mesa 7i92H bitfile for mx4660
- bdelarre
04 Jan 2020 01:59 #153940
by bdelarre
mesa 7i92H bitfile for mx4660 was created by bdelarre
I'm attempting to get a 7i92H mesa ethernet card to talk to an mx4660 via the header pins to the DB25 input on the mx4660. I've found the mx4660 bitfile in the 7i92 software download, and flashed it successfully to the card, this is the result of
I brought up linuxcnc with the the example 7i92 config found in this thread forum.linuxcnc.org/27-driver-boards/3081...e-mx4660-4-axis-step and linuxcnc starts. It also powers up the stepper motors, but I'm not able to jog.
I suspect the pinout defined in the bitfile does not work with the H variant of the mesa 7i92?
From my read of the pinout table for P2 above, IO 2 is step output function mapped to pin 2, which according to the 7i92 manual (www.mesanet.com/pdf/parallel/7i92man.pdf) is header pin 3. Which if I connect that header to the mx4660 db25 input would end up being pin 3 on the db25 input which is x-axis dir input. So step and dir and crossed here, other pins are even more wrong.
Am I reading this right? Do i need to make a custom bit file? Anyone got one for the header outputs?
sudo mesaflash --device 7i92 --addr 10.10.10.10 --readhmidConfiguration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 2 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort PWM 0 PWM (Out)
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort StepGen 4 Step/Table1 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort None
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort QCount 0 Quad-A (In)
11 14 IOPort QCount 0 Quad-B (In)
12 15 IOPort QCount 0 Quad-IDX (In)
13 16 IOPort None
IO Connections for P1
1 17 IOPort None
14 18 IOPort PWM 1 PWM (Out)
2 19 IOPort StepGen 5 Step/Table1 (Out)
15 20 IOPort None
3 21 IOPort StepGen 5 Dir/Table2 (Out)
16 22 IOPort StepGen 9 Step/Table1 (Out)
4 23 IOPort StepGen 6 Step/Table1 (Out)
17 24 IOPort None
5 25 IOPort StepGen 6 Dir/Table2 (Out)
6 26 IOPort StepGen 7 Step/Table1 (Out)
7 27 IOPort StepGen 7 Dir/Table2 (Out)
8 28 IOPort StepGen 8 Step/Table1 (Out)
9 29 IOPort StepGen 8 Dir/Table2 (Out)
10 30 IOPort QCount 1 Quad-A (In)
11 31 IOPort QCount 1 Quad-B (In)
12 32 IOPort QCount 1 Quad-IDX (In)
13 33 IOPort NoneI brought up linuxcnc with the the example 7i92 config found in this thread forum.linuxcnc.org/27-driver-boards/3081...e-mx4660-4-axis-step and linuxcnc starts. It also powers up the stepper motors, but I'm not able to jog.
- Thank you received: 5321
04 Jan 2020 03:15 #153950
Replied by PCW on topic mesa 7i92H bitfile for mx4660
If you look at the leftmost column, this is the DB25 pin so
Step 0 goes to DB25 pin 2 and Dir 0 goes to DB25 pin 3
(you will get these pinouts with a straight through HDR26 to DB25 flat cable)
- bdelarre
06 Jan 2020 00:24 - 06 Jan 2020 00:24 #154119
by bdelarre
Replied by bdelarre on topic mesa 7i92H bitfile for mx4660
Thanks PCW, it does indeed work as expected.
I had mistakenly mis-read how the charge pump dip switch is configured on the mx4660 which was preventing the driver from taking any commands.
My setup now works for stepping, also have PWM control of the VFD operational, and the e-stop hooked in. Next up homing switches and calibration of stepgen settings and I should be good to go.
Thanks!
Thanks!
Last edit: 06 Jan 2020 00:24 by bdelarre.
