attached to a stepper, not an axis(saving the axis for a and b), I'd just like to give it pulses for movement so ideally, I'd like to find the file that runs the homing procedure and get it to run a ladder file also. Is that possible? I guess I could just add a Home TC button under the Home axis but it would be nice to have it all in one so I don't accidentally forget.
28 Dec 2019 13:32 #153365 by Mike_Eitel
Replied by Mike_Eitel on topic Add Action to "Home All Axis"equence
You could OR2 all xxx.homing pins to detect any homing process and use that to start your carousel homing
Time to create page: 0.133 seconds
