Help needed setting up WiFi pendent XHC-WHB04
- depronman
- Thank you received: 9
12 Jan 2020 18:52 #154704
by depronman
Replied by depronman on topic Help needed setting up WiFi pendent XHC-WHB04
yes, do you want me to post all of them ?
Cheers,
Paul
Cheers,
Paul
- satiowadahc
- Thank you received: 12
12 Jan 2020 18:53 #154705
by satiowadahc
Replied by satiowadahc on topic Help needed setting up WiFi pendent XHC-WHB04
just the lines that start with loadrt, like in the last file you posted had
loadrt flipflop names=flipflop_resume,flipflop_pause,flipflop_run,flipflop_icon,flipflop_spindle_start,flipflop_spindle_stop
# pins for start/pause button 3.
should be one in there with some loadrt threads names=[]
The following user(s) said Thank You: depronman
- depronman
12 Jan 2020 20:11 #154718
by depronman
this is the HAL section of my ini file
[HAL]
HALUI = halui
HALFILE = orac_pendent.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[HALUI]
# add halui MDI commands here (max 64)
The contents of 'orac_pendent.hal' are posted above
There is no 'custom.hal' file is present
# These files are loaded post GUI, in the order they appear
# Generated by stepconf 1.1 at Sun Jan 5 21:53:20 2020
# overwritten when you run stepconf again
source custom_postgui.hal
Hope this helps, I really appreciate your help (as you have no doubt worked out I am VERY new to Linuxcnc, but compared to MACH3 it is soooo much better
Cheers,
Paul
[HAL]
HALUI = halui
[HALUI]
Cheers,
Paul
- satiowadahc
12 Jan 2020 22:05 #154722
by satiowadahc
hmm.. you might be able to just add:
loadrt threads names=servo-thread period=100
to the top of one of your hal files. Else we'll need to sort out which threads you currently have running by:
1) comment out the line with the pendant hal file
2) running linuxcnc
3) in a seperate terminal run the command `halrun`
4) type 'show threads' and press enter
2) running linuxcnc
- depronman
12 Jan 2020 22:09 #154723
by depronman
I'll give this a try on Tuesday evening, away on business tomorrow back on Tuesday
Your help is much appreciated
Cheers,
Paul
PS are you in the UK ?
Cheers,
Paul
- satiowadahc
12 Jan 2020 22:11 #154724
by satiowadahc
Best of luck!
Sorry, Canadian.
Sorry, Canadian.
- depronman
12 Jan 2020 22:14 #154725
by depronman
I've flown over it many times, but never been - one day, its on my bucket list
Thanks for the help
Paul
Thanks for the help
Paul
Time to create page: 0.642 seconds
