Touch-off via HAL button in AXIS...almost!
- pferrick
- Thank you received: 3
03 Jan 2020 22:51 #153931
by pferrick
Touch-off via HAL button in AXIS...almost! was created by pferrick
Hi all-
I have successfully triggered an MDI command (G10 L20 P1 X0 Y0 Z0) via a HAL button, which I'm intending to use as a workpiece touch-off.
When it happens, the G54 offsets become equal to the current machine coordinates. But the overall effect is not quite the same as pushing the 'touch off' buttons in AXIS and entering 0 for X, Y and Z. Doing that redraws the toolpath with the tool icon (the white cone) over the (0,0,0) point in the coordinate system of the part....the above code repositions the origin just fine, but for some reason AXIS doesn't redraw the toolpath in the updated position.
Any hints would be appreciated!
Thanks,
Patrick
Thanks,
Patrick
- Thank you received: 2181
04 Jan 2020 00:20 #153936
Replied by cmorley on topic Touch-off via HAL button in AXIS...almost!
Unfortunately linuxcnc doesn't send a command to the gui to redraw when you use G10 - you must expressly ask AXIS to reload.
typically axis-remote is used to do this - are you using gladevcp? there is a thread od a few days ago on how to do this:
forum.linuxcnc.org/48-gladevcp/38063-com...p-button-call-python
Chris M
Chris M
The following user(s) said Thank You: pferrick
- pferrick
04 Jan 2020 03:44 #153953
by pferrick
Replied by pferrick on topic Touch-off via HAL button in AXIS...almost!
Thanks for the quick response, Chris. Yes, I am running gladevcp and I think I recall playing around with axis-remote for one reason or the other.
Would it be something along the lines of this python:
import sys
import linuxcnc
c = linuxcnc.command ()
c.program_open("axis-remote --mdi G10 L20 P1 X0 Y0 Z0")
c.program_open("axis-remote --reload")
which would be called by a gladevcp button?
import sys
import linuxcnc
04 Jan 2020 03:59 #153959
The axis remote commands are fine but c.open program only opens gcode related programs
If you look at the thread link I posted the answer is there - assuming you are using gladevcp with a python handler file.
In general you connect a gladevcp button to call a function in a python handler file to do what ever you want such as touch off and reload.
Depending on what version of linuxcnc you are using there could be other options but gladevcp is the most tested way.
Chris
Chris
Time to create page: 0.093 seconds
